Ana içeriğe geç
iMac 27" 2017 RAM Replacement
Neye ihtiyacın var
    1. iMac 27" 2017 RAM Replacement, Open the RAM door: adım 1, 2 resimden 1. iMac 27" 2017 RAM Replacement, Open the RAM door: adım 1, 2 resimden 2.
      • While holding the display steady, use the flat end of a spudger to press in on the RAM door release button, located just above the power port.
      • You may have to press fairly hard—keep at it until the bottom of the door pops out about 0.25" from the rear of the iMac.
      FixBot'a Sor
      Yorum Ekle
    2. iMac 27" 2017 RAM Replacement, Remove the RAM door: adım 2, 3 resimden 1. iMac 27" 2017 RAM Replacement, Remove the RAM door: adım 2, 3 resimden 2. iMac 27" 2017 RAM Replacement, Remove the RAM door: adım 2, 3 resimden 3.
      • Pull the RAM access door off the back of the iMac.
      FixBot'a Sor
      Yorum Ekle
    3. iMac 27" 2017 RAM Replacement, Unlock the RAM tray: adım 3, 3 resimden 1. iMac 27" 2017 RAM Replacement, Unlock the RAM tray: adım 3, 3 resimden 2. iMac 27" 2017 RAM Replacement, Unlock the RAM tray: adım 3, 3 resimden 3.
      • The RAM tray is locked into its upright position with two grey tabs.
      • Use your thumbs or index fingers to unlock the tray by pushing the tabs outward, away from the RAM.
      • Pull the tabs out and down, swinging the RAM tray down to a near-horizontal position.
      FixBot'a Sor
      Yorum Ekle
    4. iMac 27" 2017 RAM Replacement, Remove the RAM: adım 4, 3 resimden 1. iMac 27" 2017 RAM Replacement, Remove the RAM: adım 4, 3 resimden 2. iMac 27" 2017 RAM Replacement, Remove the RAM: adım 4, 3 resimden 3.
      • Remove a stick of RAM by grabbing it with two hands and pulling straight out of the RAM tray.
      • RAM modules are keyed so that they can only be installed in the proper orientation. Note where the shorter section of contacts is when removing, and reinstalling, your RAM.
      • To install a new module, insert the module into the desired slot in the tray and press it firmly in place. Push the tray back up until it locks in place.
      • The RAM access door is not symmetrical. If it is not flush on both ends, try putting it in the other way.
      • Re-insert the RAM access door back into its place.
      FixBot'a Sor
      Yorum Ekle
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Adam O'Camb
224.695 İtibar
416 adet Kılavuz yazıldı
2Kılavuz Yorumları
Thanks Arthur, I got them
walser1 - Yanıt Paylaş
bom dia, posso trocar a memoria de 2444MHZ para 2666MHZ? 3000MHZ ?
MARCELO MIRA - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 13
Son 7 gün: 48
Son 30 gün: 214
Her zaman: 21,636
