Ana içeriğe geç
iPhone 16 Pro Screen Removal
Salt Önkoşul
Bu sadece bir ön koşul kılavuzudur! Bu kılavuz başka bir prosedürün parçasıdır ve tek başına kullanılması amaçlanmamıştır.
Neye ihtiyacın var
  1. iPhone 16 Pro Screen Removal, Prepare the phone for disassembly: adım 1, 2 resimden 1. iPhone 16 Pro Screen Removal, Prepare the phone for disassembly: adım 1, 2 resimden 2.
    • Allow the phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard.
    • Unplug any cables from the phone.
    • Hold the power and either volume buttons and slide to power off the phone.
  2. iPhone 16 Pro Screen Removal, Tape over any cracks: adım 2, 2 resimden 1. iPhone 16 Pro Screen Removal, Tape over any cracks: adım 2, 2 resimden 2.
    • If the screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
    • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
  3. iPhone 16 Pro Screen Removal, Mark your opening picks: adım 3, 3 resimden 1. iPhone 16 Pro Screen Removal, Mark your opening picks: adım 3, 3 resimden 2. iPhone 16 Pro Screen Removal, Mark your opening picks: adım 3, 3 resimden 3.
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
  4. iPhone 16 Pro Screen Removal, Remove the pentalobe screws: adım 4, 2 resimden 1. iPhone 16 Pro Screen Removal, Remove the pentalobe screws: adım 4, 2 resimden 2.
    • Use a P2 pentalobe screwdriver to remove the two 7.4 mm‑long screws on either side of the USB-C port.
  5. iPhone 16 Pro Screen Removal, Create a gap with a suction handle: adım 5, 1 resimden 1.
    Bu adımda kullanılan alet:
    iOpener
    $14.99
    • The next two steps show how to create an initial gap using a suction handle.
    • Use a hair dryer or heat gun to heat the bottom edge of the screen until it's hot to the touch.
    • You can also use an iOpener to heat the screen. Follow these instructions to heat and apply the iOpener properly.
  6. iPhone 16 Pro Screen Removal: adım 6, 3 resimden 1. iPhone 16 Pro Screen Removal: adım 6, 3 resimden 2. iPhone 16 Pro Screen Removal: adım 6, 3 resimden 3.
    • Apply a suction handle to the bottom edge of the screen.
    • Pull up on the handle with a strong, steady force to create a gap between the screen and the frame.
    • If you can't create a gap, apply more heat to the edge and try again.
    • Insert the tip of an opening pick into the gap.
  7. iPhone 16 Pro Screen Removal, Screen information: adım 7, 1 resimden 1.
    • As you slice the adhesive securing the screen in the following steps, don't insert your pick deeper than 3 mm to avoid damaging the following areas:
    • Two delicate cables connecting the screen to the iPhone—one just above the Action button and the other about halfway along the left edge of the iPhone
    • Multiple spring contacts around the perimeter of the iPhone
  8. iPhone 16 Pro Screen Removal, Slice the bottom edge adhesive: adım 8, 3 resimden 1. iPhone 16 Pro Screen Removal, Slice the bottom edge adhesive: adım 8, 3 resimden 2. iPhone 16 Pro Screen Removal, Slice the bottom edge adhesive: adım 8, 3 resimden 3.
    • Slide the opening pick along the bottom edge to release the adhesive.
    • Don't insert the pick deeper than 3 mm to avoid damaging the spring contacts.
    • If the adhesive feels difficult to slice, reheat the edge for a minute.
    • Leave the opening pick in the bottom-left corner to prevent the adhesive from resealing.
  9. iPhone 16 Pro Screen Removal, Heat the left edge: adım 9, 1 resimden 1.
    • Use a hair dryer or heat gun to heat the left edge of the screen until it's hot to the touch.
  10. iPhone 16 Pro Screen Removal, Separate the left adhesive: adım 10, 2 resimden 1. iPhone 16 Pro Screen Removal, Separate the left adhesive: adım 10, 2 resimden 2.
    • Don't insert your pick deeper than 3 mm to avoid damaging the spring contacts and cables.
    • Insert a second opening pick in the bottom-left corner, close to the existing pick.
    • Slide the opening pick along the left edge of the screen to separate the adhesive and release the metal clips.
    • You'll hear and feel the metal clips release as you pass them.
    • Leave the opening pick in the top-left corner to prevent the adhesive from resealing.
  11. iPhone 16 Pro Screen Removal, Separate the remaining adhesives: adım 11, 3 resimden 1. iPhone 16 Pro Screen Removal, Separate the remaining adhesives: adım 11, 3 resimden 2. iPhone 16 Pro Screen Removal, Separate the remaining adhesives: adım 11, 3 resimden 3.
    • Repeat the heating and slicing procedure along the remaining screen edges.
  12. iPhone 16 Pro Screen Removal, Swing open the screen: adım 12, 3 resimden 1. iPhone 16 Pro Screen Removal, Swing open the screen: adım 12, 3 resimden 2. iPhone 16 Pro Screen Removal, Swing open the screen: adım 12, 3 resimden 3.
    • At this point, the screen should be free from the frame. If the screen feels stuck, go back around the perimeter with your pick and carefully check for missed sections of adhesive or stuck clips.
    • Carefully lift the screen upwards until the clips along the long edges clear the frame.
    • Swing open the screen over the left edge of the iPhone and lay it flat on your work surface.
  13. iPhone 16 Pro Screen Removal, Remove the connector covers: adım 13, 1 resimden 1.
    • Use a tri-point Y000 driver to remove the two 1.3 mm‑long screws securing the front sensor and display connector covers.
  14. iPhone 16 Pro Screen Removal: adım 14, 3 resimden 1. iPhone 16 Pro Screen Removal: adım 14, 3 resimden 2. iPhone 16 Pro Screen Removal: adım 14, 3 resimden 3.
    • Use tweezers to grasp the front sensor connector cover near the screw hole.
    • Lift and remove the cover.
  15. iPhone 16 Pro Screen Removal: adım 15, 3 resimden 1. iPhone 16 Pro Screen Removal: adım 15, 3 resimden 2. iPhone 16 Pro Screen Removal: adım 15, 3 resimden 3.
    • Repeat this process for the other cover.
  16. iPhone 16 Pro Screen Removal, Disconnect the screen: adım 16, 2 resimden 1. iPhone 16 Pro Screen Removal, Disconnect the screen: adım 16, 2 resimden 2.
    • Use the tip of a spudger to pry up and disconnect the display press connector.
  17. iPhone 16 Pro Screen Removal: adım 17, 2 resimden 1. iPhone 16 Pro Screen Removal: adım 17, 2 resimden 2.
    • Repeat this process for the front sensor press connector.
  18. iPhone 16 Pro Screen Removal, Remove the screen: adım 18, 1 resimden 1.
    • Remove the screen.
Sonuç
To reassemble your iPhone, follow these instructions in reverse order.
After your repair, calibrate a genuine replacement screen using Apple's Repair Assistant. Navigate to Settings General About Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 16 Pro Answers community for help.
Bir başkası bu kılavuzu tamamladı.
Nick Schultz
39.338 İtibar
226 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
23.994 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 15
Her zaman: 854
