Ana içeriğe geç
iPhone 5 Logic Board Replacement
Neye ihtiyacın var
  1. iPhone 5 Logic Board Replacement, Taping the display glass: adım 1, 3 resimden 1. iPhone 5 Logic Board Replacement, Taping the display glass: adım 1, 3 resimden 2. iPhone 5 Logic Board Replacement, Taping the display glass: adım 1, 3 resimden 3.
    • Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    FixBot'a Sor
    Yorum Ekle
  2. iPhone 5 Logic Board Replacement, Remove the Pentalobe screws: adım 2, 1 resimden 1.
    • Before you proceed, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.6 mm Pentalobe screws next to the Lightning connector.
    FixBot'a Sor
    Yorum Ekle
  3. iPhone 5 Logic Board Replacement, How to prevent display separation: adım 3, 3 resimden 1. iPhone 5 Logic Board Replacement, How to prevent display separation: adım 3, 3 resimden 2. iPhone 5 Logic Board Replacement, How to prevent display separation: adım 3, 3 resimden 3.
    • In the following steps you will be pulling the display up out of the phone body. The display is composed of a glass screen and a plastic bezel with metal clips.
    • Regardless of the tool you use, you need to be sure you pull up the entire display.
    • If the glass begins to separate from the plastic, as shown in the first image, slide a plastic opening tool between the plastic frame and the metal phone body to pry the metal clips out of the case.
    • If you are reassembling a phone with a separated display bezel, you may want to place a thin strip of adhesive between the plastic bezel and the glass to keep the phone closed.
    FixBot'a Sor
    Yorum Ekle
  4. iPhone 5 Logic Board Replacement, Anti-Clamp instructions: adım 4, 3 resimden 1. iPhone 5 Logic Board Replacement, Anti-Clamp instructions: adım 4, 3 resimden 2. iPhone 5 Logic Board Replacement, Anti-Clamp instructions: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    Clampy - Anti-Clamp
    $24.95
    • The next two steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down two steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
    FixBot'a Sor
    Yorum Ekle
  5. iPhone 5 Logic Board Replacement: adım 5, 3 resimden 1. iPhone 5 Logic Board Replacement: adım 5, 3 resimden 2. iPhone 5 Logic Board Replacement: adım 5, 3 resimden 3.
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next two steps.
    FixBot'a Sor
    Yorum Ekle
  6. iPhone 5 Logic Board Replacement, Manual Opening Procedure: adım 6, 1 resimden 1.
    • Press a suction cup onto the screen, just above the home button.
    • Be sure the cup is completely on the screen to get a tight seal.
    • If you're opening an iPhone with cracked glass, neatly lay a couple strips of packing tape across the front and squeeze out as many bubbles as you can. This will give the suction cup a surface to grab, and minimize the spread of broken glass.
    FixBot'a Sor
    Yorum Ekle
  7. iPhone 5 Logic Board Replacement, Start lifting the front panel assembly: adım 7, 1 resimden 1.
    • Make sure the suction cup is firmly attached to the front panel assembly.
    • While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the front panel assembly from the rear case.
    • Take your time and apply firm, constant force. The screen is a much tighter fit than most devices.
    • With a plastic opening tool, begin to gently pry the rear case down, away from the screen, while you pull up with the suction cup.
    • There are several clips attaching the front panel assembly to the rear case, so you may need to use a combination of the suction cup and plastic opening tool to free the front panel assembly.
    FixBot'a Sor
    Yorum Ekle
  8. iPhone 5 Logic Board Replacement, Detaching the front panel side clips: adım 8, 1 resimden 1.
    • Continue to pry up around the sides of the front panel assembly, detaching the clips along the left and right side.
    FixBot'a Sor
    Yorum Ekle
  9. iPhone 5 Logic Board Replacement, Opening up the phone: adım 9, 3 resimden 1. iPhone 5 Logic Board Replacement, Opening up the phone: adım 9, 3 resimden 2. iPhone 5 Logic Board Replacement, Opening up the phone: adım 9, 3 resimden 3.
    • Do not try to completely remove the front panel assembly from the rear case, as there are several ribbon cables still attached at the top of the iPhone.
    • Once the clips have been released on the bottom and sides of the front panel assembly, pull the bottom of the assembly away from the rear case.
    • Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
    • Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
    FixBot'a Sor
    Yorum Ekle
  10. iPhone 5 Logic Board Replacement, Removing the battery connector bracket screws: adım 10, 1 resimden 1.
