Ana içeriğe geç
iMac Intel 27" EMC 2546 RAM Replacement
Neye ihtiyacın var
  1. iMac Intel 27" EMC 2546 RAM Replacement, Open the RAM door: adım 1, 2 resimden 1. iMac Intel 27" EMC 2546 RAM Replacement, Open the RAM door: adım 1, 2 resimden 2.
    • While holding the display steady, use the flat end of a spudger to press in on the RAM door release button, located just above the power port.
    • You may have to press fairly hard—keep at it until the bottom of the door pops out about 0.25" from the rear of the iMac.
    FixBot'a Sor
    Yorum Ekle
  2. iMac Intel 27" EMC 2546 RAM Replacement, Remove the RAM door: adım 2, 3 resimden 1. iMac Intel 27" EMC 2546 RAM Replacement, Remove the RAM door: adım 2, 3 resimden 2. iMac Intel 27" EMC 2546 RAM Replacement, Remove the RAM door: adım 2, 3 resimden 3.
    • Pull the RAM access door off the back of the iMac.
    FixBot'a Sor
    Yorum Ekle
  3. iMac Intel 27" EMC 2546 RAM Replacement, Unlock the RAM tray: adım 3, 3 resimden 1. iMac Intel 27" EMC 2546 RAM Replacement, Unlock the RAM tray: adım 3, 3 resimden 2. iMac Intel 27" EMC 2546 RAM Replacement, Unlock the RAM tray: adım 3, 3 resimden 3.
    • The RAM tray is locked into its upright position with two grey tabs.
    • Use your thumbs or index fingers to unlock the tray by pushing the tabs outward, away from the RAM.
    • Pull the tabs out and down, swinging the RAM tray down to a near-horizontal position.
    FixBot'a Sor
    Yorum Ekle
  4. iMac Intel 27" EMC 2546 RAM Replacement, Remove the RAM: adım 4, 3 resimden 1. iMac Intel 27" EMC 2546 RAM Replacement, Remove the RAM: adım 4, 3 resimden 2. iMac Intel 27" EMC 2546 RAM Replacement, Remove the RAM: adım 4, 3 resimden 3.
    • Remove a stick of RAM by grabbing it with two hands and pulling straight out of the RAM tray.
    • RAM modules are keyed so that they can only be installed in the proper orientation. Note where the shorter section of contacts is when removing, and reinstalling, your RAM.
    • To install a new module, insert the module into the desired slot in the tray and press it firmly in place. Push the tray back up until it locks in place.
    • The RAM access door is not symmetrical. If it is not flush on both ends, try putting it in the other way.
    • Re-insert the RAM access door back into its place.
    FixBot'a Sor
    Yorum Ekle
Sonuç
62 farklı kişi bu kılavuzu tamamladı.
Andrew Optimus Goldheart
515.377 İtibar
407 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
31.535 adet Kılavuz yazıldı
4Kılavuz Yorumları
If you have two original RAM sticks, they're installed in alternating slots, so there's no need to move anything around to install two more - just use the empty slots.
matt - Yanıt Paylaş
Ich habe diese Anleitung genutzt bei meinem 27“ late 2013 Mac. Zu den vorhandenen Speichern von 2x4GB habe ich in die leeren Slots je einen 8GB Speicher eingesetzt. Das ging problemlos so wie beschrieben. Habe kein Werkzeug gebraucht. Die Taste zum Öffnen konnte ich mit dem Daumennagel hineindrücken. Der gesamte Speicher wird mit 24GB angezeigt. Vielen Dank für diese Hilfe!
Nedra - Yanıt Paylaş
Hello. My Imac (27-inch, Late 2012) has the original memory (2x4GB Elpida) in slots 1 and 2. When trying to install in slots 1+3, 1+4, 2+3, 2+4 it beeps three times and the Mac does not start. Replacing the original memory in slots 1+2 with new memory (2x8GB) is successful. Can not add memory to slots 3 and 4 (old memory or new). Please advise where to look for the problem.
Олег Б. - Yanıt Paylaş
First, check if the memory slot pins are faulty. Place your iMac on a soft surface and use a flashlight to check for any signs of bending. If not, double-check that all memory modules have the same frequency (e.g., the memory card for an iMac 2012-27'' has a frequency of 1867MHz).
Jason Noh - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 26
Son 30 gün: 147
Her zaman: 53,165
