Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Lay the iMac display-side down on a flat surface (putting a cloth under the screen to protect it from bumps).
Loosen the three Phillips screws securing the rear panel to the iMac.
Lift the rear panel slightly near the bottom of the iMac.
Pull the rear panel toward yourself and remove it from the iMac.
Remove the three Phillips screws securing the power supply to the chassis.
Rotate the center Phillips screw on the bottom of the iMac clockwise until the rear panel clamp contacts the edge of the case.
Bu adımda kullanılan alet:Heavy-Duty Spudger$4.99-
While depressing the connector lock, use a heavy duty spudger to pry the power supply connector away from its socket on the logic board.
Lift the power supply slightly from its left edge, then grab each side and rotate the power supply toward yourself.
Rotate each of the two RAM retaining arms away from the RAM chip.
Pull the RAM chip straight away from its socket.
Remove the following two screws:
One 11 mm T10 Torx.
One 10.6 mm T8 Torx.
Remove the two 7.3 mm Phillips screws securing the display data cable to the logic board.
Pull the display cable up off the logic board by its black pull tab.
Disconnect both the left and right fan connectors by pulling them straight up off the logic board.
Disconnect the SATA data cable by pulling its connector straight up off the logic board.
Disconnect the SATA power cable by depressing the lock mechanism and pulling the connector straight away from its socket (parallel to the face of the logic board).
Remove the four 7 mm Phillips screws securing the optical drive to the midplane.
Pull the optical drive up by its white pull tab to disconnect it from the logic board.
Lift the free end of the optical drive slightly, then pull it away from the edge of the rear case to clear the two plastic positioning pins.
Lift the optical drive out of your iMac.
Use the tip of a spudger to lift the speaker cable slightly.
Disconnect the speaker cable by pulling its connector straight up from the logic board.
Use the tip of a spudger to slightly lift the lower fan cable and microphone cable.
Disconnect the fan and microphone cables by pulling their connectors straight up from the logic board.
Lift the AirPort card slightly by its plastic tab and pull it straight away from its socket.
Insert the flat end of a spudger between the body of the AirPort card and its antenna connector.
Push the spudger away from the AirPort card to disconnect the AirPort antenna.
Use a spudger to push the AirPort antenna through the gap in the AirPort bracket.
Pull the AirPort antenna out from underneath the AirPort bracket.
Remove the two 5.5 mm T6 Torx screws securing the Bluetooth board to the logic board.
Use your finger to lift the Bluetooth board from the right edge up off its socket on the logic board.
Use a spudger to pry the antenna connector off the Bluetooth board.
Disconnect the hard drive thermal sensor cable from the hard drive thermal sensor board.
Remove the following three screws:
One shouldered 12.4 mm Phillips.
Two 7 mm T10 Torx.
Insert the flat end of a spudger into the gap between the SATA data connector and the hard drive.
Twist the spudger to separate the SATA data connector from the hard drive, then disconnect it from the hard drive.
Disconnect the black inverter cable from its socket on the logic board by pulling the cable straight away from its socket toward the side of the iMac.
Remove the following 9 screws securing the logic board to the midplane:
Eight 7 mm T10 Torx.
One 26 mm Phillips.
Gently lift the logic board from its left side to clear the two pins mounted to the midplane.
Lift the logic board out of the midplane. Careful, there is a light guide on the lower left that can tear if you are not careful. This guides the light to the power-on light at the front of the iMac.
57 farklı kişi bu kılavuzu tamamladı.
5 Yorum
After removing and replacing the logic board on my iMac G5 twice, I thought I should add a suggestion.
Before replacing the board, it helps to tape or tie back all of the cables and connectors well out of the way. It's so easy to accidentally trap one of the connectors under the edge of the board. Also make sure to tie the speaker cables in a little bundle to make sure they fit into the small notch in the board/frame as it goes down.
One more item. When lowering the board into place, watch the small white plastic sleep light cone. The left of the two ears tend to get stuck on the edge of the (midplane?). It's difficult to see, but you can poke the end of a spurger in from the left to move the cone over just far enough to clear as the board is lowered. Make sure the holes in the sleep light cone ears are located over the little white matching pins. I made this mistake which caused me to remove the logic board, disturbing the thermal paste on the CPU.
My compliments to Andrew and everyone else who's been involved in this guide. I'd like to add my own suggestion regarding the 2
SATA cables and their routing. Make sure to A. Take a photo of any wiring routing prior to disassembly, and B. Note that the SATA power and data cables route UNDER the logic board as they pass from the HDD to their respective connectors on the logic board. I made the mistake of not paying attention and had to backtrack a bit to properly route those wires. Could / Would not have done this job without your guide so thank you very much!
Excellent guide, I recently found an old iMac A1076 for 20 bucks at a thrift store, it powered on but no display. I ordered a replacement logic board and this guide was really easy to follow to replace the faulty old board. It’s now up and running great! Thanks again
My problem is when the power cable on,the led 1,2 is on,hit the power button,the sound DON can hear,but led 3,4 is off,the fans is normal,but after half past minute,the fans begin loud noise screen still black,is the problem is logic board or the LCD display?much appreciate
You should post your question in the forum to get a faster response. It’s been awhile since I’ve worked on this machine and don’t quite remember the LED indications. Doesn’t sound like an LCD issue.
