Ana içeriğe geç
iLive IKBC384S FM/AM Antenna Replacement
Neye ihtiyacın var
  1. iLive IKBC384S  FM/AM Antenna Replacement, Top Cover: adım 1, 2 resimden 1. iLive IKBC384S  FM/AM Antenna Replacement, Top Cover: adım 1, 2 resimden 2.
    • Make sure you remove all seven 3 mm screws before proceeding to the next step.
  2. iLive IKBC384S  FM/AM Antenna Replacement: adım 2, 2 resimden 1. iLive IKBC384S  FM/AM Antenna Replacement: adım 2, 2 resimden 2.
    • Use iOpener or heat gun on all sides except the front.
  3. iLive IKBC384S  FM/AM Antenna Replacement: adım 3, 2 resimden 1. iLive IKBC384S  FM/AM Antenna Replacement: adım 3, 2 resimden 2.
    • Be cautious when taking the top of the device off there may still be some adhesive stuck to device.
    • The top of the device will be very difficult to remove because of the adhesive holding it together.
  4. iLive IKBC384S  FM/AM Antenna Replacement, FM/AM Antenna: adım 4, 2 resimden 1. iLive IKBC384S  FM/AM Antenna Replacement, FM/AM Antenna: adım 4, 2 resimden 2.
    • Remove all four screws(13.5 mm in length) that are securing the disk drive.
  5. iLive IKBC384S  FM/AM Antenna Replacement: adım 5, 2 resimden 1. iLive IKBC384S  FM/AM Antenna Replacement: adım 5, 2 resimden 2.
    • Unplug the ribbon cable connected to the motherboard that stems from the disc drive.
    • Also, disconnect the two power connectors from the motherboard.
    • Once you have removed the ribbon cables and two connectors on the motherboard the disk drive can be removed.
  6. iLive IKBC384S  FM/AM Antenna Replacement: adım 6, 1 resimden 1.
    • After removing the top of the device, locate the screws on the motherboard. Gently unscrew all four of the 3.5mm screws on the motherboard.
  7. iLive IKBC384S  FM/AM Antenna Replacement: adım 7, 2 resimden 1. iLive IKBC384S  FM/AM Antenna Replacement: adım 7, 2 resimden 2.
    • Desolder the antenna at the contact point.
    • Check out this awesome guide for soldering and desoldering tips.
  8. iLive IKBC384S  FM/AM Antenna Replacement: adım 8, 2 resimden 1. iLive IKBC384S  FM/AM Antenna Replacement: adım 8, 2 resimden 2.
    • Place iOpener on antenna for approximately 5 minutes
  9. iLive IKBC384S  FM/AM Antenna Replacement: adım 9, 1 resimden 1.
    • Lift up and remove all of the antenna.
    • The antenna will be glued down all the way around the radio
Sonuç
Tracy Walts
201 İtibar
2 adet Kılavuz yazıldı
Ekip
Texas Tech, Team S46-G6, Bennett Spring 2017 Texas Tech, Team S46-G6, Bennett Spring 2017 üyesi
TTU-BENNETT-S17S46G6
3 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 6
Her zaman: 683
