Ana içeriğe geç
iPhone 6 Camera Lens Replacement
Neye ihtiyacın var
Videoya Genel Bakış
  1. iPhone 6 Camera Lens Replacement, Pentalobe Screws: adım 1, 1 resimden 1.
    • Before disassembling your iPhone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.6 mm-long P2 Pentalobe screws next to the Lightning connector.
  2. iPhone 6 Camera Lens Replacement, Anti-Clamp instructions: adım 2, 3 resimden 1. iPhone 6 Camera Lens Replacement, Anti-Clamp instructions: adım 2, 3 resimden 2. iPhone 6 Camera Lens Replacement, Anti-Clamp instructions: adım 2, 3 resimden 3.
    Bu adımda kullanılan alet:
    Clampy - Anti-Clamp
    $24.95
    • The next two steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  3. iPhone 6 Camera Lens Replacement: adım 3, 3 resimden 1. iPhone 6 Camera Lens Replacement: adım 3, 3 resimden 2. iPhone 6 Camera Lens Replacement: adım 3, 3 resimden 3.
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait a few seconds between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
  4. iPhone 6 Camera Lens Replacement, Manual Opening Procedure: adım 4, 1 resimden 1.
    Clampy - Anti-Clamp
    $24.95
    • If you don't have an Anti-Clamp, use a single suction cup to lift the front panel:
    • Press a suction cup onto the screen, just above the home button.
    • Be sure the cup is pressed securely onto the screen to get a tight seal.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
  5. iPhone 6 Camera Lens Replacement: adım 5, 1 resimden 1.
    • While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the front panel assembly from the rear case.
    • Take your time and apply firm, constant force. The display assembly is a much tighter fit than most devices.
    • Using a plastic opening tool, begin to gently pry the rear case down, away from the display assembly, while continuing to pull up with the suction cup.
    • There are several clips holding the front panel assembly to the rear case, so you may need to use a combination of the suction cup and plastic opening tool to free the front panel assembly.
  6. iPhone 6 Camera Lens Replacement: adım 6, 2 resimden 1. iPhone 6 Camera Lens Replacement: adım 6, 2 resimden 2.
    • Pull the plastic nub to release the vacuum seal on the suction cup.
    • Remove the suction cup from the display assembly.
  7. iPhone 6 Camera Lens Replacement, Opening up the phone: adım 7, 3 resimden 1. iPhone 6 Camera Lens Replacement, Opening up the phone: adım 7, 3 resimden 2. iPhone 6 Camera Lens Replacement, Opening up the phone: adım 7, 3 resimden 3.
    • Open the iPhone by swinging the home button end of the front panel assembly away from the rear case, using the top of the phone as a hinge.
    • Several clips along the top edge of the front panel form a partial hinge.
    • During reassembly, align the clips just below the top edge of the rear case. Then, slide the front panel upward until its top edge is flush with that of the rear case.
  8. iPhone 6 Camera Lens Replacement: adım 8, 3 resimden 1. iPhone 6 Camera Lens Replacement: adım 8, 3 resimden 2. iPhone 6 Camera Lens Replacement: adım 8, 3 resimden 3.
    • Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
    • In a pinch, an unopened canned beverage works well for this.
    • Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
  9. iPhone 6 Camera Lens Replacement, Removing the battery connector bracket screws: adım 9, 1 resimden 1.
    Magnetic Project Mat
    $16.96
    • Remove the following Phillips screws from the battery connector bracket:
    • One 2.2 mm screw
    • One 3.2 mm screw
    • During your repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your phone.
  10. iPhone 6 Camera Lens Replacement: adım 10, 1 resimden 1.
    • Remove the metal battery connector bracket from the iPhone.
  11. iPhone 6 Camera Lens Replacement, Disconnecting the battery connector: adım 11, 1 resimden 1.
    • Use a plastic opening tool to gently pry the battery connector up from its socket on the logic board.
    • Take care to only pry up on the battery connector, and not the socket on the logic board. If you pry up on the logic board socket, you may break the connector entirely.
  12. iPhone 6 Camera Lens Replacement, Removing the front panel assembly cable bracket screws: adım 12, 1 resimden 1.
    • Remove the following five Phillips screws securing the front panel assembly cable bracket:
    • Three 1.2 mm screws
    • One 1.7 mm screw
    • One 3.1 mm screw
    • Incorrect placement of these screws during reassembly will cause permanent damage to your iPhone's logic board.
  13. iPhone 6 Camera Lens Replacement: adım 13, 1 resimden 1.
    • Remove the front panel assembly cable bracket from the logic board.
  14. iPhone 6 Camera Lens Replacement: adım 14, 2 resimden 1. iPhone 6 Camera Lens Replacement: adım 14, 2 resimden 2.
    • In the next four steps, take care to pry up only on the cable connectors, and not on their sockets on the logic board.
    • Use a spudger or a fingernail to disconnect the front-facing camera and sensor cable connector.
  15. iPhone 6 Camera Lens Replacement: adım 15, 2 resimden 1. iPhone 6 Camera Lens Replacement: adım 15, 2 resimden 2.
    • Use a spudger or a fingernail to disconnect the home button cable connector.
