Ana içeriğe geç
iPhone 13 Pro SIM Card Replacement
Sam Omiotek
Sam Omiotek ve başka bir katkıda bulunan
En son September 1, 2023 tarihinde güncellendi
2 - 3 dakika
Kolay
Use this guide to remove or replace the SIM card in your iPhone 13 Pro. This guide is for the physical SIM card only; the embedded SIM (eSIM) is silicon-based and cannot be removed.
Neye ihtiyacın var
Parçalar
Aletler
Daha fazlasını göster…
  1. iPhone 13 Pro SIM Card Replacement, Eject the SIM card tray: adım 1, 3 resimden 1. iPhone 13 Pro SIM Card Replacement, Eject the SIM card tray: adım 1, 3 resimden 2. iPhone 13 Pro SIM Card Replacement, Eject the SIM card tray: adım 1, 3 resimden 3.
    • Insert a SIM card eject tool into the small hole in the SIM card tray, located on the volume button edge of the iPhone.
    • Press firmly to eject the tray.
  2. iPhone 13 Pro SIM Card Replacement, Remove the SIM card tray: adım 2, 3 resimden 1. iPhone 13 Pro SIM Card Replacement, Remove the SIM card tray: adım 2, 3 resimden 2. iPhone 13 Pro SIM Card Replacement, Remove the SIM card tray: adım 2, 3 resimden 3.
    • Remove the SIM card tray from the iPhone.
    • The SIM card will fall out of the tray easily.
    • When reinserting the SIM card, make sure it's in the proper orientation inside the tray.
    • A thin rubber gasket around the SIM tray provides water and dust protection. If this gasket is damaged or missing, replace the gasket or the entire SIM tray to protect your iPhone's internal components.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Sam Omiotek
83.744 İtibar
290 adet Kılavuz yazıldı
3 Yorum
I buy iPhone 13 pro but i recieved iPhone 13 pro copy phone,in this phone even I couldn't install sim card , anyone pls help me
Jafar Naikwadi - Yanıt
Anyone pls help me pls
Hello, can I swap sim card trays from iPhone 13 256 Green to iPhone 14 Pro Max 128 Black (A2894) in EUROPE? I’m guessing they have the same sim card tray shape, I don’t care about the color. Thanks
Stefano Valero - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 13
Son 7 gün: 66
Son 30 gün: 282
Her zaman: 11,746
