Ana içeriğe geç
iNet M1001 Battery Replacement
Neye ihtiyacın var
  1. iNet M1001 Battery Replacement, Back Cover: adım 1, 2 resimden 1. iNet M1001 Battery Replacement, Back Cover: adım 1, 2 resimden 2.
    • Remove the two 4.1 mm PH1 screws with a Philips screwdriver.
  2. iNet M1001 Battery Replacement: adım 2, 2 resimden 1. iNet M1001 Battery Replacement: adım 2, 2 resimden 2.
    • Press the small suction cup on the back cover, and then pull the small suction cup to remove the back cover.
  3. iNet M1001 Battery Replacement, Battery: adım 3, 2 resimden 1. iNet M1001 Battery Replacement, Battery: adım 3, 2 resimden 2.
    • Desolder the battery wires with a soldering iron; pull the wires out.
    • Check out this awesome guide for tips on soldering and desoldering.
  4. iNet M1001 Battery Replacement: adım 4, 2 resimden 1. iNet M1001 Battery Replacement: adım 4, 2 resimden 2.
    • Remove the two pieces of tape on the battery.
  5. iNet M1001 Battery Replacement: adım 5, 1 resimden 1.
    • Apply heat around the edges of the battery with a hair dryer.
  6. iNet M1001 Battery Replacement: adım 6, 3 resimden 1. iNet M1001 Battery Replacement: adım 6, 3 resimden 2. iNet M1001 Battery Replacement: adım 6, 3 resimden 3.
    • Pry off the battery with a plastic opening tool.
Sonuç
Abdulateef Abola
401 İtibar
4 adet Kılavuz yazıldı
Ekip
IUPUI, Team 4-1, Baechle Spring 2017 IUPUI, Team 4-1, Baechle Spring 2017 üyesi
IUPUI-BAECHLE-S17S4G1
2 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 218
