Ana içeriğe geç
iPhone 6 Speaker Replacement
Neye ihtiyacın var
  1. iPhone 6 Speaker Replacement, Pentalobe Screws: adım 1, 1 resimden 1.
    • Before disassembling your iPhone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.6 mm-long P2 Pentalobe screws next to the Lightning connector.
  2. iPhone 6 Speaker Replacement, Anti-Clamp instructions: adım 2, 3 resimden 1. iPhone 6 Speaker Replacement, Anti-Clamp instructions: adım 2, 3 resimden 2. iPhone 6 Speaker Replacement, Anti-Clamp instructions: adım 2, 3 resimden 3.
    Bu adımda kullanılan alet:
    Clampy - Anti-Clamp
    $24.95
    • The next two steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  3. iPhone 6 Speaker Replacement: adım 3, 3 resimden 1. iPhone 6 Speaker Replacement: adım 3, 3 resimden 2. iPhone 6 Speaker Replacement: adım 3, 3 resimden 3.
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait a few seconds between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
  4. iPhone 6 Speaker Replacement, Manual Opening Procedure: adım 4, 1 resimden 1.
    Clampy - Anti-Clamp
    $24.95
    • If you don't have an Anti-Clamp, use a single suction cup to lift the front panel:
    • Press a suction cup onto the screen, just above the home button.
    • Be sure the cup is pressed securely onto the screen to get a tight seal.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
  5. iPhone 6 Speaker Replacement: adım 5, 1 resimden 1.
    • While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the front panel assembly from the rear case.
    • Take your time and apply firm, constant force. The display assembly is a much tighter fit than most devices.
    • Using a plastic opening tool, begin to gently pry the rear case down, away from the display assembly, while continuing to pull up with the suction cup.
    • There are several clips holding the front panel assembly to the rear case, so you may need to use a combination of the suction cup and plastic opening tool to free the front panel assembly.
  6. iPhone 6 Speaker Replacement: adım 6, 2 resimden 1. iPhone 6 Speaker Replacement: adım 6, 2 resimden 2.
    • Pull the plastic nub to release the vacuum seal on the suction cup.
    • Remove the suction cup from the display assembly.
  7. iPhone 6 Speaker Replacement, Opening up the phone: adım 7, 3 resimden 1. iPhone 6 Speaker Replacement, Opening up the phone: adım 7, 3 resimden 2. iPhone 6 Speaker Replacement, Opening up the phone: adım 7, 3 resimden 3.
    • Open the iPhone by swinging the home button end of the front panel assembly away from the rear case, using the top of the phone as a hinge.
    • Several clips along the top edge of the front panel form a partial hinge.
    • During reassembly, align the clips just below the top edge of the rear case. Then, slide the front panel upward until its top edge is flush with that of the rear case.
  8. iPhone 6 Speaker Replacement: adım 8, 3 resimden 1. iPhone 6 Speaker Replacement: adım 8, 3 resimden 2. iPhone 6 Speaker Replacement: adım 8, 3 resimden 3.
    • Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
    • In a pinch, an unopened canned beverage works well for this.
    • Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
  9. iPhone 6 Speaker Replacement, Removing the battery connector bracket screws: adım 9, 1 resimden 1.
    Magnetic Project Mat
    $19.95
    • Remove the following Phillips screws from the battery connector bracket:
    • One 2.2 mm screw
    • One 3.2 mm screw
    • During your repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your phone.
  10. iPhone 6 Speaker Replacement: adım 10, 1 resimden 1.
    • Remove the metal battery connector bracket from the iPhone.
  11. iPhone 6 Speaker Replacement, Disconnecting the battery connector: adım 11, 1 resimden 1.
    • Use a plastic opening tool to gently pry the battery connector up from its socket on the logic board.
    • Take care to only pry up on the battery connector, and not the socket on the logic board. If you pry up on the logic board socket, you may break the connector entirely.
  12. iPhone 6 Speaker Replacement, Removing the front panel assembly cable bracket screws: adım 12, 1 resimden 1.
    • Remove the following five Phillips screws securing the front panel assembly cable bracket:
    • Three 1.2 mm screws
    • One 1.7 mm screw
    • One 3.1 mm screw
    • Incorrect placement of these screws during reassembly will cause permanent damage to your iPhone's logic board.
  13. iPhone 6 Speaker Replacement: adım 13, 1 resimden 1.