    • Remove the following two screws securing the metal battery connector bracket to the logic board:
    • One 1.8 mm Phillips screw
    • One 1.6 mm Phillips screw
    FixBot'a Sor
    Yorum Ekle
  11. iPhone 5 Logic Board Replacement, Removing the battery connector bracket: adım 11, 1 resimden 1.
    • Remove the metal battery connector bracket from the iPhone.
    FixBot'a Sor
    Yorum Ekle
  12. iPhone 5 Logic Board Replacement, Disconnecting the battery connector: adım 12, 1 resimden 1.
    • Use a plastic opening tool to gently pry the battery connector up from its socket on the logic board.
    • Be careful not to dislodge the small surface-mounted components surrounding the socket.
    • Be very careful to only pry up on the battery connector itself and not the socket on the logic board. If you pry up on the logic board socket or the board itself, you may destroy the socket or damage nearby components on the board.
    FixBot'a Sor
    Yorum Ekle
  13. iPhone 5 Logic Board Replacement, Removing the front panel assembly cable bracket screws: adım 13, 1 resimden 1.
    • Remove the following screws securing the front panel assembly cable bracket to the logic board:
    • Two 1.2 mm Phillips screws
    • This screw tends to not be attracted to a magnetized screwdriver. Take care not to lose it when removing, and make sure it gets back into the right place—a magnetized screw may interfere with the compass.
    FixBot'a Sor
    Yorum Ekle
  14. iPhone 5 Logic Board Replacement, Removing the front panel assembly cable bracket: adım 14, 2 resimden 1. iPhone 5 Logic Board Replacement, Removing the front panel assembly cable bracket: adım 14, 2 resimden 2.
    • Lift the display cable bracket toward the battery to unhook it, and remove it from the iPhone.
    • During reassembly, clip the left-hand hooks under the logic board and lower the bracket towards the outside of the phone.
    FixBot'a Sor
    Yorum Ekle
  15. iPhone 5 Logic Board Replacement, Disconnecting the front panel assembly cables: adım 15, 3 resimden 1. iPhone 5 Logic Board Replacement, Disconnecting the front panel assembly cables: adım 15, 3 resimden 2. iPhone 5 Logic Board Replacement, Disconnecting the front panel assembly cables: adım 15, 3 resimden 3.
    • Make sure the battery is disconnected before you disconnect or reconnect the cables in this step.
    • Use a plastic opening tool or a fingernail to disconnect the three front panel assembly cables:
    • Front-facing camera and sensor cable
    • LCD cable
    • Digitizer cable
    • When reassembling your phone, the LCD cable may pop off the connector. This can cause white lines, or nothing at all to appear when powering your phone back on. If that happens, simply reconnect the cable and power cycle your phone. The best way to power cycle your phone is to disconnect and reconnect the battery.
    FixBot'a Sor
    Yorum Ekle
  16. iPhone 5 Logic Board Replacement, Separating front panel assembly and rear case: adım 16, 1 resimden 1.
    • Remove the front panel assembly from the rear case.
    FixBot'a Sor
    Yorum Ekle
  17. iPhone 5 Logic Board Replacement, Lifting the battery: adım 17, 1 resimden 1.
    • Use the exposed clear plastic pull tab to peel the battery off the adhesive securing it to the iPhone.
    • If you are having trouble peeling the battery up or if the tab breaks, apply a few drops of high concentration (over 90%) isopropyl alcohol under the edge of the battery.
    • Wait about one minute for the alcohol solution to weaken the adhesive. Use an opening tool to gently lift the battery by its edge.
    • Don't try to forcefully lever the battery out. If needed, apply a few more drops of alcohol to further weaken the adhesive. Never deform or puncture the battery with your pry tool.
    • If there's any alcohol solution remaining in the phone, carefully wipe it off or allow it to air dry before installing your new battery.
    • If you still have trouble peeling the battery up, use an iOpener or hair dryer to heat the rear case of the iPhone and soften the adhesive.
    • Overheating the iPhone may ignite the battery.
    FixBot'a Sor
    Yorum Ekle
  18. iPhone 5 Logic Board Replacement, Prying up the battery: adım 18, 2 resimden 1. iPhone 5 Logic Board Replacement, Prying up the battery: adım 18, 2 resimden 2.
    • Use the plastic opening tool to gently pry the battery up, only at the outside edge of the phone. Prying anywhere else, especially near the logic board, may result in damage to the logic board.
    • If the battery doesn't pry easily out of the case, apply a few more drops of isopropyl alcohol.
