Neye ihtiyacın var
Power off your iPhone before beginning disassembly.
Remove the two 3.4 mm pentalobe screws on the bottom edge of the iPhone.
Use a spudger or a fingernail to disconnect the two lower display connectors by prying them straight up from their sockets on the logic board.
Use the flat end of a spudger to disconnect the rear-facing camera's press connector from its socket on the logic board.
Turn off your iPhone before starting to take it apart.
Remove the two 3.4 mm pentalobe screws at the bottom of your iPhone
Put the hot iOpener over the bottom of the phone to soften the adhesive that holds the display.
Remove the spudger from the left side of the iPhone and insert the flat end into the lower right corner of the device.
Rotate the spudger to widen the gap between the display assembly and the rear case.
Slide the flat end of the spudger to the right side of the phone to break the adhesive that holds the display in place.
Remove the following Y000 tri-wing screws from the connector lower bracket:
Three 1.2 mm screws
One 2.4 mm screw
Remove the connector lower bracket.
Use the flat end of a spudger or a fingernail to disconnect the two lower display connectors lifting them straight from their socket on the logic board.
Use the flat end of a spudger to detach the rear camera's pressure connector from its seat on the logic board.
To reassemble your device, Follow these instructions in reverse order.
Bu çevirmenlere özel teşekkürler:
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
