Ana içeriğe geç
iPhone 6 Plus Screen Replacement
Neye ihtiyacın var
Videoya Genel Bakış
    1. iPhone 6 Plus Screen Replacement, Pentalobe Screws: adım 1, 1 resimden 1.
      • Before disassembling your iPhone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
      • Power off your iPhone before beginning disassembly.
      • Remove the two 3.6 mm P2 Pentalobe screws next to the Lightning connector.
      FixBot'a Sor
      Yorum Ekle
    1. iPhone 6 Plus Screen Replacement, Taping Over The Display: adım 2, 3 resimden 1. iPhone 6 Plus Screen Replacement, Taping Over The Display: adım 2, 3 resimden 2. iPhone 6 Plus Screen Replacement, Taping Over The Display: adım 2, 3 resimden 3.
      • If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
      • Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered.
      • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
      • If the broken glass makes it difficult to get a suction cup to stick in the next few steps, try folding a strong piece of tape (such as duct tape) into a handle and lifting the display with that instead.
      FixBot'a Sor
      Yorum Ekle
    1. iPhone 6 Plus Screen Replacement, Anti-Clamp instructions: adım 3, 3 resimden 1. iPhone 6 Plus Screen Replacement, Anti-Clamp instructions: adım 3, 3 resimden 2. iPhone 6 Plus Screen Replacement, Anti-Clamp instructions: adım 3, 3 resimden 3.
      Bu adımda kullanılan alet:
      Clampy - Anti-Clamp
      $24.95
      • The next two steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
      • For complete instructions on how to use the Anti-Clamp, check out this guide.
      • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
      • Slide the arms over either the left or right edge of your iPhone.
      • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
      • Squeeze the cups together to apply suction to the desired area.
      • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
      FixBot'a Sor
      Yorum Ekle
    2. iPhone 6 Plus Screen Replacement: adım 4, 3 resimden 1. iPhone 6 Plus Screen Replacement: adım 4, 3 resimden 2. iPhone 6 Plus Screen Replacement: adım 4, 3 resimden 3.
      • Pull the blue handle forwards to lock the arms.
      • Turn the handle clockwise 360 degrees or until the cups start to stretch.
      • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
      • Insert an opening pick or tool under the screen when the Anti-Clamp creates a large enough gap.
      • If the Anti-Clamp doesn't create a sufficient gap, rotate the handle a quarter turn.
      • Don't crank more than a quarter turn at a time, and wait a few seconds between turns. Let the Anti-Clamp and time do the work for you.
      • Skip the next three steps.
      FixBot'a Sor
      Yorum Ekle
    1. iPhone 6 Plus Screen Replacement, Front Panel Assembly: adım 5, 1 resimden 1.
      • Use a single suction cup to lift the front panel:
      • Press a suction cup onto the screen, just above the home button.
      • Be sure the cup is pressed securely onto the screen to get a tight seal.
      • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
      FixBot'a Sor
      Yorum Ekle
    2. iPhone 6 Plus Screen Replacement: adım 6, 1 resimden 1.
      • While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the front panel assembly from the rear case.
      • Take your time and apply firm, constant force. The display assembly is a much tighter fit than most devices.
      • Using a plastic opening tool, begin to gently pry the rear case down, away from the display assembly, while continuing to pull up with the suction cup.
      • There are several clips attaching the front panel assembly to the rear case, so you may need to use a combination of the suction cup and plastic opening tool to free the front panel assembly.
      FixBot'a Sor
      Yorum Ekle
    3. iPhone 6 Plus Screen Replacement: adım 7, 2 resimden 1. iPhone 6 Plus Screen Replacement: adım 7, 2 resimden 2.
      • Pull the plastic nub to release the vacuum seal on the suction cup.
      • Remove the suction cup from the display assembly.
      FixBot'a Sor
      Yorum Ekle
    4. iPhone 6 Plus Screen Replacement: adım 8, 3 resimden 1. iPhone 6 Plus Screen Replacement: adım 8, 3 resimden 2. iPhone 6 Plus Screen Replacement: adım 8, 3 resimden 3.
      • Pull the home button end of the front panel assembly away from the rear case, using the top of the phone as a hinge.
      • Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
      • Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
      • In a pinch, you can use an unopened canned beverage to hold the display.
