Ana içeriğe geç
iPhone 16 Pro Loudspeaker Replacement
Neye ihtiyacın var
  1. iPhone 16 Pro Loudspeaker Replacement, Prepare your phone for disassembly: adım 1, 2 resimden 1. iPhone 16 Pro Loudspeaker Replacement, Prepare your phone for disassembly: adım 1, 2 resimden 2.
    • Allow your phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard.
    • Unplug any cables from your phone.
    • Hold the power and either volume buttons and slide to power off your phone.
  2. iPhone 16 Pro Loudspeaker Replacement, Tape over any cracks: adım 2, 2 resimden 1. iPhone 16 Pro Loudspeaker Replacement, Tape over any cracks: adım 2, 2 resimden 2.
    • If your screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
    • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
  3. iPhone 16 Pro Loudspeaker Replacement, Mark your opening picks: adım 3, 3 resimden 1. iPhone 16 Pro Loudspeaker Replacement, Mark your opening picks: adım 3, 3 resimden 2. iPhone 16 Pro Loudspeaker Replacement, Mark your opening picks: adım 3, 3 resimden 3.
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
  4. iPhone 16 Pro Loudspeaker Replacement, Remove the pentalobe screws: adım 4, 2 resimden 1. iPhone 16 Pro Loudspeaker Replacement, Remove the pentalobe screws: adım 4, 2 resimden 2.
    • Use a P2 pentalobe screwdriver to remove the two 7.4 mm‑long screws on either side of the USB-C port.
  5. iPhone 16 Pro Loudspeaker Replacement, Heat the bottom edge: adım 5, 2 resimden 1. iPhone 16 Pro Loudspeaker Replacement, Heat the bottom edge: adım 5, 2 resimden 2.
    • Apply a heated iOpener to the bottom edge of the back glass for two minutes.
    • Alternatively, you can use a hair dryer or heat gun to heat the bottom edge of the back glass until it's hot to the touch.
    • Be careful not to heat the phone hotter than this—the battery is susceptible to heat damage.
  6. iPhone 16 Pro Loudspeaker Replacement, Insert an opening pick: adım 6, 3 resimden 1. iPhone 16 Pro Loudspeaker Replacement, Insert an opening pick: adım 6, 3 resimden 2. iPhone 16 Pro Loudspeaker Replacement, Insert an opening pick: adım 6, 3 resimden 3.
    • Apply a suction handle to the bottom edge of the back glass, above the USB-C port.
    • Pull up on the handle with a strong, steady force to create a gap between the back glass and the frame.
    • Insert the tip of an opening pick into the gap.
  7. iPhone 16 Pro Loudspeaker Replacement, Back glass information: adım 7, 2 resimden 1. iPhone 16 Pro Loudspeaker Replacement, Back glass information: adım 7, 2 resimden 2.
    • As you slice the adhesive securing the back glass in the next steps, be careful of the following areas:
    • There's a delicate cable connecting the back glass to the phone, right next to the volume up button. Don't insert your pick here to avoid slicing the cable.
    • There are multiple spring contacts around the perimeter of the phone. Be extra careful not to insert your pick deeper than suggested in each step to avoid bending these contacts.
    • If you damage the spring contacts, gently bend them back with a spudger or opening pick so they align with their gold contact pads on the back glass.
  8. iPhone 16 Pro Loudspeaker Replacement, Separate the bottom edge adhesive: adım 8, 3 resimden 1. iPhone 16 Pro Loudspeaker Replacement, Separate the bottom edge adhesive: adım 8, 3 resimden 2. iPhone 16 Pro Loudspeaker Replacement, Separate the bottom edge adhesive: adım 8, 3 resimden 3.
    • Don't insert your pick deeper than 5 mm on the bottom edge to avoid damaging the spring contact.
    • Slide your pick back and forth along the bottom edge to separate the adhesive.
    • Leave your pick inserted in the bottom right corner to prevent the adhesive from resealing.
  9. iPhone 16 Pro Loudspeaker Replacement, Heat the right edge: adım 9, 1 resimden 1.
    • Apply a heated iOpener to the right edge of the back glass for two minutes.
    • When using a hair dryer or heat gun, heat the back glass until it's hot to the touch.
  10. iPhone 16 Pro Loudspeaker Replacement, Separate the bottom right corner adhesive: adım 10, 2 resimden 1. iPhone 16 Pro Loudspeaker Replacement, Separate the bottom right corner adhesive: adım 10, 2 resimden 2.
    • Slide your pick around the bottom right corner and halfway up the right edge, or until you feel a hard stop at a clip securing the back glass.
    • Don't slice near the volume buttons to avoid damaging the wireless charging/flash cable.
    • Leave this pick inserted to prevent the adhesive from resealing.
  11. iPhone 16 Pro Loudspeaker Replacement, Heat the left edge: adım 11, 1 resimden 1.
    • Apply a heated iOpener to the left edge of the back glass for two minutes.
