Ana içeriğe geç
iMac Intel 27" EMC 2429 RAM Replacement
Neye ihtiyacın var
  1. iMac Intel 27" EMC 2429 RAM Replacement, Access Door: adım 1, 2 resimden 1. iMac Intel 27" EMC 2429 RAM Replacement, Access Door: adım 1, 2 resimden 2.
    • Loosen the three Phillips screws securing the access door to the bottom edge of your iMac.
    • These screws will remain captive in the access door.
    • Remove the access door from your iMac.
    • During reassembly, fasten the access door loosely and align it with the pocket cut into the outer case of the iMac before fully tightening the screws.
    I am going to put a very important comment here. Before you start this process listen to the fans on your iMac do any of them sound obviously loud (think about how quiet your iMac used to sound as a reference) If you notice one or more of them sounding substantially loud compared to the others consider locating a replacement fan prior starting this process. After all if you are already “in the neighborhood” it is a shame to do all this work only to have to disassemble your imac a couple weeks later because you realize the fan is failing. I speak from my own personal learning experience of having to disassembly my iMac 3 weeks later because the HDD was failing and apparently the moving the fan around was just enough to push it to start really under performing.
    Wizbang FL - Yanıt
    I’m not sure why it is necessary to remove the RAM. As far as I can tell, it can remain in place during this procedure.
    gordonhamachi - Yanıt
  2. iMac Intel 27" EMC 2429 RAM Replacement, RAM: adım 2, 1 resimden 1.
    • Use your fingers or the tip of a spudger to slide the black plastic RAM tray pull tab out of the RAM slot.
    Bonjour, j’ai arraché la languette. Conséquence, elle est inutilisable et je ne peux pas retirer la barrette. Comment faire autrement ? Est-ce que cet outil peut être utile ?
    Robert Ainstain - Yanıt
  3. iMac Intel 27" EMC 2429 RAM Replacement: adım 3, 2 resimden 1. iMac Intel 27" EMC 2429 RAM Replacement: adım 3, 2 resimden 2.
    • Pull the black plastic tab away from the iMac to eject the RAM chip from its socket.
    • The RAM modules are firmly seated and may require a fair amount of force to remove.
    • Use your fingers to slide the RAM chip out of its socket.
    • If necessary, repeat this process for the other RAM module(s).
    How many 4MB cards can I install?
    nowsc - Yanıt
    None. 4mb ram is too old to fit into any computer manufactured after like 1998.
    Brett Davison - Yanıt
    @Brett
    I suggest that you learn your unit symbols before you try to appear clever:
    4mb == 4 milli bits
    4MB == 4 mega bytes
    nowsc was obviously meaning 4GB not 4MB, try not to be a dick.
    Simon - Yanıt
    Just for the records :
    4 millibits are 0,000000004 MB
    There was never any RAM in mb and the question states MB and nobody except you is talking of millibits.
    You are also a dick if you try to spread “your knowledge” nobody has asked for
    Hein Blöd -
    Take care to note which way out the RAM comes - there is a notch in each RAM and it is not centered, therefore either the notch will be on the left or to the right (depending on which way up you have your iMac). This will make it easier to replace the RAM without damaging anything.
    Mike Haines - Yanıt
    If damaged the notch inside one pair of RAM slots, is it fixable ?
    Gavriil Bordyukov - Yanıt
    its not that hard to say that you can add up to 4GB sticks, bringing a total to 16GB
    Charlie Amis - Yanıt
    Does it make a difference which slots you put sticks in? Should they be inserted in slots left to right or can they be inserted on one side (front/back)? And I've seen it referenced as "Channel A (slots 1 and 2) and Channel B (slots 3 and 4)", no diagram as to which is which.
    Melanie Collins - Yanıt
    It does make a difference, but only if you have a single stick of memory. Here's what Apple says about the 27" 2011 iMac:
    Source: https://support.apple.com/en-us/108317#2
    Amusingly, although Apple defines "bottom" as being closer to the stand, that is opposite to the orientation of the pictures.
    Apple does not mention memory channels in their text or diagrams. Since they came with both top slots populated, a good bet is that they are on separate channels (left and right).
    hackerb9 -
    (Update: I believe Apple's wording was incorrect. "Top" is closest to the stand, not the display, because those are the slots which had the SO-DIMMs in the iMac I just checked.)
    hackerb9 -
Sonuç
93 farklı kişi bu kılavuzu tamamladı.
Phillip Takahashi
87.367 İtibar
87 adet Kılavuz yazıldı
15 Yorum
My iMac 21.5-inch Mid 2011 has EMC 2428, but still directions turned out to be the same.
I replaced the memory in my MacBook Pro, and used the old cards (2x2GB) to fill out the 2 empty slots that apple left empty, doubled the memory of 2 machines for the price of one ^_^
Mabel - Yanıt
So confused. I have an end 2429 and I ordered some memory hut its says notebook memory, do these machines use the same type of ram?
Kosta Kritikos -
Thanks ifixit team, I did it. It is really piece of cake! Thanks again!
prelude0214 - Yanıt
What's the real max capacity for the RAM?
Angel Pimienta - Yanıt
16 Gb (4 x 4 Gb) DDR3 1333 MHz
Aleksei Marinichev -
16gb according to Apple but 32gb is no problem I would recommend using all identical sticks ie. same manufacturer/speed etc etc.
I have run 32gb for years in that machine With no issues.
Richard Reichle -
Hi, can I add one Ram of 4MB and one of 8Mb?
Cristian Catanescu - Yanıt
You can but it’s not an ideal configuration
Richard Reichle -
Hi, according to Mactracker the iMac 27 inch mid 2011 can have up to 32GB of RAM. Anyone tested this?
Bård Arve Evjen - Yanıt
Absolutely I have 32gb and I have used that config since it was new
Richard Reichle -
Thanks so much! I just pulled them out did vacuum, & stuck them back in. You saved me an expensive trip to the computer repair store.
Lindaj - Yanıt
With EMC 2429 can I upgrade just two of the four RAM slots? ie I currently have 4x2 GB RAM (8GB total), can I replace just two if the ram chips with 4 GB chips so I end up with 2x4GB and 2x2GB (12GB total) installed? Many thanks
Rich - Yanıt
Yes, you can. As long as you are installing as a pair, you can replace two 2GB (2x2) with two 4GB (2x4).
Mikkif -
I think it would be ok to show what the position of the RAM should be when you insert it.
And leave the old RAM in. Adding RAM the easy way.
A Eensteen - Yanıt
Mein iMac stürzt nach einer RAM-Erweiterung ständig ab, obwohl der RAM die Anforderungen genau erfüllt (von 2 x 2GB DDR3 SO-DIMM auf 4 x 8GB DDR3 SO-DIMM, 1333Hz), ich weiß nicht, was ich machen soll. Ich finde auch in den entsprechenden Foren keine passende Lösung. Muss ich vielleicht das Betriebssystem (MAC-OS 10.14) neu installieren?
Inva Sion - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 16
Son 7 gün: 42
Son 30 gün: 186
Her zaman: 84,789