    • Pry gently and evenly to avoid deforming the battery. A bent battery can be a fire hazard.
    • Do not pry at the top portion of the battery, you risk severing the volume control cables.
    FixBot'a Sor
    Yorum Ekle
  19. iPhone 5 Logic Board Replacement, Removing the battery: adım 19, 1 resimden 1.
    • Remove the battery.
    • If your replacement battery came in a plastic sleeve, remove it before installation by pulling it away from the the ribbon cable.
    • Before you adhere the replacement battery, temporarily reconnect the battery connector to the motherboard socket. This ensures that the battery is properly aligned in its recess.
    • Adhere the battery, disconnect it, and continue reassembling your device.
    • During reassembly, make sure the battery is seated firmly against the rear case. This will prevent any damage to other components when reinstalling the front panel assembly.
    • Perform a hard reset after reassembly. This can prevent several issues and simplify troubleshooting.
    FixBot'a Sor
    Yorum Ekle
  20. iPhone 5 Logic Board Replacement, Logic Board Assembly: adım 20, 1 resimden 1.
    • Use the tip of a spudger to pry the cellular data antenna cable connector up from its socket on the logic board, just above the speaker enclosure.
    FixBot'a Sor
    Yorum Ekle
  21. iPhone 5 Logic Board Replacement: adım 21, 1 resimden 1.
    • Remove the following two screws securing the top logic board bracket to the rear case:
    • One 1.5 mm Phillips screw
    • One 2.3 mm Phillips screw
    FixBot'a Sor
    Yorum Ekle
  22. iPhone 5 Logic Board Replacement: adım 22, 2 resimden 1. iPhone 5 Logic Board Replacement: adım 22, 2 resimden 2.
    • Remove the bracket from the top of the logic board.
    • Be sure not to break off the tiny grounding tab that sticks up off of the bracket next to the rear facing camera.
    • On newer models, the bracket may be attached to the camera housing and will not come completely out.
    FixBot'a Sor
    Yorum Ekle
  23. iPhone 5 Logic Board Replacement: adım 23, 3 resimden 1. iPhone 5 Logic Board Replacement: adım 23, 3 resimden 2. iPhone 5 Logic Board Replacement: adım 23, 3 resimden 3.
    • Use the flat end of a spudger to disconnect the following three cables from the logic board:
    • Upper interconnect cable
    • Button assembly cable
    • Lower interconnect cable
    FixBot'a Sor
    Yorum Ekle
  24. iPhone 5 Logic Board Replacement: adım 24, 1 resimden 1.
    • Remove the two 1.3 mm Phillips screws from the inner top of the rear case.
    FixBot'a Sor
    Yorum Ekle
  25. iPhone 5 Logic Board Replacement: adım 25, 1 resimden 1.
    • Remove the single 1.2 mm Phillips screw remaining in the mid-section logic board bracket.
    FixBot'a Sor
    Yorum Ekle
  26. iPhone 5 Logic Board Replacement: adım 26, 2 resimden 1. iPhone 5 Logic Board Replacement: adım 26, 2 resimden 2.
    • Remove the mid-section bracket from the logic board.
    FixBot'a Sor
    Yorum Ekle
  27. iPhone 5 Logic Board Replacement: adım 27, 2 resimden 1. iPhone 5 Logic Board Replacement: adım 27, 2 resimden 2.
    • Use a spudger to pry the Lightning connector cable connector up from its socket on the logic board.
    • Gently peel the cable back and out of the way of the logic board.
    FixBot'a Sor
    Yorum Ekle
  28. iPhone 5 Logic Board Replacement: adım 28, 3 resimden 1. iPhone 5 Logic Board Replacement: adım 28, 3 resimden 2. iPhone 5 Logic Board Replacement: adım 28, 3 resimden 3.
    • Depress the SIM card release on the right side of the iPhone with a SIM card eject tool or a bent paperclip to eject the SIM card tray.
    • Alternatively, you can press the SIM card eject lever from the inside with the flat end of a spudger.
    • Remove the SIM card tray from the iPhone.
    FixBot'a Sor
    Yorum Ekle
  29. iPhone 5 Logic Board Replacement: adım 29, 1 resimden 1.
    Standoff Screwdriver for iPhones
    $5.49
    • Remove the following screws securing the logic board to the rear case:
    • Two 2.3 mm Phillips screws
    • Two 2.7 mm standoff screws
    • Standoff screws are best removed using a standoff screwdriver or bit.
