Giriş
Use this guide to remove the logic board and strip it of all its peripherals: SSD, AirPort, heat sink and CPU, and RAM.
Before beginning any work on your iMac: Unplug the computer and press and hold the power button for ten seconds to discharge the power supply's capacitors.
Be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply.
With the hinge free to move, the iMac will be unbalanced and hard to work on. Repairs can be completed with the iMac laying down, but are faster and easier with an iMac service wedge.
If you are using the iFixit cardboard service wedge, follow these assembly directions to put it together.
With the cards inserted as shown near the corners, gently twist the cards to increase the gap between display and case.
If there are any sections that seem to stick and won't separate, stop twisting and use one of the cards to cut the adhesive in the problem area.
Begin to lift the top of the display up from the frame.
If there is a wire or cable underneath adhesive tape, always pull the tape off first.
If the cable is glued to the chassis, use a heated iOpener or a hair dryer to soften the adhesive first. You can then slide an opening pick underneath the cable to loosen it. Never pull directly on the delicate connectors.
Slide an opening pick underneath the foam cushion pieces to separate them from the display, and gently pull them off. You may need some double sided tape to re-attach them to the new display.
Use a Phillips screwdriver to remove the nine 3.2 mm screws securing the support bracket.
You may need to peel up the display adhesive lining the bottom edge of the iMac enclosure to access the screws.
Pull straight up on the SATA data/power cable to disconnect it from the drive.
Disconnect the power supply control cable from the power supply.
Use the tip of a spudger to disconnect the fan cable's connector from its socket on the logic board.
Use the flat end of a spudger to disconnect each of the four antenna connectors from the AirPort/Bluetooth card.
Leftmost
Top
Upper right
Lower right
Pull up on the SATA power cable connector to disconnect it.
Unplug the SATA data cable connector by depressing its locking tab and pulling straight up on the connector.
Remove the SATA cable from the logic board assembly to get it out of the way and prevent it from being damaged.
Use your thumbs or index fingers to unlock the tray by pushing the tabs outward, away from the RAM.
Pull the tabs out and up, swinging the RAM tray up to a near-vertical position.
Remove two 3.7 mm T5 screws from the back of the logic board.
Remove the power supply cable from its connector by pulling it parallel to the logic board.
To reassemble your device, follow these instructions in reverse and use our Adhesive Strips Guide to reattach the display glass.
27 farklı kişi bu kılavuzu tamamladı.
15 Comments
Don't forget to use a ESD Wrist Strap and or ESD Mat; you can fry components by touching the wrong surface or part; don't find out the hard way.
Tell us the Manufacturer of the Logic Board please and the Modell Type
C02SX8FRGG7J logic board
I wonder if its possible to install a newer(2017) Logic Board with a better GPU,CPU and faster USB Ports into my late 2015 iMac 5k.
I mean, to buy one costs around 500$, why not to swap it out and sell the 2015 Board. The Upgrade to
a newer GPU and newer System (USB-C, RAM, CPU) may worth the 500$.
After all one could sell the old Logic Board and gain some money back - don´t you think it is a good deal?
After the Upgrade I could finally use the TB3 for eGPUs and all other Benefits of the newer iMac Board.
I know, I would have to deal with the Ports and do some work on the Body of the Mac, but if this is the only problem, then I
think it is manageble. What I really do not know is wether the 2017 Board will fit in the 2015 Body or not, and wether the power supply is the same or not.
Thank you for Answers, I hope there will be some.
I’d like to know the same thing. Theoretically it’s possible but sounds very weird to be that none tried or ask the same thing. I’d be a very bad thing for Apple
