Giriş
Prerequisite guide to remove the front camera assembly in an iPhone 16 Pro.
Neye ihtiyacın var
Unplug any cables from the phone.
Hold the power and either volume buttons and slide to power off the phone.
If the screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
Measure 3 mm from the tip and mark the opening pick with a permanent marker.
Use a P2 pentalobe screwdriver to remove the two 7.4 mm‑long screws on either side of the USB-C port.
Use the point of a spudger to pry up and disconnect the earpiece speaker and 5G mmWave antenna press connectors, located on the top right corner of the logic board.
Use the point of a spudger to pry up and disconnect the two front camera assembly press connectors underneath the previous two.
Use a spudger or your fingers to pick up the front camera assembly and remove it from the phone.
To reassemble your iPhone, follow this guide in reverse order.
After your repair, calibrate a genuine replacement front camera assembly using Apple's Repair Assistant. Navigate to Settings → General → About → Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 16 Pro Answers Community for help.
