Ana içeriğe geç
iPhone 16 Pro 5G mmWave Antenna Replacement
Neye ihtiyacın var
  1. iPhone 16 Pro 5G mmWave Antenna Replacement, Prepare your phone for disassembly: adım 1, 2 resimden 1. iPhone 16 Pro 5G mmWave Antenna Replacement, Prepare your phone for disassembly: adım 1, 2 resimden 2.
    • Allow your phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard.
    • Unplug any cables from your phone.
    • Hold the power and either volume buttons and slide to power off your phone.
  2. iPhone 16 Pro 5G mmWave Antenna Replacement, Tape over any cracks: adım 2, 2 resimden 1. iPhone 16 Pro 5G mmWave Antenna Replacement, Tape over any cracks: adım 2, 2 resimden 2.
    • If your screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
    • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
  3. iPhone 16 Pro 5G mmWave Antenna Replacement, Mark your opening picks: adım 3, 3 resimden 1. iPhone 16 Pro 5G mmWave Antenna Replacement, Mark your opening picks: adım 3, 3 resimden 2. iPhone 16 Pro 5G mmWave Antenna Replacement, Mark your opening picks: adım 3, 3 resimden 3.
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
  4. iPhone 16 Pro 5G mmWave Antenna Replacement, Remove the pentalobe screws: adım 4, 2 resimden 1. iPhone 16 Pro 5G mmWave Antenna Replacement, Remove the pentalobe screws: adım 4, 2 resimden 2.
    • Use a P2 pentalobe screwdriver to remove the two 7.4 mm‑long screws on either side of the USB-C port.
  5. iPhone 16 Pro 5G mmWave Antenna Replacement, Heat the bottom edge: adım 5, 2 resimden 1. iPhone 16 Pro 5G mmWave Antenna Replacement, Heat the bottom edge: adım 5, 2 resimden 2.
    • Apply a heated iOpener to the bottom edge of the back glass for two minutes.
    • Alternatively, you can use a hair dryer or heat gun to heat the bottom edge of the back glass until it's hot to the touch.
    • Be careful not to heat the phone hotter than this—the battery is susceptible to heat damage.
  6. iPhone 16 Pro 5G mmWave Antenna Replacement, Insert an opening pick: adım 6, 3 resimden 1. iPhone 16 Pro 5G mmWave Antenna Replacement, Insert an opening pick: adım 6, 3 resimden 2. iPhone 16 Pro 5G mmWave Antenna Replacement, Insert an opening pick: adım 6, 3 resimden 3.
    • Apply a suction handle to the bottom edge of the back glass, above the USB-C port.
    • Pull up on the handle with a strong, steady force to create a gap between the back glass and the frame.
    • Insert the tip of an opening pick into the gap.
  7. iPhone 16 Pro 5G mmWave Antenna Replacement, Back glass information: adım 7, 2 resimden 1. iPhone 16 Pro 5G mmWave Antenna Replacement, Back glass information: adım 7, 2 resimden 2.
    • As you slice the adhesive securing the back glass in the next steps, be careful of the following areas:
    • There's a delicate cable connecting the back glass to the phone, right next to the volume up button. Don't insert your pick here to avoid slicing the cable.
    • There are multiple spring contacts around the perimeter of the phone. Be extra careful not to insert your pick deeper than suggested in each step to avoid bending these contacts.
    • If you damage the spring contacts, gently bend them back with a spudger or opening pick so they align with their gold contact pads on the back glass.
  8. iPhone 16 Pro 5G mmWave Antenna Replacement, Separate the bottom edge adhesive: adım 8, 3 resimden 1. iPhone 16 Pro 5G mmWave Antenna Replacement, Separate the bottom edge adhesive: adım 8, 3 resimden 2. iPhone 16 Pro 5G mmWave Antenna Replacement, Separate the bottom edge adhesive: adım 8, 3 resimden 3.
    • Don't insert your pick deeper than 5 mm on the bottom edge to avoid damaging the spring contact.
    • Slide your pick back and forth along the bottom edge to separate the adhesive.
    • Leave your pick inserted in the bottom right corner to prevent the adhesive from resealing.
  9. iPhone 16 Pro 5G mmWave Antenna Replacement, Heat the right edge: adım 9, 1 resimden 1.
    • Apply a heated iOpener to the right edge of the back glass for two minutes.
    • When using a hair dryer or heat gun, heat the back glass until it's hot to the touch.
  10. iPhone 16 Pro 5G mmWave Antenna Replacement, Separate the bottom right corner adhesive: adım 10, 2 resimden 1. iPhone 16 Pro 5G mmWave Antenna Replacement, Separate the bottom right corner adhesive: adım 10, 2 resimden 2.
    • Slide your pick around the bottom right corner and halfway up the right edge, or until you feel a hard stop at a clip securing the back glass.