      FixBot'a Sor
      Yorum Ekle
    5. iPhone 6 Plus Screen Replacement: adım 9, 2 resimden 1. iPhone 6 Plus Screen Replacement: adım 9, 2 resimden 2.
      • Several clips along the top edge of the front panel form a partial hinge, allowing the front panel assembly to swing open like a book.
      • During reassembly, align the clips just below the top edge of the rear case. Then, slide the front panel upward until its top edge is flush with that of the rear case.
      FixBot'a Sor
      Yorum Ekle
    6. iPhone 6 Plus Screen Replacement: adım 10, 1 resimden 1.
      • Remove the following Phillips screws from the battery connector bracket:
      • One 2.3 mm screw
      • One 3.1 mm screw
      FixBot'a Sor
      Yorum Ekle
    7. iPhone 6 Plus Screen Replacement: adım 11, 1 resimden 1.
      • Remove the metal battery connector bracket from the iPhone.
      FixBot'a Sor
      Yorum Ekle
    8. iPhone 6 Plus Screen Replacement: adım 12, 1 resimden 1.
      • Use a clean fingernail or the edge of an opening tool to gently pry the battery connector up from its socket on the logic board.
      • Take care to only pry up on the battery connector, and not the socket on the logic board. If you pry up on the logic board socket, you may break the connector entirely.
      FixBot'a Sor
      Yorum Ekle
    9. iPhone 6 Plus Screen Replacement: adım 13, 1 resimden 1.
      • Remove the following Phillips screws securing the front panel assembly cable bracket:
      • Three 1.2 mm screws
      • One 1.5 mm screw
      • One 2.9 mm screw
      • Do not attempt to insert longer screws into the red marked screw holes. Doing so may result in irreparable damage to the logic board.
      FixBot'a Sor
      Yorum Ekle
    10. iPhone 6 Plus Screen Replacement: adım 14, 1 resimden 1.
      • Remove the front panel assembly cable bracket from the logic board.
      FixBot'a Sor
      Yorum Ekle
    11. iPhone 6 Plus Screen Replacement: adım 15, 2 resimden 1. iPhone 6 Plus Screen Replacement: adım 15, 2 resimden 2.
      • In the next four steps, take care to pry up only on the cable connectors, and not on their sockets on the logic board.
      • While still supporting the front panel, use a fingernail or the edge of an opening tool to disconnect the front-facing camera and earpiece speaker connector.
      FixBot'a Sor
      Yorum Ekle
    12. iPhone 6 Plus Screen Replacement: adım 16, 2 resimden 1. iPhone 6 Plus Screen Replacement: adım 16, 2 resimden 2.
      • Disconnect the home button cable connector.
      FixBot'a Sor
      Yorum Ekle
    13. iPhone 6 Plus Screen Replacement: adım 17, 2 resimden 1. iPhone 6 Plus Screen Replacement: adım 17, 2 resimden 2.
      • Make sure the battery is disconnected before you disconnect or reconnect the cable in this step.
      • Use a plastic opening tool to disconnect the display data cable connector.
      • When reassembling your phone, the display data cable may pop off the connector. This can result in white lines or a blank screen when powering your phone back on. If that happens, simply reconnect the cable and power cycle your phone. The best way to power cycle your phone is to disconnect and reconnect the battery connector.
      FixBot'a Sor
      Yorum Ekle
    14. iPhone 6 Plus Screen Replacement: adım 18, 2 resimden 1. iPhone 6 Plus Screen Replacement: adım 18, 2 resimden 2.
      • Finally, disconnect the digitizer cable connector.
      • When reconnecting the digitizer cable, do not press the center of the connector. Press one end of the connector, then press the opposite end. Pressing in the center of the connector can bend the component and cause digitizer damage.
      FixBot'a Sor
      Yorum Ekle
    15. iPhone 6 Plus Screen Replacement: adım 19, 1 resimden 1.
      • Remove the front panel assembly from the rear case.
      FixBot'a Sor
      Yorum Ekle
    1. iPhone 6 Plus Screen Replacement, Home Button Assembly: adım 20, 1 resimden 1.
      • Remove the two 1.8 mm Phillips screws securing the home button bracket to the front panel.
      FixBot'a Sor
      Yorum Ekle
    2. iPhone 6 Plus Screen Replacement: adım 21, 1 resimden 1.
      • Remove the home button bracket from the front panel assembly.
