Ana içeriğe geç
iPhone 7 Plus Display Assembly Replacement
Salt Önkoşul
Bu kılavuz yalnızca diğer kılavuzlar için bir ön koşul olarak kullanılmak üzere tasarlanmıştır. Tek başına eksiktir.
Neye ihtiyacın var
  1. iPhone 7 Plus Display Assembly Replacement, Display Assembly: adım 1, 3 resimden 1. iPhone 7 Plus Display Assembly Replacement, Display Assembly: adım 1, 3 resimden 2. iPhone 7 Plus Display Assembly Replacement, Display Assembly: adım 1, 3 resimden 3.
    • Make sure the battery is disconnected before you disconnect or reconnect the cables in this step.
    • Use the flat end of a spudger or a fingernail to disconnect the two lower display connectors by prying them straight up from their sockets on the logic board.
    • To re-attach press connectors, press down on one end until it clicks into place, then repeat on the other end. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
    • If you have a blank screen, white lines on the display, or partial or complete lack of touch response after reassembling your phone, try disconnecting and carefully reconnecting both of these cables and make sure they are fully seated.
  2. iPhone 7 Plus Display Assembly Replacement: adım 2, 3 resimden 1. iPhone 7 Plus Display Assembly Replacement: adım 2, 3 resimden 2. iPhone 7 Plus Display Assembly Replacement: adım 2, 3 resimden 3.
    • Remove the three tri-point Y000 screws securing the bracket over the front panel sensor assembly connector:
    • One 1.3 mm screw
    • Two 1.0 mm screws
    • Remove the bracket.
  3. iPhone 7 Plus Display Assembly Replacement: adım 3, 2 resimden 1. iPhone 7 Plus Display Assembly Replacement: adım 3, 2 resimden 2.
    • Disconnect the front panel sensor assembly connector from its socket on the logic board.
    • This press connector should also be reconnected one end at a time to minimize the risk of bending.
  4. iPhone 7 Plus Display Assembly Replacement: adım 4, 1 resimden 1.
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
Paige Reisman
23.904 İtibar
15 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 5,501
