Ana içeriğe geç
iPhone Air Back Glass Replacement
Neye ihtiyacın var
  1. iPhone Air Back Glass Replacement, Prepare your phone for disassembly: adım 1, 2 resimden 1. iPhone Air Back Glass Replacement, Prepare your phone for disassembly: adım 1, 2 resimden 2.
    • Let your phone's battery drain below 25% before starting this repair—a charged lithium‑ion battery may catch fire if damaged.
    • Unplug any cables from your phone.
    • Hold the power and either volume button and slide to power off your phone.
    FixBot'a Sor
    Yorum Ekle
  2. iPhone Air Back Glass Replacement, Mark your opening picks: adım 2, 3 resimden 1. iPhone Air Back Glass Replacement, Mark your opening picks: adım 2, 3 resimden 2. iPhone Air Back Glass Replacement, Mark your opening picks: adım 2, 3 resimden 3.
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    FixBot'a Sor
    Yorum Ekle
  3. iPhone Air Back Glass Replacement, Cracked glass preparation: adım 3, 1 resimden 1.
    • Glass shards can complicate disassembly—or worse, cause injury. If your phone's back glass is cracked, follow this step.
    • Apply packing tape to the cracked glass until it's completely covered—this will help keep the glass contained and allow the suction cup to stick.
    • Make sure there's a single strip (not overlapping) of tape on the bottom edge, big enough for a suction cup to fit on.
    • Only cover the glass itself—don't stick any tape to the frame.
    • Consider wearing safety glasses to protect your eyes from any glass shaken free during the repair.
    FixBot'a Sor
    Yorum Ekle
  4. iPhone Air Back Glass Replacement, Remove the pentalobe screws: adım 4, 1 resimden 1.
    • Use a P2 pentalobe driver to remove the two 4.9 mm-long screws on either side of the USB-C port.
    FixBot'a Sor
    Yorum Ekle
  5. iPhone Air Back Glass Replacement, Heat the bottom edge: adım 5, 2 resimden 1. iPhone Air Back Glass Replacement, Heat the bottom edge: adım 5, 2 resimden 2.
    • Apply a heated iOpener to the bottom edge of the back glass for two minutes.
    • Alternatively, you can use a hair dryer or heat gun to heat the bottom edge of the back glass until it's slightly too hot to touch.
    • Improper use of a heat gun can destroy the display and/or battery—follow the linked instructions carefully.
    FixBot'a Sor
    Yorum Ekle
  6. iPhone Air Back Glass Replacement, Insert an opening pick: adım 6, 3 resimden 1. iPhone Air Back Glass Replacement, Insert an opening pick: adım 6, 3 resimden 2. iPhone Air Back Glass Replacement, Insert an opening pick: adım 6, 3 resimden 3.
    • Apply a suction handle to the bottom edge of the back glass, as close to the edge as possible.
    • Pull up on the handle with strong, steady force to create a gap between the back glass and the frame.
    • If the back glass doesn't budge, reheat it and try again.
    • Insert the tip of an opening pick into the gap.
    FixBot'a Sor
    Yorum Ekle
  7. iPhone Air Back Glass Replacement, Back glass information: adım 7, 2 resimden 1. iPhone Air Back Glass Replacement, Back glass information: adım 7, 2 resimden 2.
    • As you slice the adhesive securing the back glass in the next steps, be careful of the following areas:
    • There's a delicate cable connecting the back glass to the phone, right next to the volume up button.
    • There are multiple spring contacts along the top edge of the phone. Be extra careful not to insert your pick deeper than instructed in each step to avoid bending these contacts.
    FixBot'a Sor
    Yorum Ekle
  8. iPhone Air Back Glass Replacement, Separate the bottom edge adhesive: adım 8, 3 resimden 1. iPhone Air Back Glass Replacement, Separate the bottom edge adhesive: adım 8, 3 resimden 2. iPhone Air Back Glass Replacement, Separate the bottom edge adhesive: adım 8, 3 resimden 3.
    • Slide your pick back and forth along the bottom edge to separate the adhesive.
    • Leave your pick inserted in the bottom left corner to prevent the adhesive from resealing.
    FixBot'a Sor
    Yorum Ekle
  9. iPhone Air Back Glass Replacement, Heat the left edge: adım 9, 1 resimden 1.
    • Apply a heated iOpener to the left edge of the back glass for two minutes.
    • When using a hair dryer or heat gun, only heat the back glass until it's hot to the touch.
    FixBot'a Sor
    Yorum Ekle
  10. iPhone Air Back Glass Replacement, Separate the left edge adhesive: adım 10, 3 resimden 1. iPhone Air Back Glass Replacement, Separate the left edge adhesive: adım 10, 3 resimden 2. iPhone Air Back Glass Replacement, Separate the left edge adhesive: adım 10, 3 resimden 3.
    • Insert a second opening pick to the left of the original.
    • Slide the second pick around the bottom left corner and along the left edge of the back glass to separate the adhesive and release the metal clip.
    • Leave this pick inserted at the top left corner to prevent the adhesive from resealing.
    FixBot'a Sor
    Yorum Ekle
  11. iPhone Air Back Glass Replacement, Heat the right edge: adım 11, 1 resimden 1.
    • Apply a heated iOpener to the right edge of the back glass for two minutes.
    FixBot'a Sor
    Yorum Ekle
  12. iPhone Air Back Glass Replacement, Separate the right edge adhesive: adım 12, 3 resimden 1. iPhone Air Back Glass Replacement, Separate the right edge adhesive: adım 12, 3 resimden 2. iPhone Air Back Glass Replacement, Separate the right edge adhesive: adım 12, 3 resimden 3.
    • Don't insert your pick deeper than 3 mm along the right edge to avoid damaging the ribbon cable.