      FixBot'a Sor
      Yorum Ekle
    3. iPhone 6 Plus Screen Replacement: adım 22, 2 resimden 1. iPhone 6 Plus Screen Replacement: adım 22, 2 resimden 2.
      • Use the tip of a spudger to disconnect the home button connector from its socket on the home button cable.
      FixBot'a Sor
      Yorum Ekle
    4. iPhone 6 Plus Screen Replacement: adım 23, 1 resimden 1.
      iOpener
      $14.95
      • Carefully wedge the tip of a spudger underneath the home button connector cable.
      • Gently move the spudger across to separate the home button connector cable from the adhesive securing it to the front panel assembly.
      • If the cable doesn't separate easily, apply heat using an iOpener or hair dryer to soften the adhesive, and try again. Be careful not to damage the cable.
      FixBot'a Sor
      Yorum Ekle
    5. iPhone 6 Plus Screen Replacement: adım 24, 2 resimden 1. iPhone 6 Plus Screen Replacement: adım 24, 2 resimden 2.
      iOpener
      $24.95
      • The rubber gasket surrounding the home button is very thin and tears easily.
      • Apply mild heat (with an iOpener, heat gun, or hair dryer) to soften the adhesive securing the home button gasket.
      • Using your fingertip, gently press up on the home button from the front side of the display assembly. Use firm, constant pressure to slowly separate the home button's rubber gasket from the front panel.
      FixBot'a Sor
      Yorum Ekle
    6. iPhone 6 Plus Screen Replacement: adım 25, 2 resimden 1. iPhone 6 Plus Screen Replacement: adım 25, 2 resimden 2.
      • Carefully use the tip of a spudger to finish separating the home button from the front panel.
      FixBot'a Sor
      Yorum Ekle
    7. iPhone 6 Plus Screen Replacement: adım 26, 1 resimden 1.
      • Lift and remove the home button assembly off the front panel assembly.
      FixBot'a Sor
      Yorum Ekle
    1. iPhone 6 Plus Screen Replacement, Screen: adım 27, 1 resimden 1.
      • The screen remains.
      • Compare your new replacement part to the original part. You may need to transfer remaining components (such as the two rubber grommets at the bottom of the screen) before installing.
      • The Touch ID function will ONLY work with your phone's original home button assembly, so you'll need to transfer the home button assembly from your old screen to your new screen to retain Touch ID.
      • Your replacement part may come with an extra Phillips screw already installed left of the Home Button. Remove the unnecessary screw so that you can reinstall the home button bracket.
      • After reassembly, clean the touchscreen surface with an alcohol wipe prior to turning the iPhone back on. The alcohol helps dissipate any lingering static electricity, which can cause problems with the display.
      • After reassembly, connect the iPhone to an AC power source before turning it on for the first time. Once the iPhone has booted up successfully, you can disconnect the AC power.
      FixBot'a Sor
      Yorum Ekle
Sonuç
753 farklı kişi bu kılavuzu tamamladı.
96Kılavuz Yorumları
I have original home screen button, but the panel and home button cable was part of what was damaged on the phone. With that in mind will it still work with original home screen button, but replacement panel?
Pot Kerwin - Yanıt Paylaş
This is a tough one. I do not know that you'll be able to salvage the Touch ID functionality of the home button with the connector being damaged. You may need to purchase iPhone 6 and 6 Plus Home Button Assembly and iPhone 6 and 6 Plus Home Button Gasket. This will no longer retain the Touch ID functionality though.
Jeffrey Carpenter - Yanıt Paylaş
I will be testing this out myself as soon a I get a new touchID cable/along with the LCD Panel. I did a screen replacement, all went well and works great, however I punctured the TouchID cable when prying it off of the old display.
I ordered a new cable with the panel, as I understand it as long as you have the ORIGINAL TouchID assembly which I do, after replacing the cable it should work!
Cody Crosby - Yanıt Paylaş
Instructions are incomplete ! You also have to remove the aluminum plate and the rear camera/speaker assembly.
Also, my touch ID does not work anymore :/ nothing was damaged and plug is connected. Resetting the phone made no difference.
Why would it not work if I used the same Home Button and logic board?
michael8nuts - Yanıt Paylaş
hey having the same problem with my touch id.. did you ever find a solution?
bRIZZZZZZZZ - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 13
Son 7 gün: 92
Son 30 gün: 674
Her zaman: 767,482