    • Remove the front panel assembly cable bracket from the logic board.
  14. iPhone 6 Speaker Replacement: adım 14, 2 resimden 1. iPhone 6 Speaker Replacement: adım 14, 2 resimden 2.
    • In the next four steps, take care to pry up only on the cable connectors, and not on their sockets on the logic board.
    • Use a spudger or a fingernail to disconnect the front-facing camera and sensor cable connector.
  15. iPhone 6 Speaker Replacement: adım 15, 2 resimden 1. iPhone 6 Speaker Replacement: adım 15, 2 resimden 2.
    • Use a spudger or a fingernail to disconnect the home button cable connector.
  16. iPhone 6 Speaker Replacement: adım 16, 2 resimden 1. iPhone 6 Speaker Replacement: adım 16, 2 resimden 2.
    • Make sure the battery is disconnected before you disconnect or reconnect the cable in this step.
    • Use a spudger or a fingernail to disconnect the display data cable connector.
    • When reassembling your phone, the display data cable may pop off its connector. This can result in white lines or a blank screen when powering your phone back on. If that happens, simply reconnect the cable and power cycle your phone. The best way to power cycle your phone is to disconnect and reconnect the battery connector.
  17. iPhone 6 Speaker Replacement: adım 17, 2 resimden 1. iPhone 6 Speaker Replacement: adım 17, 2 resimden 2.
    • Use the flat end of a spudger to disconnect the digitizer cable connector.
    • When reconnecting the digitizer cable, do not press the center of the connector. Press one end of the connector, then press the opposite end. Pressing in the center of the connector can bend the component and cause digitizer damage.
  18. iPhone 6 Speaker Replacement, Separating front panel assembly and rear case: adım 18, 1 resimden 1.
    • Remove the front panel assembly from the rear case.
  19. iPhone 6 Speaker Replacement, Speaker: adım 19, 2 resimden 1. iPhone 6 Speaker Replacement, Speaker: adım 19, 2 resimden 2.
    • Use the flat end of a spudger to disconnect the Lightning connector assembly cable and fold it out of the way of the speaker.
  20. iPhone 6 Speaker Replacement: adım 20, 2 resimden 1. iPhone 6 Speaker Replacement: adım 20, 2 resimden 2.
    • Use the point of a spudger to lift the antenna cable connector up off of its socket on the logic board.
  21. iPhone 6 Speaker Replacement: adım 21, 1 resimden 1.
    • Remove the following four Phillips screws securing the speaker:
    • Two 2.9 mm screws
    • Two 2.3 mm screws
  22. iPhone 6 Speaker Replacement: adım 22, 2 resimden 1. iPhone 6 Speaker Replacement: adım 22, 2 resimden 2.
    • Use the point of a spudger to push the antenna interconnect cable clip off of the speaker housing.
  23. iPhone 6 Speaker Replacement: adım 23, 3 resimden 1. iPhone 6 Speaker Replacement: adım 23, 3 resimden 2. iPhone 6 Speaker Replacement: adım 23, 3 resimden 3.
    • Use the tip of a spudger to pry the speaker up and out of the rear case.
    • Remove the speaker from the iPhone.
Sonuç
135 farklı kişi bu kılavuzu tamamladı.
Sam Goldheart
477.183 İtibar
538 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
25.591 adet Kılavuz yazıldı
18Kılavuz Yorumları
Hi guys, I'm about to start this process. My question is, do I need to remove the screen before changing the speaker? Is there any reason why I should do that? Or can I just live the phone in 90 degrees, as shown on step 9? To sum up, can I just jump from step 13 to step 20? Thanks!
Emilio Zaidman - Yanıt Paylaş
I'm wondering the same thing. Why does the screen need to come off? I have no problem doing it but seems like a good bit of work that is not needed for just replacing the speaker.
psycwon - Paylaş
Fully detaching the display is not necessary. If it's properly supported so that there's no strain on the display cables, you can skip straight to removing the speaker.
Jeff Suovanen - Paylaş
After replacing my speaker when I turn my phone on the audio sounds distorted and if I turn the volume up too high instead of increasing the volume the phone will power off. Any ideas?
Darren Fadaie - Yanıt Paylaş
The same here!!! :( any solutions?
fyantorno - Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 46
Son 30 gün: 149
Her zaman: 223,980