  12. iPhone 16 Pro Loudspeaker Replacement, Separate the left edge adhesive: adım 12, 2 resimden 1. iPhone 16 Pro Loudspeaker Replacement, Separate the left edge adhesive: adım 12, 2 resimden 2.
    • Insert a second opening pick at the bottom edge.
    • Slide the second pick around the bottom left corner and along the left edge of the screen to separate the adhesive and release the metal clips.
    • You'll hear and feel the metal clips release as you pass them.
    • Leave this pick inserted at the top left corner to prevent the adhesive from resealing.
  13. iPhone 16 Pro Loudspeaker Replacement, Heat the top edge: adım 13, 1 resimden 1.
    • Apply a heated iOpener to the top edge of the back glass, angled to include the volume buttons, for two minutes.
  14. iPhone 16 Pro Loudspeaker Replacement, Separate the top edge adhesive: adım 14, 2 resimden 1. iPhone 16 Pro Loudspeaker Replacement, Separate the top edge adhesive: adım 14, 2 resimden 2.
    • Don't insert your pick deeper than 3 mm along the top edge to avoid damaging the spring contacts.
    • Slide your opening pick across the top edge and around the top right corner to the volume up button to separate the adhesive.
    • You'll hear and feel clicks as the top two clips release.
  15. iPhone 16 Pro Loudspeaker Replacement, Swing open the back glass: adım 15, 2 resimden 1. iPhone 16 Pro Loudspeaker Replacement, Swing open the back glass: adım 15, 2 resimden 2.
    • Don't try to fully remove the back glass just yet—it's still attached with a delicate ribbon cable. Follow the next few steps to remove it safely.
    • If the back glass doesn't swing open easily, don't force it—go back around the perimeter with your pick to check for missed sections of adhesive or stuck clips.
    • You may need to lift the back glass up slightly before swinging it open to fully disengage the clips.
    • Gently swing open the back glass towards the volume buttons.
    • Support the back glass with a clean, sturdy object like a small box to avoid straining the cable.
    • Remove the opening picks.
    • Consider using polyimide tape to protect the rear camera lenses while you're working inside the phone. Don't push against the lenses to avoid damaging the delicate stabilizers.
  16. iPhone 16 Pro Loudspeaker Replacement, Disconnect the battery: adım 16, 2 resimden 1. iPhone 16 Pro Loudspeaker Replacement, Disconnect the battery: adım 16, 2 resimden 2.
    • Use a tri-point Y000 screwdriver to remove the three screws securing the lower connector cover:
    • Two 1.2 mm‑long screws
    • One 1.0 mm‑long screw
  17. iPhone 16 Pro Loudspeaker Replacement: adım 17, 3 resimden 1. iPhone 16 Pro Loudspeaker Replacement: adım 17, 3 resimden 2. iPhone 16 Pro Loudspeaker Replacement: adım 17, 3 resimden 3.
    • Use tweezers or your fingers to pick up and remove the lower connector cover.
  18. iPhone 16 Pro Loudspeaker Replacement: adım 18, 3 resimden 1. iPhone 16 Pro Loudspeaker Replacement: adım 18, 3 resimden 2. iPhone 16 Pro Loudspeaker Replacement: adım 18, 3 resimden 3.
    • Use the point of a spudger to pry up and disconnect the battery press connector.
    • During reassembly, align the connector carefully over its socket and press down with your fingertip or the flat end of a spudger—first on one side, then the other—until it clicks into place. Don't try to force the connector into place. If you're having trouble, reposition it and try again.
  19. iPhone 16 Pro Loudspeaker Replacement, Disconnect the back glass: adım 19, 2 resimden 1. iPhone 16 Pro Loudspeaker Replacement, Disconnect the back glass: adım 19, 2 resimden 2.
    • Use a tri-point Y000 screwdriver to remove the four screws securing the upper connector cover:
    • Two 1.0 mm‑long screws
    • One 1.2 mm‑long screw
    • One 1.6 mm‑long screw
  20. iPhone 16 Pro Loudspeaker Replacement: adım 20, 2 resimden 1. iPhone 16 Pro Loudspeaker Replacement: adım 20, 2 resimden 2.
    • Use tweezers or your fingers to pick up and remove the upper connector cover.
  21. iPhone 16 Pro Loudspeaker Replacement: adım 21, 2 resimden 1. iPhone 16 Pro Loudspeaker Replacement: adım 21, 2 resimden 2.
    • Use the point of a spudger to pry up and disconnect the back glass press connector.
  22. iPhone 16 Pro Loudspeaker Replacement, Remove the back glass: adım 22, 2 resimden 1. iPhone 16 Pro Loudspeaker Replacement, Remove the back glass: adım 22, 2 resimden 2.
    • Lift the back glass off the frame and remove it.
    • During reassembly:
    • This is a good point to test your repair before sealing up your phone. Temporarily reconnect the battery and back glass (before replacing the adhesive), power on your phone, and make sure it works as expected. Power it back down, disconnect the battery, and continue reassembly.