    • Insert a third opening pick to the right of the original at the bottom edge.
    • Slide this pick around the bottom right corner and along the right edge of the back glass to separate the adhesive and release the metal clip.
    • Leave this pick inserted at the top right corner to prevent the adhesive from resealing.
    FixBot'a Sor
    Yorum Ekle
  13. iPhone Air Back Glass Replacement, Separate the top edge adhesive: adım 13, 3 resimden 1. iPhone Air Back Glass Replacement, Separate the top edge adhesive: adım 13, 3 resimden 2. iPhone Air Back Glass Replacement, Separate the top edge adhesive: adım 13, 3 resimden 3.
    • Don't insert your pick deeper than 3 mm along the top edge to avoid damaging the spring contacts.
    • Repeat the heating and sliding process along the top edge of the back glass to separate the adhesive and release the metal clips.
    FixBot'a Sor
    Yorum Ekle
  14. iPhone Air Back Glass Replacement, Swing open the back glass: adım 14, 3 resimden 1. iPhone Air Back Glass Replacement, Swing open the back glass: adım 14, 3 resimden 2. iPhone Air Back Glass Replacement, Swing open the back glass: adım 14, 3 resimden 3.
    • Don't try to fully remove the back glass just yet—it's still attached with a delicate ribbon cable.
    • If the back glass doesn't swing open easily, don't force it—go back around the perimeter with your pick to separate missed sections of adhesive or stuck clips.
    • Gently lift the back glass and swing it open towards the volume buttons.
    • Support the back glass with a clean, sturdy object like a small box to avoid straining the cable.
    FixBot'a Sor
    Yorum Ekle
  15. iPhone Air Back Glass Replacement, Protect the rear camera: adım 15, 1 resimden 1.
    • We recommend using polyimide (aka kapton) tape to keep the camera lens clean. If you don't have any, you may skip this step, but be extra careful not to touch the camera.
    • Set a piece of polyimide tape over the rear camera lens.
    • Don't press down on the rear camera.
    • During reassembly, carefully remove the tape without jostling the rear camera—its stabilizing mechanism is extremely fragile.
    FixBot'a Sor
    Yorum Ekle
  16. iPhone Air Back Glass Replacement, Remove the left connector cover: adım 16, 2 resimden 1. iPhone Air Back Glass Replacement, Remove the left connector cover: adım 16, 2 resimden 2.
    • Remove the three screws securing the left connector cover, located below the rear camera:
    • One 1.1 mm-long tri-point Y000 screw
    • One 1.0 mm-long tri-point Y000 screw
    • One 3.2 mm-long JIS 00 screw
    • Small iFixit Phillips bits are designed to work with JIS screws, so you can use an iFixit PH 00 driver. You can try Phillips drivers from other manufacturers, but you risk stripping the screw.
    FixBot'a Sor
    Yorum Ekle
  17. iPhone Air Back Glass Replacement: adım 17, 3 resimden 1. iPhone Air Back Glass Replacement: adım 17, 3 resimden 2. iPhone Air Back Glass Replacement: adım 17, 3 resimden 3.
    • Use tweezers or your fingers to lift the cover to release its hook and remove it.
    • During reassembly, insert the cover's hook into its slot on the logic board at an angle, then lay the cover flat.
    FixBot'a Sor
    Yorum Ekle
  18. iPhone Air Back Glass Replacement, Disconnect the battery: adım 18, 2 resimden 1. iPhone Air Back Glass Replacement, Disconnect the battery: adım 18, 2 resimden 2.
    • Use the point of a spudger to pry up and disconnect the battery press connector.
    • During reassembly, align the connector carefully over its socket and press down with your fingertip or the flat end of a spudger—first on one side, then the other—until it clicks into place. Don't try to force the connector into place. If you're having trouble, reposition it and try again.
    FixBot'a Sor
    Yorum Ekle
  19. iPhone Air Back Glass Replacement, Remove the right connector cover: adım 19, 2 resimden 1. iPhone Air Back Glass Replacement, Remove the right connector cover: adım 19, 2 resimden 2.
    • Remove the three screws securing the right connector cover:
    • Two 1.1 mm-long tri-point Y000 screws
    • One 2.8 mm-long JIS 00 screw
    FixBot'a Sor
    Yorum Ekle
  20. iPhone Air Back Glass Replacement: adım 20, 3 resimden 1. iPhone Air Back Glass Replacement: adım 20, 3 resimden 2. iPhone Air Back Glass Replacement: adım 20, 3 resimden 3.
    FixBot'a Sor
    Yorum Ekle
  21. iPhone Air Back Glass Replacement, Disconnect the back glass: adım 21, 2 resimden 1. iPhone Air Back Glass Replacement, Disconnect the back glass: adım 21, 2 resimden 2.
    • Use the point of a spudger to pry up and disconnect the flash and wireless charging coil press connector.
    FixBot'a Sor
    Yorum Ekle
  22. iPhone Air Back Glass Replacement, Remove the back glass: adım 22, 2 resimden 1. iPhone Air Back Glass Replacement, Remove the back glass: adım 22, 2 resimden 2.
    • Remove the back glass.
    • Follow this guide to replace the adhesive and install the back glass.
    FixBot'a Sor
    Yorum Ekle
Sonuç
To reassemble your iPhone, follow this guide to reapply adhesive and install the back glass.
After your repair, calibrate a genuine replacement back glass using Apple's Repair Assistant. Navigate to Settings General About Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone Air Answers Community for help.
8 farklı kişi bu kılavuzu tamamladı.
Nick Schultz
58.636 İtibar
318 adet Kılavuz yazıldı
1Rehber Yorum
Thanks for the information
jorge torres - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 32
Son 7 gün: 235
Son 30 gün: 1,045
Her zaman: 10,810
