Giriş
このガイドを使って、お持ちのハードドライブの交換やアップグレードができます。
このガイドはSSDを搭載したiMacのハードドライブのアップグレードの方法も書いてあります。どうやってSSDの温度センサーをインストールすればいいか書いてあるのでMacのファンは正しいスピードで動作するでしょう。
iMacを起動させる前にコンピューターのプラグを抜き、電力供給のコンデンサを放電するために10秒間、電源ボタンを押したままにします。
細心の注意をしてくださいコンデンサのリード線や電力供給装置の裏にあるむき出しのはんだ接合には、絶対に触れないでください。
Neye ihtiyacın var
Bu adımda kullanılan alet:Heavy-Duty Suction Cups (Pair)$14.95
ガラスパネルの上部コーナーの2箇所に吸盤カップを取り付けます。
吸盤カップがうまく装着しない場合は、ガラスパネルと吸盤カップを中性洗剤などで綺麗に拭き取ってください。
デバイスを組み立て直すには、これらの手順と逆の順序に従ってください。
252 farklı kişi bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
44 Yorum
I went through all the steps and now when I attempt to boot, I hear the apple chime, but I get nothing on screen.
I thought this might have to do with a loose cord, but when I reattached the suspect cord (the display data cable) it did not resolve the problem.
Anyone have any ideas as to what could be causing the display to malfunction?
I had this problem as well, caused by a small cable coming from the display. It is a Sync Cable with a small 2 Pin Molex connector, and it popped up and got hidden when I removed the display, which caused me to forget to re-attach it during reassembly.
capone99 -
Question for capone99: where did this cable come from? Was it one of the five specified for unplugging in this guide? Or are you saying it came loose by itself during installation?
Did anyone ever solve this? Having the same issue.
In step 14, the Apple connector for the hard drive has a locking mechanise that doesn't fit most replacement hard drives. I got an identical hard drive that doesn't have a provision for the connector. A little bit of shaving or filing of the plastic connector did the trick.
