Ana içeriğe geç
iPhone SE Home Button Replacement
Neye ihtiyacın var
Videoya Genel Bakış
  1. iPhone SE Home Button Replacement, Removing the Pentalobe screws: adım 1, 1 resimden 1.
    • Before you proceed, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.9 mm Pentalobe screws from either side of Lightning connector.
    FixBot'a Sor
    Yorum Ekle
  2. iPhone SE Home Button Replacement, Taping the display glass: adım 2, 3 resimden 1. iPhone SE Home Button Replacement, Taping the display glass: adım 2, 3 resimden 2. iPhone SE Home Button Replacement, Taping the display glass: adım 2, 3 resimden 3.
    • Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    FixBot'a Sor
    Yorum Ekle
  3. iPhone SE Home Button Replacement, Display separation prevention: adım 3, 3 resimden 1. iPhone SE Home Button Replacement, Display separation prevention: adım 3, 3 resimden 2. iPhone SE Home Button Replacement, Display separation prevention: adım 3, 3 resimden 3.
    • In the following steps you will be pulling the display up out of the phone body. The display is composed of a glass screen and a plastic bezel with metal clips.
    • Regardless of the tool you use, you need to be sure you pull up the entire display.
    • If the glass begins to separate from the plastic, as shown in the first image, slide a plastic opening tool between the plastic frame and the metal phone body to pry the metal clips out of the case.
    • If you are reassembling a phone with a separated display bezel, you may want to place a thin strip of adhesive between the plastic bezel and the glass to keep the phone closed.
    FixBot'a Sor
    Yorum Ekle
  4. iPhone SE Home Button Replacement, Anti-Clamp instructions: adım 4, 3 resimden 1. iPhone SE Home Button Replacement, Anti-Clamp instructions: adım 4, 3 resimden 2. iPhone SE Home Button Replacement, Anti-Clamp instructions: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    Clampy - Anti-Clamp
    $24.95
    • The next two steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down two steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use the included tape pad to create a grippier surface.
    FixBot'a Sor
    Yorum Ekle
  5. iPhone SE Home Button Replacement: adım 5, 3 resimden 1. iPhone SE Home Button Replacement: adım 5, 3 resimden 2. iPhone SE Home Button Replacement: adım 5, 3 resimden 3.
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time and wait a few seconds between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next two steps.
    FixBot'a Sor
    Yorum Ekle
  6. iPhone SE Home Button Replacement, Manual Opening Procedure: adım 6, 1 resimden 1.
    • If you don't have an Anti-Clamp, use a single suction cup to lift the front panel:
    • Press a suction cup onto the screen, just above the home button.
    • Be sure the cup is completely on the screen to get a tight seal.
    FixBot'a Sor
    Yorum Ekle
  7. iPhone SE Home Button Replacement, Start lifting the front panel assembly: adım 7, 1 resimden 1.
    • The front panel is attached with clips, and there are several ribbon cables connecting it to the rest of the phone. Your goal here is to release the clips and open the phone only enough to disconnect the cables. Go slowly and carefully to avoid damage.
    • Make sure the suction cup is firmly attached to the front panel assembly near the home button.
    • While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the home button end of the front panel from the rear case.
    • With a plastic opening tool, gently pry the edges of the rear case down, away from the front panel assembly, while you pull up with the suction cup.
    • Take your time and apply firm, constant force. The front panel assembly is a much tighter fit than on most other devices.
    FixBot'a Sor
    Yorum Ekle
  8. iPhone SE Home Button Replacement: adım 8, 2 resimden 1. iPhone SE Home Button Replacement: adım 8, 2 resimden 2.
    • Do not try to completely remove the front panel assembly from the rear case, as there are several delicate ribbon cables connecting them.
    • Pull the plastic nub to release the vacuum seal on the suction cup.
    • Remove the suction cup from the screen.
    FixBot'a Sor
    Yorum Ekle
  9. iPhone SE Home Button Replacement, Removing the Touch ID cable bracket: adım 9, 3 resimden 1. iPhone SE Home Button Replacement, Removing the Touch ID cable bracket: adım 9, 3 resimden 2. iPhone SE Home Button Replacement, Removing the Touch ID cable bracket: adım 9, 3 resimden 3.
    • Open the phone just enough to reveal the metal bracket covering the home button cable.
    • Do not open the phone too far or you risk damaging the home button cable, or the socket it plugs into. Keep the cable loose—if it is stretched out, that's too far.
    • Only the phone's original home button assembly will be capable of using the Touch ID functionality. If you rip the cable, installing a new home button will only restore ordinary home button functions, not the Touch ID features.
    • Use the tip of a spudger to push the bracket free and remove it with tweezers.
    • The next two steps apply to reassembly. Skip them and continue to Step 12 until reassembly.
    FixBot'a Sor
    Yorum Ekle
  10. iPhone SE Home Button Replacement: adım 10, 2 resimden 1. iPhone SE Home Button Replacement: adım 10, 2 resimden 2.