    • Use this guide to reapply adhesive and install your back glass.
  23. iPhone 16 Pro Loudspeaker Replacement, Remove the Taptic Engine cover: adım 23, 2 resimden 1. iPhone 16 Pro Loudspeaker Replacement, Remove the Taptic Engine cover: adım 23, 2 resimden 2.
    • Use a Phillips screwdriver to remove the three screws securing the Taptic Engine cover:
    • One 3.0 mm‑long screw
    • Two 1.7 mm‑long screws
  24. iPhone 16 Pro Loudspeaker Replacement: adım 24, 3 resimden 1. iPhone 16 Pro Loudspeaker Replacement: adım 24, 3 resimden 2. iPhone 16 Pro Loudspeaker Replacement: adım 24, 3 resimden 3.
    • Use tweezers or your fingers to lift the top edge of the Taptic Engine cover.
    • Once the bottom edge unlatches from the frame, remove the Taptic Engine cover.
    • During reassembly, make sure the bottom edge of the cover latches properly to the frame.
  25. iPhone 16 Pro Loudspeaker Replacement, Disconnect the lower assembly cable: adım 25, 2 resimden 1. iPhone 16 Pro Loudspeaker Replacement, Disconnect the lower assembly cable: adım 25, 2 resimden 2.
    • Use the point of a spudger to pry up and disconnect the lower assembly cable press connector from the logic board.
  26. iPhone 16 Pro Loudspeaker Replacement: adım 26, 3 resimden 1. iPhone 16 Pro Loudspeaker Replacement: adım 26, 3 resimden 2. iPhone 16 Pro Loudspeaker Replacement: adım 26, 3 resimden 3.
    • Use the point of a spudger to pry up and disconnect the two press connectors near the bottom right edge of the frame.
  27. iPhone 16 Pro Loudspeaker Replacement: adım 27, 2 resimden 1. iPhone 16 Pro Loudspeaker Replacement: adım 27, 2 resimden 2.
    • Use a tri-point Y000 screwdriver to remove the 1.0 mm‑long screw securing the lower assembly cable.
  28. iPhone 16 Pro Loudspeaker Replacement: adım 28, 2 resimden 1. iPhone 16 Pro Loudspeaker Replacement: adım 28, 2 resimden 2.
    • Use an iOpener or hair dryer to heat up the lower assembly cable section on top of the Taptic Engine until it's hot to the touch.
  29. iPhone 16 Pro Loudspeaker Replacement: adım 29, 2 resimden 1. iPhone 16 Pro Loudspeaker Replacement: adım 29, 2 resimden 2.
    • Slide an opening pick under the lower assembly cable to separate it from the Taptic Engine.
    • Carefully bend the cable out of the way so you can access the Taptic Engine.
  30. iPhone 16 Pro Loudspeaker Replacement, Remove the Taptic Engine: adım 30, 2 resimden 1. iPhone 16 Pro Loudspeaker Replacement, Remove the Taptic Engine: adım 30, 2 resimden 2.
    • Use a Phillips screwdriver to remove the 1.9 mm‑long screw securing the Taptic Engine.
  31. iPhone 16 Pro Loudspeaker Replacement: adım 31, 2 resimden 1. iPhone 16 Pro Loudspeaker Replacement: adım 31, 2 resimden 2.
    • Slide the tip of an opening pick along the top edge of the Taptic Engine to separate the plastic buffer strip adhered to it.
  32. iPhone 16 Pro Loudspeaker Replacement: adım 32, 3 resimden 1. iPhone 16 Pro Loudspeaker Replacement: adım 32, 3 resimden 2. iPhone 16 Pro Loudspeaker Replacement: adım 32, 3 resimden 3.
    • Use the point of a spudger to pry up the Taptic Engine from its top-right corner.
    • Be careful not to pry against the battery.
    • Remove the Taptic Engine.
  33. iPhone 16 Pro Loudspeaker Replacement, Remove the loudspeaker: adım 33, 2 resimden 1. iPhone 16 Pro Loudspeaker Replacement, Remove the loudspeaker: adım 33, 2 resimden 2.
    • Remove the four screws securing the loudspeaker:
    • Two 1.6 mm‑long Phillips screws
    • One 2.0 mm‑long Phillips screw
    • One 1.3 mm‑long tri-point Y000 screw
  34. iPhone 16 Pro Loudspeaker Replacement: adım 34, 3 resimden 1. iPhone 16 Pro Loudspeaker Replacement: adım 34, 3 resimden 2. iPhone 16 Pro Loudspeaker Replacement: adım 34, 3 resimden 3.
    • Insert the point of a spudger underneath the loudspeaker's bottom-right screw hole.
    • Pry up and remove the loudspeaker.
Sonuç
To reassemble your iPhone, follow this guide to reapply adhesive and install your back glass.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 16 Pro Answers community for help.
Nick Schultz
19.526 İtibar
114 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
121 Üyeler
19.674 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 24
Son 30 gün: 74
Her zaman: 128
