Ana içeriğe geç
iMac Intel 24" EMC 2267 RAM Replacement
Neye ihtiyacın var
  1. iMac Intel 24" EMC 2267 RAM Replacement, Note - most of this guide was taken from the info for: iMac Intel 20" EMC 2266: adım 1, 1 resimden 1.
    • Lay your iMac front side down on a table with the lower edge facing yourself.
    • Loosen the single Phillips screw PH#2 in the center of the access door.
    • This screw is captive in the access door.
    • Remove the access door from your iMac.
  2. iMac Intel 24" EMC 2267 RAM Replacement, Note - most of this guide was taken from the info for: iMac Intel 20" EMC 2266: adım 2, 2 resimden 1. iMac Intel 24" EMC 2267 RAM Replacement, Note - most of this guide was taken from the info for: iMac Intel 20" EMC 2266: adım 2, 2 resimden 2.
    • Use the sharp end of a spudger to pull the black plastic RAM tabs out of the memory bay. Formatting help
    • Pull the black plastic RAM tab away from your iMac to eject the RAM chip.
  3. iMac Intel 24" EMC 2267 RAM Replacement: adım 3, 1 resimden 1.
    • Grab the RAM chip by its edges and pull it straight out of its slot.
    • If two RAM chips are installed, repeat this process for the other chip.
Sonuç
37 farklı kişi bu kılavuzu tamamladı.
johann beda
2.550 İtibar
15 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 20
Son 30 gün: 87
Her zaman: 26,932