    • In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
    • One non-magnetic 2.7 mm standoff screw
    • Be sure to put this screw back in its original position at the top of the logic board. A magnetized screw may interfere with the digital compass.
    FixBot'a Sor
    Yorum Ekle
  30. iPhone 5 Logic Board Replacement: adım 30, 3 resimden 1. iPhone 5 Logic Board Replacement: adım 30, 3 resimden 2. iPhone 5 Logic Board Replacement: adım 30, 3 resimden 3.
    • Rotate the logic board assembly toward the battery side of the rear case.
    • Do not attempt to completely remove the logic board assembly from the rear case, yet; there is still one cable connected to the underside of the logic board.
    • The flash surround is adhered to the flash unit and the rear case. If it stays on the rear case remove with tweezers and mount it back on the flash unit.
    • Note: when reassembling your device, be sure that the lower interconnect cable is not tucked underneath the logic board.
    FixBot'a Sor
    Yorum Ekle
  31. iPhone 5 Logic Board Replacement: adım 31, 2 resimden 1. iPhone 5 Logic Board Replacement: adım 31, 2 resimden 2.
    • Use the tip of a spudger to pry the Wi-Fi antenna cable connector up from its socket on the underside of the logic board.
    FixBot'a Sor
    Yorum Ekle
  32. iPhone 5 Logic Board Replacement: adım 32, 1 resimden 1.
    • Remove the logic board assembly from the rear case.
    • While your logic board is out of your phone, keep it on a grounded anti-static mat to prevent any damage to the circuitry.
    FixBot'a Sor
    Yorum Ekle
  33. iPhone 5 Logic Board Replacement, Rear-Facing Camera: adım 33, 1 resimden 1.
    • Remove two 1.1 mm Phillips screws securing the rear-facing camera bracket to the logic board.
    FixBot'a Sor
    Yorum Ekle
  34. iPhone 5 Logic Board Replacement: adım 34, 2 resimden 1. iPhone 5 Logic Board Replacement: adım 34, 2 resimden 2.
    • Remove the rear-facing camera bracket from the logic board.
    FixBot'a Sor
    Yorum Ekle
  35. iPhone 5 Logic Board Replacement: adım 35, 1 resimden 1.
    • Use the flat end of a spudger to disconnect the rear-facing camera cable from its socket on the logic board.
    FixBot'a Sor
    Yorum Ekle
  36. iPhone 5 Logic Board Replacement: adım 36, 2 resimden 1. iPhone 5 Logic Board Replacement: adım 36, 2 resimden 2.
    • Remove the rear-facing camera from the logic board.
    • Your replacement part may not come with the flash surround—if not, remove it from the old camera and transfer it to your replacement.
    FixBot'a Sor
    Yorum Ekle
  37. iPhone 5 Logic Board Replacement, Logic Board: adım 37, 2 resimden 1. iPhone 5 Logic Board Replacement, Logic Board: adım 37, 2 resimden 2.
    • Use the flat end of a spudger to disconnect the bottoms of the interconnect cables from their sockets on the logic board.
    FixBot'a Sor
    Yorum Ekle
  38. iPhone 5 Logic Board Replacement: adım 38, 1 resimden 1.
    • Remove the two interconnect cables from the logic board.
    FixBot'a Sor
    Yorum Ekle
  39. iPhone 5 Logic Board Replacement: adım 39, 1 resimden 1.
    • The bare logic board remains.
    FixBot'a Sor
    Yorum Ekle
Sonuç
208 farklı kişi bu kılavuzu tamamladı.
Andrew Optimus Goldheart
515.338 İtibar
407 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
30.155 adet Kılavuz yazıldı
24Kılavuz Yorumları
Is it possible to switch my iphone 5 motherboard to a iphone5s motherboard?
Jep poy - Yanıt Paylaş
No it isn't, the boards are different sizes.
Gigabit87898 - Yanıt Paylaş
Is it ok to switch my iphone 5 motherboard to a iphone 5s motherboard?
Is replacing the logic board a sensible way to add memory - i.e. would it make sense to swap a 64GB logic board into my 16GB iPhone 5? (I have been nursing this phone along for a while now but the low memory is getting to be a problem!)
Jeff Caves - Yanıt Paylaş
Yes, that’s the best way to do it. It’s possible to unsolder the flash storage from the current motherboard and install a new one, but that’s much more difficult.
Matthew Sigmond - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 55
Son 30 gün: 227
Her zaman: 422,414
