Ana içeriğe geç
iPhone 6s Display Replacement
Arşivlenmiş Kılavuz
Bu kılavuz sadece arşivsel amaçlarla muhafaza edilmiştir. Onarımınızı gerçekleştirmek için kılavuzun güncel halini kullanın.
Neye ihtiyacın var
  1. iPhone 6s Display Replacement, Battery Connection: adım 1, 1 resimden 1.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.4 mm Pentalobe screws surrounding the Lightning connector.
    FixBot'a Sor
    Yorum Ekle
  2. iPhone 6s Display Replacement: adım 2, 1 resimden 1.
    • If you don't have an iSclack, use a single suction cup to lift the front panel:
    • Press a suction cup onto the screen, just above the home button.
    • Be sure the cup is pressed securely onto the screen to get a tight seal.
    FixBot'a Sor
    Yorum Ekle
  3. iPhone 6s Display Replacement: adım 3, 3 resimden 1. iPhone 6s Display Replacement: adım 3, 3 resimden 2. iPhone 6s Display Replacement: adım 3, 3 resimden 3.
    • There is a notch on the underside of the display just above the headphone jack that is the safest place to begin prying the phone open.
    • Pull up on the suction cup to slightly separate the front panel assembly from the rear case.
    • Take your time and apply firm, constant force. The display assembly is a much tighter fit than most devices and is held down with adhesive.
    • Once a small gap has been opened, insert the flat end of a spudger above the headphone jack.
    FixBot'a Sor
    Yorum Ekle
  4. iPhone 6s Display Replacement: adım 4, 2 resimden 1. iPhone 6s Display Replacement: adım 4, 2 resimden 2.
    • Twist the spudger to open the gap more and break it free from the adhesive.
    • Keep pulling up on the suction cup while twisting the spudger.
    FixBot'a Sor
    Yorum Ekle
  5. iPhone 6s Display Replacement: adım 5, 2 resimden 1. iPhone 6s Display Replacement: adım 5, 2 resimden 2.
    • Use the edge of a spudger to slice through the adhesive on either side of the phone.
    FixBot'a Sor
    Yorum Ekle
  6. iPhone 6s Display Replacement: adım 6, 2 resimden 1. iPhone 6s Display Replacement: adım 6, 2 resimden 2.
    FixBot'a Sor
    Yorum Ekle
  7. iPhone 6s Display Replacement: adım 7, 3 resimden 1. iPhone 6s Display Replacement: adım 7, 3 resimden 2. iPhone 6s Display Replacement: adım 7, 3 resimden 3.
    • Use the suction cup to open the display, breaking the last of the adhesive.
    • Don't open the display more than 90 degrees, as it is still connected at the top by three cables that may break if stretched.
    FixBot'a Sor
    Yorum Ekle
  8. iPhone 6s Display Replacement: adım 8, 1 resimden 1.
    • Lean the display against something to keep it propped up while you're working on the phone.
    FixBot'a Sor
    Yorum Ekle
  9. iPhone 6s Display Replacement: adım 9, 1 resimden 1.
    • Remove the following screws from the battery connector bracket:
    • One 3.0 mm Phillips #00 screw
    • One 2.3 mm Phillips #00 screw
    FixBot'a Sor
    Yorum Ekle
  10. iPhone 6s Display Replacement: adım 10, 1 resimden 1.
    • Remove the metal battery connector bracket from the iPhone.
    FixBot'a Sor
    Yorum Ekle
  11. iPhone 6s Display Replacement: adım 11, 3 resimden 1. iPhone 6s Display Replacement: adım 11, 3 resimden 2. iPhone 6s Display Replacement: adım 11, 3 resimden 3.
    • Use the flat end of a spudger to disconnect the battery connector from the logic board.
    • Push the connector to the side to ensure it doesn't accidentally make contact and power on the phone while you're working on it.
    FixBot'a Sor
    Yorum Ekle
  12. iPhone 6s Display Replacement, Display: adım 12, 1 resimden 1.
    • While holding the front panel open at about a 90º angle, remove the following screws securing the front panel assembly cable bracket:
    • Three 1.3 mm Phillips #00 screws
    • Don't lose track of this screw! It's very important that the one 3.0 mm screw goes in the top-right corner of the plate. Anywhere else may cause damage to the logic board.
    FixBot'a Sor
    Yorum Ekle
  13. iPhone 6s Display Replacement: adım 13, 1 resimden 1.
    • Remove the front panel assembly cable bracket from the logic board.
    FixBot'a Sor
    Yorum Ekle
  14. iPhone 6s Display Replacement: adım 14, 3 resimden 1. iPhone 6s Display Replacement: adım 14, 3 resimden 2. iPhone 6s Display Replacement: adım 14, 3 resimden 3.
    • In the next three steps, take care to pry up only on the cable connectors, and not on their sockets on the logic board.
    • Use the flat end of a spudger to disconnect the front-facing camera and sensor cable connector.
    FixBot'a Sor
    Yorum Ekle
  15. iPhone 6s Display Replacement: adım 15, 3 resimden 1. iPhone 6s Display Replacement: adım 15, 3 resimden 2. iPhone 6s Display Replacement: adım 15, 3 resimden 3.
    • Use the flat end of a spudger to disconnect the display data cable connector.
    • When reassembling your phone, the display data cable may pop off its connector. This can result in white lines or a blank screen when powering your phone back on. If that happens, simply reconnect the cable and power cycle your phone. The best way to power cycle your phone is to disconnect and reconnect the battery connector.
    FixBot'a Sor
    Yorum Ekle
  16. iPhone 6s Display Replacement: adım 16, 2 resimden 1. iPhone 6s Display Replacement: adım 16, 2 resimden 2.
    • Finally, use the flat end of a spudger to disconnect the digitizer cable connector.
    FixBot'a Sor
    Yorum Ekle
  17. iPhone 6s Display Replacement: adım 17, 2 resimden 1. iPhone 6s Display Replacement: adım 17, 2 resimden 2.
    • Remove the display assembly from the rear case.
    FixBot'a Sor
    Yorum Ekle
Sonuç
153 farklı kişi bu kılavuzu tamamladı.
Sam Goldheart
477.675 İtibar
538 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
28.230 adet Kılavuz yazıldı
21Kılavuz Yorumları
while technically correct, this guide is not complete in the sense that a new tech cannot follow it step-by-step to successfully complete a screen replacement. You should include the steps necessary to move the parts over from the old screen. Yes you can buy screen replacements with small parts but most repair operations don't do that as it isn't that hard to move them and much less expensive.
There are many small parts involved in moving from one screen to another. There are also a few steps that require prying a flex from the frame that is taped down. Having the additional steps in this guide that point out exactly where each small parts go and how to successfully pull the flex off without tearing it would be a huge improvement to this guide (and all the other screen replacement guides as they all have the same gap)
thanks - this is a great site and my techs use it for training every day.
Marty Morrow - Yanıt Paylaş
The demo ends before it does what is stated in the heading (Display Replacement.) This demo is for Front Panel Assembly Replacement.
PJL500 - Yanıt Paylaş
As stated in the intro, this is just the full front panel assembly guide. We'll be posting more thorough screen replacement guides in the future. Stay tuned ;)
Sam Goldheart - Yanıt Paylaş
When will you be selling the 6S replacement screen. I only see on for the 6 and it says not compatible with the 6S.
Additionally is it possible to replace just the glass and not all the other parts?
dougross - Yanıt Paylaş
That is what i am curious about as well!!!
just cracked the glass in the bottom left corner of my 6s Plus.
brink28 - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 40
Her zaman: 186,019
