Ana içeriğe geç
iPhone 12 Back Glass Replacement
REWA
REWA ve 3 diğer katkıda bulunanlar
En son March 27, 2024 tarihinde güncellendi
40 dakika
Çok zor
Topluluk-Katkılı Kılavuz
It is well known that Apple has added MagSafe to the iPhone 12 series. While trying to separate the back glass, we found that the magnets were glued to the back glass. Undoubtedly, the difficulty to refurbish the iPhone 12 series back glass has accordingly increased. Thanks to our rich experience and proper tools, we finally figured out the right way to fix the iPhone 12 back glass.
  1. Disassemble the phone and remove the wireless charging coil.
  2. After that, scan the back glass with laser except for the camera area.
  3. Then we remove the magnet array and the back glass.
  4. Put on the new back glass with enlarged camera holes.
  5. Stick the magnet array and shield to the new back glass.
The foregoing guide gives you a clear and correct guide about how to replace the iPhone 12 back glass.
However, the journey to search the right way was not easy. We made the first attempt and almost failed. Scroll down and you will see what challenges we have come across.
Videoya Genel Bakış
  1. iPhone 12 Back Glass Replacement, Laser Marking: adım 1, 3 resimden 1. iPhone 12 Back Glass Replacement, Laser Marking: adım 1, 3 resimden 2. iPhone 12 Back Glass Replacement, Laser Marking: adım 1, 3 resimden 3.
    • Put the back glass of iPhone 12 under the focus positioning probe of the laser marking machine. After positioning, mark the back glass area except for the camera and wireless charging area. We haven't marked the wireless charging area to avoid damage.
    Where can we find the files necessary to program the laser for 12's?
    Scott Chiste - Yanıt
  2. iPhone 12 Back Glass Replacement, Back Glass Separation: adım 2, 3 resimden 1. iPhone 12 Back Glass Replacement, Back Glass Separation: adım 2, 3 resimden 2. iPhone 12 Back Glass Replacement, Back Glass Separation: adım 2, 3 resimden 3.
    • A new member, Glass Breaking Pen, is coming to our back glass refurbishing tools family. Break the back glass with Glass Breaking Pen and remove the shards with Pry Bar.
    • When breaking the wireless charging area, you can see that the magnets are glued to the glass. Hence the back glass fix solution of iPhone 11 is not suitable for iPhone 12.
    • If we stick to our old method, all magnets will fall off and become separate. The subsequent recovering process will be harder. In addition, we can’t mark the wireless charging area directly with a laser to avoid damage.
  3. iPhone 12 Back Glass Replacement, Back Glass Separation: adım 3, 3 resimden 1. iPhone 12 Back Glass Replacement, Back Glass Separation: adım 3, 3 resimden 2. iPhone 12 Back Glass Replacement, Back Glass Separation: adım 3, 3 resimden 3.
    • We should remove the wireless charging coil and then mark. The magnet array and shield can be easily removed after marking.
  4. iPhone 12 Back Glass Replacement, Back Glass Separation: adım 4, 2 resimden 1. iPhone 12 Back Glass Replacement, Back Glass Separation: adım 4, 2 resimden 2.
    • Then we remove the glass around the camera. Please do not touch the camera lens.
    • After the glass is completely removed, mark the back again to remove residual adhesive.
  5. iPhone 12 Back Glass Replacement, Back Glass Gluing: adım 5, 3 resimden 1. iPhone 12 Back Glass Replacement, Back Glass Gluing: adım 5, 3 resimden 2. iPhone 12 Back Glass Replacement, Back Glass Gluing: adım 5, 3 resimden 3.
    • Clamp a new back glass with enlarged camera holes down to the middle frame first to see if it fits.
    • Apply some adhesive evenly on the middle frame. Put the back glass in position and press it gently against the middle frame.
  6. iPhone 12 Back Glass Replacement, Back Glass Gluing: adım 6, 2 resimden 1. iPhone 12 Back Glass Replacement, Back Glass Gluing: adım 6, 2 resimden 2.
    • Press the back glass further against the middle frame with Press Clamp.
