Ana içeriğe geç
iPhone 4 Speaker Enclosure Assembly Replacement
Walter Galan
Walter Galan ve 3 diğer katkıda bulunanlar
En son July 16, 2019 tarihinde güncellendi
Tahmin yok
Orta
Salt Önkoşul
Bu kılavuz yalnızca diğer kılavuzlar için bir ön koşul olarak kullanılmak üzere tasarlanmıştır. Tek başına eksiktir.
Prereq with logic board still in.
Neye ihtiyacın var
Aletler
  1. iPhone 4 Speaker Enclosure Assembly Replacement, Speaker Enclosure Assembly: adım 1, 2 resimden 1. iPhone 4 Speaker Enclosure Assembly Replacement, Speaker Enclosure Assembly: adım 1, 2 resimden 2.
    • Remove the following two screws:
    • One 1.2 mm Phillips
    • One 1.6 mm Phillips
    • Remove the thin steel dock connector cable cover from the iPhone.
    • Before reassembly, be sure to clean all metal-to-metal contact points on the dock connector cable cover with a de-greaser such as windex. The oils on your fingers have the potential to cause wireless interference issues.
  2. iPhone 4 Speaker Enclosure Assembly Replacement: adım 2, 2 resimden 1. iPhone 4 Speaker Enclosure Assembly Replacement: adım 2, 2 resimden 2.
    • Use a plastic opening tool to gently pry the dock cable connector up off the logic board from both short ends of the connector.
  3. iPhone 4 Speaker Enclosure Assembly Replacement: adım 3, 2 resimden 1. iPhone 4 Speaker Enclosure Assembly Replacement: adım 3, 2 resimden 2.
    • Carefully peel the dock ribbon cable off the logic board and the lower speaker enclosure.
    • Do not use excessive force to peel the dock ribbon cable off the logic board. Doing so may tear the cable.
  4. iPhone 4 Speaker Enclosure Assembly Replacement: adım 4, 1 resimden 1.
    • Use a plastic opening tool to pry the lower antenna connector up off its socket on the logic board.
  5. iPhone 4 Speaker Enclosure Assembly Replacement: adım 5, 1 resimden 1.
    • Remove the following screws securing the speaker enclosure assembly to the outer case:
    • One 1.9 mm Phillips screw
    • One 2.4 mm Phillips screw
  6. iPhone 4 Speaker Enclosure Assembly Replacement: adım 6, 3 resimden 1. iPhone 4 Speaker Enclosure Assembly Replacement: adım 6, 3 resimden 2. iPhone 4 Speaker Enclosure Assembly Replacement: adım 6, 3 resimden 3.
    • Use a plastic opening tool to lift the speaker enclosure assembly out of the case, being sure not to damage the EMI fingers on the attached Wi-Fi antenna.
    • Remove the speaker enclosure assembly.
    • Before reinstalling the speaker enclosure assembly's screws, be sure the Wi-Fi grounding fingers are installed below the lip in the iPhone's metal case as seen in the third picture.
    • Before reassembly, be sure to clean all metal-to-metal contact points between the grounding fingers of the Wi-Fi antenna and the case of the iPhone with a de-greaser such as windex or isopropyl alcohol. The oils on your fingers have the potential to cause wireless interference issues.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 73