    • During reassembly, you will need to reinstall the Touch ID cable bracket. The top of the bracket needs to slide between the battery and Touch ID cable connector, in front of the metal tab. The bottom must latch down over the connector.
    • Slide the top of the bracket over the Touch ID cable connector from left to right.
    • Alternatively, lay the bracket directly over the connector. The edge with the "leg" will prop the bracket up at a slight angle, and the opposite edge must be between the cable connector and the metal tab near the battery. With the edge of a spudger flat against the bracket, apply gentle downward pressure to snap in the back and front clasps.
    FixBot'a Sor
    Yorum Ekle
  11. iPhone SE Home Button Replacement: adım 11, 2 resimden 1. iPhone SE Home Button Replacement: adım 11, 2 resimden 2.
    • During reassembly, use the flat end of a spudger to snap the front portion of the Touch ID cable bracket down over the cable connector.
    • If the bracket does not snap down flush, you may need to remove the bracket and slide it over the cable connector again for a better fit.
    FixBot'a Sor
    Yorum Ekle
  12. iPhone SE Home Button Replacement, Disconnecting the home button cable connector: adım 12, 2 resimden 1. iPhone SE Home Button Replacement, Disconnecting the home button cable connector: adım 12, 2 resimden 2.
    • Use the tip of a spudger to pry the home button cable connector up out of its socket.
    • Be sure you're separating the cable connector from its socket, and not prying the entire socket up. The socket is on its own glued-down cable that can be pried up if you aren't careful.
    FixBot'a Sor
    Yorum Ekle
  13. iPhone SE Home Button Replacement, Opening up the phone: adım 13, 3 resimden 1. iPhone SE Home Button Replacement, Opening up the phone: adım 13, 3 resimden 2. iPhone SE Home Button Replacement, Opening up the phone: adım 13, 3 resimden 3.
    • Once the connector has been released, pull the home button end of the assembly away from the rear case, using the top of the phone as a hinge.
    • Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
    • Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
    • In a pinch, you can use an unopened canned beverage to hold the display.
    FixBot'a Sor
    Yorum Ekle
  14. iPhone SE Home Button Replacement: adım 14, 1 resimden 1.
    • Remove the two 1.6 mm Phillips #000 screws securing the metal battery connector bracket to the logic board.
    FixBot'a Sor
    Yorum Ekle
  15. iPhone SE Home Button Replacement: adım 15, 1 resimden 1.
    • Remove the metal battery connector bracket from the iPhone.
    FixBot'a Sor
    Yorum Ekle
  16. iPhone SE Home Button Replacement: adım 16, 2 resimden 1. iPhone SE Home Button Replacement: adım 16, 2 resimden 2.
    • Use the flat end of a spudger to gently pry the battery connector up from its socket on the logic board.
    • Be very careful to only pry up on the battery connector itself and not the socket on the logic board. If you pry up on the logic board socket or the board itself, you may destroy the socket or damage nearby components on the board.
    FixBot'a Sor
    Yorum Ekle
  17. iPhone SE Home Button Replacement: adım 17, 1 resimden 1.
    • Remove the following screws securing the front panel assembly cable bracket to the logic board:
    • One 1.7 mm Phillips #000 screw
    • One 1.2 mm Phillips #000 screw
    • One 1.3 mm Phillips #000 screw
    • One more 1.7 mm Phillips #000 screw
    • This 1.7 mm screw tends to not be attracted to a magnetized screwdriver. Take care not to lose it when removing.
    • It is especially important to keep track of your screws in this step for reassembly. Accidentally using the 1.3 mm screw or one of the 1.7 mm screws in the bottom right hole will result in significant damage to the logic board causing the phone to no longer boot properly.
    • Be careful not to over-tighten the screws, and don't force them. If they don't fit easily when you are securing them, they may be the wrong size.
    FixBot'a Sor
    Yorum Ekle
  18. iPhone SE Home Button Replacement: adım 18, 1 resimden 1.
    • Remove the front panel assembly cable bracket from the logic board.
    FixBot'a Sor
    Yorum Ekle
  19. iPhone SE Home Button Replacement: adım 19, 2 resimden 1. iPhone SE Home Button Replacement: adım 19, 2 resimden 2.
    • Use a spudger or a fingernail to disconnect the front-facing camera and sensor cable.
    FixBot'a Sor
    Yorum Ekle
  20. iPhone SE Home Button Replacement: adım 20, 2 resimden 1. iPhone SE Home Button Replacement: adım 20, 2 resimden 2.
    • Make sure the battery is disconnected before you disconnect or reconnect the cable in this step.
    • Disconnect the LCD cable connector.
    • When reassembling your phone, the LCD cable may pop off the connector. This can result in white lines or a blank screen when powering your phone back on. If that happens, simply reconnect the cable and power cycle your phone. The best way to power cycle your phone is to disconnect and reconnect the battery.
    FixBot'a Sor
    Yorum Ekle
  21. iPhone SE Home Button Replacement: adım 21, 2 resimden 1. iPhone SE Home Button Replacement: adım 21, 2 resimden 2.
