Giriş
Use this guide to replace a joystick cover on an iNNEXT N64 Classic Controller.
Before opting for replacement, ensure any joystick malfunctions are not a product of any debris or any substance that could be cleaned with a dust blower and cotton swap dipped lightly in isopropyl alcohol.
Before you begin this repair, make sure to disconnect your controller from the console.
Neye ihtiyacın var
Turn the controller face down.
Use a Phillips #00 screwdriver to remove the eight screws on the back of the controller.
To remove the shoulder buttons, lift the buttons labelled with "L" and "R" upwards and out of the controller. There should not be any resistance coming out.
Use a Phillips screwdriver to remove the 6 screws securing the joystick assembly to the top of the controller.
Gently lift the control panel and joystick assembly from the top cover of the controller.
Flip the control panel along with the attached joystick assembly over so that they are facing you.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