    • The adhesive has set after 10 minutes. Take the back cover out. Check if the gap is too large, if there is adhesive overflow, and if the fit is smooth.
  7. iPhone 12 Back Glass Replacement, Back Glass Gluing: adım 7, 3 resimden 1. iPhone 12 Back Glass Replacement, Back Glass Gluing: adım 7, 3 resimden 2. iPhone 12 Back Glass Replacement, Back Glass Gluing: adım 7, 3 resimden 3.
    • After the back glass gluing is finished, we install the magnet array and shield. Apply some B-7000 Adhesive on the magnet circle to adhere the magnet array to the back.
    • Please make sure that the opening of the magnet array is placed in the right position as in the picture.
    • Stick the magnet that we accidentally cut out back on and glue the alignment magnet.
    • Last but not least, assemble the phone and test the MagSafe function. The MagSafe function is normal.
Sonuç
In conclusion, MagSafe is added to the iPhone 12 series, which makes it harder to refurbish the back glass. Since the magnets are glued to the back glass, we need to detach the magnets before removing the back glass. Therefore, the iPhone 12 series currently don’t support the back glass separating without disassembling. The wireless charging coil needs to be removed first. Then we can separate the back glass by marking the back glass except for the camera area. The success rate of the foregoing method is higher. But the method can be not only demanding but also has a high requirement for the technician. We will continuously make a painstaking effort to seek the best iPhone 12 back glass refurbishing solution and even the back glass separating without disassembling. Please stay tuned.
26 farklı kişi bu kılavuzu tamamladı.
REWA
17.234 İtibar
55 adet Kılavuz yazıldı
10Kılavuz Yorumları
I have a small 3 in 1 CNC printer laser machine. How can I set the laser portion up so that I can use it to repair back glass via “marking”?
Curtis Davis - Yanıt
Jesus Christ this is getting into early days irl cyberpunk levels of tools and know how just to repair the part of your telephone covered by every case ever. Who has a laser position sensor laying around the apartment? Where do you even get one? Lol
Josh Kirtland - Yanıt
I actually just looked and the author of this post is a VERY well stocked and knowledgeable repair business supply shop that does actually sell the laser position machine used in the tutorial.
At just shy of $1700.00 I'm curious about its sale numbers though. I suppose with magsafe being the new standard buying one of these makes sense for an established shop but it's definitely now the financial fork in the road for us casual fixes.
The tools are now so expensive that filing a insurance claim or flat out buying a whole new device is the more financially responsible path.
...that being said HOLY DIVER would I love to have my own personal crazy laser tool! I haven't gotten to play with lasers since I did Lidar scans way back when the LS880 from Faro was cutting edge.
Unless this person is working for Apple directly, any repair done with a back glass that has a logo is considered counterfeit.
Stefini H. - Yanıt
Nobody cares, but thanks for being a corporate bootlicker
Stuart M -
I don't know if I can post a question here but I'm gonna try. I have used your guides quite a bit and they are always spot on. Just a thank you to all the people that post these guides I would be lost without them. My question is "Can I remove a back glass from an iPhone 12 without breaking it? I have an I12 an extra one for parts thought I might use the back glass instead of buying one. Please let me know if this is possible...Thank You
Jeffrey Miller - Yanıt
I will be right to the point - answer is "No, you can't". Regardless of what method you use, there is no way in removing it without braking. You can buy a new glass or replace the entire housing (this way its more a genuine method and hence why Apple charge that much).
Eds Repairs -
I bought the iPhone 12 replacement glass from ifixit. Camera holes are not oversized. There are no instructions. How do I get it on? Do I need to remove camera lenses?
Gerald Baker - Yanıt
If the glass you bought has camera holes that does not go over the camera lenses than you will have to remove the lenses, put the glass down and then glue the camera lenses back down. There are some videos on youtube showing this. You also might have to get new camera lenses.
To be honest, I would just buy back glass that goes over the camera lenses.
Eds Repairs -
If the back glass is broken does this make it harder to change out
Ray Vasinda - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 134
Son 7 gün: 814
Son 30 gün: 4,202
Her zaman: 272,183