    • Finally, disconnect the digitizer cable connector.
    FixBot'a Sor
    Yorum Ekle
  22. iPhone SE Home Button Replacement: adım 22, 1 resimden 1.
    • Remove the front panel assembly from the rear case.
    FixBot'a Sor
    Yorum Ekle
  23. iPhone SE Home Button Replacement, Home Button Assembly: adım 23, 2 resimden 1. iPhone SE Home Button Replacement, Home Button Assembly: adım 23, 2 resimden 2.
    • Unscrew the single captive Phillips #000 screw securing the home button cable.
    • The captive screw is fastened to the home button cable by a spring contact backing. During reassembly, ensure the contact is in the correct orientation—on the side of the screw nearest the LCD.
    • If your replacement part does not have this captive screw and spring contact, you will need to transfer them to the new cable.
    FixBot'a Sor
    Yorum Ekle
  24. iPhone SE Home Button Replacement: adım 24, 2 resimden 1. iPhone SE Home Button Replacement: adım 24, 2 resimden 2.
    • Fold the home button cable down, out of the way of the home button bracket.
    FixBot'a Sor
    Yorum Ekle
  25. iPhone SE Home Button Replacement: adım 25, 1 resimden 1.
    • Remove the two 1.4 mm Phillips #000 screws from the home button bracket.
    FixBot'a Sor
    Yorum Ekle
  26. iPhone SE Home Button Replacement: adım 26, 1 resimden 1.
    • Remove the home button bracket from the display assembly.
    FixBot'a Sor
    Yorum Ekle
  27. iPhone SE Home Button Replacement: adım 27, 2 resimden 1. iPhone SE Home Button Replacement: adım 27, 2 resimden 2.
    • Wedge the the tip of a spudger underneath the home button cable assembly.
    • The home button cable is affixed by mild adhesive.
    • Gently work the spudger underneath the cable to separate the home button cable from the front panel assembly.
    • Do not remove the home button yet, as it is still attached to the front panel assembly.
    FixBot'a Sor
    Yorum Ekle
  28. iPhone SE Home Button Replacement: adım 28, 2 resimden 1. iPhone SE Home Button Replacement: adım 28, 2 resimden 2.
    • If necessary, remove the tape over the home button on the front side of your cracked front panel assembly.
    • Gently push the top left corner of the home button up away from the front panel.
    • Do not push the home button all the way through—you only need to get a corner free, so that you can pry it free with a spudger.
    • This membrane is very thin. If you feel like you're going to tear the button, apply heat and try again.
    FixBot'a Sor
    Yorum Ekle
  29. iPhone SE Home Button Replacement: adım 29, 2 resimden 1. iPhone SE Home Button Replacement: adım 29, 2 resimden 2.
    • Peel the home button the rest of the way off of the display by prying gently with a spudger.
    FixBot'a Sor
    Yorum Ekle
  30. iPhone SE Home Button Replacement: adım 30, 1 resimden 1.
    • Remove the home button assembly from the front panel.
    FixBot'a Sor
    Yorum Ekle
  31. iPhone SE Home Button Replacement, Home Button: adım 31, 2 resimden 1. iPhone SE Home Button Replacement, Home Button: adım 31, 2 resimden 2.
    • You may have to transfer the home button gasket to your replacement home button assembly.
    • Using a set of tweezers, gently peel the gasket off of the home button.
    • The gasket is very thin; if you feel it begin to tear, stop peeling and apply heat before proceeding.
    FixBot'a Sor
    Yorum Ekle
  32. iPhone SE Home Button Replacement: adım 32, 1 resimden 1.
    • Thread the gasket off of the ribbon cable.
    • Removing the gasket over the home button risks stretching or cutting the thin gasket.
    FixBot'a Sor
    Yorum Ekle
Sonuç
100 farklı kişi bu kılavuzu tamamladı.
Sam Goldheart
477.698 İtibar
538 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
28.236 adet Kılavuz yazıldı
20Kılavuz Yorumları
Is there a reason why the Touch ID feature will not work after replacing the home button? Wouldn't all the programming that has to do with it be in the software in the phone?
Shaun - Yanıt Paylaş
Unfortunately the Touch ID is built into each home button and paired to that specific logic board. This is why it is extremely important to pay attention to that flex cable. Good Luck.
Eddie - Yanıt Paylaş
I unfortunately tore my home button cable while replacing the battery. If I purchased a used fair condition operational phone, and transferred the motherboard and the home button to my mint condition case, shouldn’t the Touch ID work?
schuft - Yanıt Paylaş
@schuft That’s a fairly involved repair, but yes! Should work fine if done carefully. Remember to verify that Touch ID works correctly on the new/donor phone before disassembling anything.
Jeff Suovanen - Yanıt Paylaş
Is it the same as the 53 error iPhone 6 problem?
Muhannad Alwani - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 15
Son 7 gün: 107
Son 30 gün: 613
Her zaman: 215,553