  16. iPhone 6 Camera Lens Replacement: adım 16, 2 resimden 1. iPhone 6 Camera Lens Replacement: adım 16, 2 resimden 2.
    • Make sure the battery is disconnected before you disconnect or reconnect the cable in this step.
    • Use a spudger or a fingernail to disconnect the display data cable connector.
    • When reassembling your phone, the display data cable may pop off its connector. This can result in white lines or a blank screen when powering your phone back on. If that happens, simply reconnect the cable and power cycle your phone. The best way to power cycle your phone is to disconnect and reconnect the battery connector.
  17. iPhone 6 Camera Lens Replacement: adım 17, 2 resimden 1. iPhone 6 Camera Lens Replacement: adım 17, 2 resimden 2.
    • Use the flat end of a spudger to disconnect the digitizer cable connector.
    • When reconnecting the digitizer cable, do not press the center of the connector. Press one end of the connector, then press the opposite end. Pressing in the center of the connector can bend the component and cause digitizer damage.
  18. iPhone 6 Camera Lens Replacement, Separating front panel assembly and rear case: adım 18, 1 resimden 1.
    • Remove the front panel assembly from the rear case.
  19. iPhone 6 Camera Lens Replacement, Rear Facing Camera: adım 19, 2 resimden 1. iPhone 6 Camera Lens Replacement, Rear Facing Camera: adım 19, 2 resimden 2.
    • Remove any tape covering the upper left rear-facing camera screw.
  20. iPhone 6 Camera Lens Replacement: adım 20, 2 resimden 1. iPhone 6 Camera Lens Replacement: adım 20, 2 resimden 2.
    • Use the flat end of a spudger to lift the rear-facing camera connector up off of its socket on the logic board.
    • Pry only on the connector, not the socket itself or you risk damaging the logic board.
  21. iPhone 6 Camera Lens Replacement: adım 21, 1 resimden 1.
    • Remove the following Phillips #00 screws from the rear-facing camera bracket:
    • One 1.5 mm screw
    • One 2.1 mm screw
  22. iPhone 6 Camera Lens Replacement: adım 22, 2 resimden 1. iPhone 6 Camera Lens Replacement: adım 22, 2 resimden 2.
    • Remove the rear-facing camera bracket.
  23. iPhone 6 Camera Lens Replacement: adım 23, 2 resimden 1. iPhone 6 Camera Lens Replacement: adım 23, 2 resimden 2.
    • Remove the rear-facing camera from the iPhone.
  24. iPhone 6 Camera Lens Replacement, Camera Lens: adım 24, 2 resimden 1. iPhone 6 Camera Lens Replacement, Camera Lens: adım 24, 2 resimden 2.
    • It's difficult to remove this bottom bracket. The inside round edge of this bracket seems soldered with camera lens ring. So you need a lot of effort and it's not unusual to break the bracket.
  25. iPhone 6 Camera Lens Replacement: adım 25, 3 resimden 1. iPhone 6 Camera Lens Replacement: adım 25, 3 resimden 2. iPhone 6 Camera Lens Replacement: adım 25, 3 resimden 3.
    • The last step is to push the cracked camera lens out from inside.
    • First, find a tool you prefer and easy to use with effort. Then, put your hands where your power will land to protect the rear case from bending. Next, push the camera lens with effort. Please be careful with the phone and your hand very much.
    • When you place the new camera lens, you will need glue or adhesive to fasten the camera lens as well as the new bottom bracket.
    • If you worry about the iPhone 6 being damaged, please send it to an Apple center.
Sonuç
109 farklı kişi bu kılavuzu tamamladı.
Sophia
43.905 İtibar
62 adet Kılavuz yazıldı
39Kılavuz Yorumları
Thank you Sophia, very good guide. I just wanted to add more information to Step 5, 6, 7, and 8.
Step 5 - Disconnect the rear camera from motherboard, gently lift ribbon towards the top. This will help release the thin black tape covering the top left screw holding the bracket. I peel it back just enough to access the screw.
Step 6 - Gently lift the rear camera from the frame avoid touching the camera lens.
I reversed parts of Step 7 and 8.
Step 7 - You will destroy the bracket. The bracket and lens are crimped or pressed together somehow, as stated in the guide. The next step I modified; press out the rest of the broken glass in the lens. Then as in step 8 press the lens from the inside, outward to break the crimp.
Step 8 - Lift out the bracket, it may still be attached.Use heated air to remove the black foam square from the old bracket and reuse for the new bracket.
To repair, I'm still looking for the best way. I carefully used super glue to place the lens and bracket in place.
MaxM Tech - Yanıt
Does anyone know if the iPhone 6 plus Lens replacement is about the same?
Caroline Haney - Yanıt
Anyone knows where can I purchase the camera bracket? I don't seem to find it.
Thank you
Abdullah Mohammad - Yanıt
Hi u can buy it here at the top of the guide :-) under relevant parts.
billyroypage -
I'm with u Greg , I tried the hard way it's like pulling a good tooth ! Something gonna break and possible bend . Great video though exposing the hidden screw.
billyroypage -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 9
Son 7 gün: 137
Son 30 gün: 696
Her zaman: 289,046