    • Don't slice near the volume buttons to avoid damaging the wireless charging/flash cable.
    • Leave this pick inserted to prevent the adhesive from resealing.
  11. iPhone 16 Pro 5G mmWave Antenna Replacement, Heat the left edge: adım 11, 1 resimden 1.
    • Apply a heated iOpener to the left edge of the back glass for two minutes.
  12. iPhone 16 Pro 5G mmWave Antenna Replacement, Separate the left edge adhesive: adım 12, 2 resimden 1. iPhone 16 Pro 5G mmWave Antenna Replacement, Separate the left edge adhesive: adım 12, 2 resimden 2.
    • Insert a second opening pick at the bottom edge.
    • Slide the second pick around the bottom left corner and along the left edge of the screen to separate the adhesive and release the metal clips.
    • You'll hear and feel the metal clips release as you pass them.
    • Leave this pick inserted at the top left corner to prevent the adhesive from resealing.
  13. iPhone 16 Pro 5G mmWave Antenna Replacement, Heat the top edge: adım 13, 1 resimden 1.
    • Apply a heated iOpener to the top edge of the back glass, angled to include the volume buttons, for two minutes.
  14. iPhone 16 Pro 5G mmWave Antenna Replacement, Separate the top edge adhesive: adım 14, 2 resimden 1. iPhone 16 Pro 5G mmWave Antenna Replacement, Separate the top edge adhesive: adım 14, 2 resimden 2.
    • Don't insert your pick deeper than 3 mm along the top edge to avoid damaging the spring contacts.
    • Slide your opening pick across the top edge and around the top right corner to the volume up button to separate the adhesive.
    • You'll hear and feel clicks as the top two clips release.
  15. iPhone 16 Pro 5G mmWave Antenna Replacement, Swing open the back glass: adım 15, 2 resimden 1. iPhone 16 Pro 5G mmWave Antenna Replacement, Swing open the back glass: adım 15, 2 resimden 2.
    • Don't try to fully remove the back glass just yet—it's still attached with a delicate ribbon cable. Follow the next few steps to remove it safely.
    • If the back glass doesn't swing open easily, don't force it—go back around the perimeter with your pick to check for missed sections of adhesive or stuck clips.
    • You may need to lift the back glass up slightly before swinging it open to fully disengage the clips.
    • Gently swing open the back glass towards the volume buttons.
    • Support the back glass with a clean, sturdy object like a small box to avoid straining the cable.
    • Remove the opening picks.
    • Consider using polyimide tape to protect the rear camera lenses while you're working inside the phone. Don't push against the lenses to avoid damaging the delicate stabilizers.
  16. iPhone 16 Pro 5G mmWave Antenna Replacement, Disconnect the battery: adım 16, 2 resimden 1. iPhone 16 Pro 5G mmWave Antenna Replacement, Disconnect the battery: adım 16, 2 resimden 2.
    • Use a tri-point Y000 screwdriver to remove the three screws securing the lower connector cover:
    • Two 1.2 mm‑long screws
    • One 1.0 mm‑long screw
  17. iPhone 16 Pro 5G mmWave Antenna Replacement: adım 17, 3 resimden 1. iPhone 16 Pro 5G mmWave Antenna Replacement: adım 17, 3 resimden 2. iPhone 16 Pro 5G mmWave Antenna Replacement: adım 17, 3 resimden 3.
    • Use tweezers or your fingers to pick up and remove the lower connector cover.
  18. iPhone 16 Pro 5G mmWave Antenna Replacement: adım 18, 3 resimden 1. iPhone 16 Pro 5G mmWave Antenna Replacement: adım 18, 3 resimden 2. iPhone 16 Pro 5G mmWave Antenna Replacement: adım 18, 3 resimden 3.
    • Use the point of a spudger to pry up and disconnect the battery press connector.
    • During reassembly, align the connector carefully over its socket and press down with your fingertip or the flat end of a spudger—first on one side, then the other—until it clicks into place. Don't try to force the connector into place. If you're having trouble, reposition it and try again.
  19. iPhone 16 Pro 5G mmWave Antenna Replacement, Disconnect the back glass: adım 19, 2 resimden 1. iPhone 16 Pro 5G mmWave Antenna Replacement, Disconnect the back glass: adım 19, 2 resimden 2.
    • Use a tri-point Y000 screwdriver to remove the four screws securing the upper connector cover:
    • Two 1.0 mm‑long screws
    • One 1.2 mm‑long screw
    • One 1.6 mm‑long screw
  20. iPhone 16 Pro 5G mmWave Antenna Replacement: adım 20, 2 resimden 1. iPhone 16 Pro 5G mmWave Antenna Replacement: adım 20, 2 resimden 2.
