Giriş
Use this guide to remove or replace a faulty logic board in your iPhone 7 Plus.
It's important to note that each iPhone's logic board and Touch ID fingerprint sensor are paired at the factory, so replacing the logic board will disable Touch ID unless you also install a replacement home button that has been properly paired to your new logic board.
Neye ihtiyacın var
Power off your iPhone before beginning disassembly.
Remove the two 3.4 mm pentalobe screws at the bottom edge of the iPhone (using a P2 screw bit, if you have a set of bits).
Measure 3 mm from the tip and mark the opening pick with a permanent marker.
Bu adımda kullanılan alet:Clampy - Anti-Clamp$24.95
Pull the blue handle backwards to unlock the Anti-Clamp's arms.
Slide the arms over either the left or right edge of your iPhone.
Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
Squeeze the cups together to apply suction to the desired area.
Heat an iOpener and thread it through the arms of the Anti-Clamp.
Fold the iOpener so it lays on the bottom edge of the iPhone.
Wait one minute to give the adhesive a chance to release and present an opening gap.
Insert an opening pick into the gap.
Skip the next three steps.
Heating the lower edge of the iPhone will help soften the adhesive securing the display, making it easier to open.
Use a hairdryer or prepare an iOpener and apply it to the lower edge of the phone for about 90 seconds in order to soften up the adhesive underneath.
Apply a suction cup to the lower half of the front panel, just above the home button.
Remove the following four tri-point Y000 screws securing the lower display cable bracket to the logic board:
Three 1.2 mm screws
One 2.6 mm screw
Use the flat end of a spudger or a fingernail to disconnect the two lower display connectors by prying them straight up from their sockets on the logic board.
Remove three Phillips screws securing the antenna component:
Two 1.3 mm screws
One 1.2 mm screw
Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray.
Press firmly to eject the tray.
Use an iFixit opening tool or a fingernail to disconnect the dual camera cable connectors by prying them straight up from their sockets.
Bu adımda kullanılan alet:Tweezers$4.99
Use a thin pry tool or tweezers to carefully pry up and disconnect the two coaxial cable connectors from the logic board.
Note: Make careful note which coaxial cable goes where before you disconnect them so that you can reconnect them properly. For example, one may be slightly longer than the other or have a different bend in its connector. Or you can put a piece of removable tape on the upper connector and remove it during reassembly.
Bu adımda kullanılan alet:iFixit Precision 4 mm Screwdriver Bit$2.99
Remove the seven screws securing the logic board:
One 1.3 mm Phillips screw
Two 2.1 mm standoff screws
One 2.0 mm standoff screw with a large head
One 2.0 mm standoff screw with a small head
Two 2.2 mm standoff screws
109 farklı kişi bu kılavuzu tamamladı.
22Kılavuz Yorumları
You can purchase motherboard from this website.
It's really tough to install Board component but this guideline really helpful..
