Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
Use this guide to replace a broken or non-functioning main camera in your iPhone SE.
The camera is not compatible with an iPhone 5s part.
Neye ihtiyacın var
Power off your iPhone before beginning disassembly.
Remove the two 3.9 mm Pentalobe screws from either side of Lightning connector.
If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping the glass.
Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered.
Regardless of the tool you use, you need to be sure you pull up the entire display.
If the glass begins to separate from the plastic, as shown in the first image, slide a plastic opening tool between the plastic frame and the metal phone body to pry the metal clips out of the case.
Bu adımda kullanılan alet:Anti-Clamp$24.95
Pull the blue handle backwards to unlock the Anti-Clamp's arms.
Slide the arms over either the left or right edge of your iPhone.
Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
Squeeze the cups together to apply suction to the desired area.
If you don't have an Anti-Clamp, use a single suction cup to lift the front panel:
Press a suction cup onto the screen, just above the home button.
While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the home button end of the front panel from the rear case.
With a plastic opening tool, gently pry the edges of the rear case down, away from the front panel assembly, while you pull up with the suction cup.
Bu adımda kullanılan alet:Tweezers$4.99
Open the phone just enough to reveal the metal bracket covering the home button cable.
Only the phone's original home button assembly will be capable of using the Touch ID functionality. If you rip the cable, installing a new home button will only restore ordinary home button functions, not the Touch ID features.
Use the tip of a spudger to push the bracket free and remove it with tweezers.
Use the tip of a spudger to pry the home button cable connector up out of its socket.
Once the connector has been released, pull the home button end of the assembly away from the rear case, using the top of the phone as a hinge.
Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
50 farklı kişi bu kılavuzu tamamladı.
9 Yorum
Hello, I have a problem: I have removed the camera to clean it from dust. That was ok. But as I removed the screws in step 17 I scratched the black sticker pad on the cpu-cover. (In my iphone SE there is no label with a QR-code like on the pictures above. Instead there is something like a black pad / upholster that I scratched.) Is that a problem or is which function has that pad? (Please excuse my poor english, I am not a native speaker.) Thanks!
Super Anleitung,
habe meine Linse von innen gereinigt, da sich dort Staub gesammelt hatte. Hab dazu ein Wattestäbchen und etwas Isopropanol benutzt.
es wäre gut ein oder zei kleine Schreauben mitzuliefern, da diese extrem leicht kaputt gehen
Danke
sonst hat es toll geklappt