    • Use tweezers or your fingers to pick up and remove the upper connector cover.
  21. iPhone 16 Pro 5G mmWave Antenna Replacement: adım 21, 2 resimden 1. iPhone 16 Pro 5G mmWave Antenna Replacement: adım 21, 2 resimden 2.
    • Use the point of a spudger to pry up and disconnect the back glass press connector.
  22. iPhone 16 Pro 5G mmWave Antenna Replacement, Remove the back glass: adım 22, 2 resimden 1. iPhone 16 Pro 5G mmWave Antenna Replacement, Remove the back glass: adım 22, 2 resimden 2.
    • Lift the back glass off the frame and remove it.
    • During reassembly:
    • This is a good point to test your repair before sealing up your phone. Temporarily reconnect the battery and back glass (before replacing the adhesive), power on your phone, and make sure it works as expected. Power it back down, disconnect the battery, and continue reassembly.
    • Use this guide to reapply adhesive and install your back glass.
  23. iPhone 16 Pro 5G mmWave Antenna Replacement, Disconnect the earpiece speaker: adım 23, 3 resimden 1. iPhone 16 Pro 5G mmWave Antenna Replacement, Disconnect the earpiece speaker: adım 23, 3 resimden 2. iPhone 16 Pro 5G mmWave Antenna Replacement, Disconnect the earpiece speaker: adım 23, 3 resimden 3.
    • The 5G mmWave antenna is only in United States and Puerto Rico iPhone 16 Pros (model A3083). For all other models, skip the next four steps.
    • Use the point of a spudger to pry up and disconnect the earpiece speaker and 5G mmWave antenna press connectors, located on the top right corner of the logic board.
  24. iPhone 16 Pro 5G mmWave Antenna Replacement, Remove the earpiece speaker: adım 24, 1 resimden 1.
    • Use a Phillips screwdriver to remove the six screws securing the earpiece speaker:
    • Three 1.2 mm‑long screws
    • Two 1.8 mm‑long screws
    • One 1.7 mm‑long screw
  25. iPhone 16 Pro 5G mmWave Antenna Replacement: adım 25, 3 resimden 1. iPhone 16 Pro 5G mmWave Antenna Replacement: adım 25, 3 resimden 2. iPhone 16 Pro 5G mmWave Antenna Replacement: adım 25, 3 resimden 3.
    • Insert the point of a spudger in the bottom-right corner of the earpiece speaker and pry it up to remove it.
    • You may feel some resistance near the top edge, where the speaker gasket seals against the frame. Pull the speaker out gently to release the seal.
    • During reassembly, insert the top edge of the earpiece speaker into its cutout at a downward angle before pressing it flat to the frame.
    • You may have to lift the front camera assembly slightly to get the earpiece speaker in its cutout. Insert the antenna and earpiece speaker cables to the right of the front camera cables, then gently press the front camera into its cutout before pushing its cables flush with the rear cameras.
  26. iPhone 16 Pro 5G mmWave Antenna Replacement, Remove the stretch release adhesive: adım 26, 3 resimden 1. iPhone 16 Pro 5G mmWave Antenna Replacement, Remove the stretch release adhesive: adım 26, 3 resimden 2. iPhone 16 Pro 5G mmWave Antenna Replacement, Remove the stretch release adhesive: adım 26, 3 resimden 3.
    • Use your tweezers to grab the stretch release adhesive pull tab, located on the edge of the 5G mmWave antenna.
    • Use your tweezers to pull the stretch release adhesive strip out slowly and steadily at a low angle. Give it plenty of time to stretch and un-stick from under the antenna.
    • For additional grip, you can twist the adhesive around the tip of the tweezers while you pull.
    • If the adhesive strip breaks off, try to retrieve it with your tweezers and continue pulling.
  27. iPhone 16 Pro 5G mmWave Antenna Replacement, Remove the antenna: adım 27, 2 resimden 1. iPhone 16 Pro 5G mmWave Antenna Replacement, Remove the antenna: adım 27, 2 resimden 2.
    Bu adımda kullanılan alet:
    Tesa 61395 Tape
    $2.99
    • Lift the 5G mmWave antenna off the earpiece speaker and remove it.
    • Use tweezers or a spudger to remove the old adhesive from the top of the earpiece speaker and back of the antenna.
    • If your replacement part doesn't include new adhesive, use a 4 mm x 16 mm strip and pre-cut square of thin, double-sided tape to secure the antenna to the earpiece speaker.
    • Press the antenna onto the earpiece speaker to adhere it.
Sonuç
To reassemble your iPhone, follow these instructions in reverse order.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 16 Pro Answers Community for help.
Nick Schultz
19.526 İtibar
114 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
121 Üyeler
19.674 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 19
Son 7 gün: 100
Son 30 gün: 323
Her zaman: 388
