Ana içeriğe geç
iPod Touch 6th Generation Display Assembly Replacement
Arşivlenmiş Kılavuz
Bu kılavuz sadece arşivsel amaçlarla muhafaza edilmiştir. Onarımınızı gerçekleştirmek için kılavuzun güncel halini kullanın.
Neye ihtiyacın var
    1. iPod Touch 6th Generation Display Assembly Replacement, Power Off device: adım 1, 2 resimden 1. iPod Touch 6th Generation Display Assembly Replacement, Power Off device: adım 1, 2 resimden 2.
      • Make sure you iPod is powered off before starting the repair
      • Hold the Sleep/Wake Button (Power Button) for about 3-5 seconds.
      FixBot'a Sor
      Yorum Ekle
    2. iPod Touch 6th Generation Display Assembly Replacement, Front Pannel: adım 2, 1 resimden 1.
      • If your display is cracked to prevent you from cutting your self we recommend you place clear duck tape over the screen until all the cracks are fully covered.
      • Wear Safety glasses to prevent glass from from going into your eyes
      FixBot'a Sor
      Yorum Ekle
    3. iPod Touch 6th Generation Display Assembly Replacement: adım 3, 1 resimden 1.
      • The bottom of the screen is held in place with adhesive.
      • Use the iOpener or Heat gun to soften the adhesive
      • Alternatively you can use an Hair dyer
      • As you start to prying the screen off, you may need to apply more heat
      FixBot'a Sor
      Yorum Ekle
    4. iPod Touch 6th Generation Display Assembly Replacement, Opening the iPod: adım 4, 2 resimden 1. iPod Touch 6th Generation Display Assembly Replacement, Opening the iPod: adım 4, 2 resimden 2.
      • Place a suction cup just above the home button, towards the lower section of the glass.
      • Press it firmly to ensure the cup has a strong seal.
      • Hold iPod firmly on a hard surface
      • To prevent you from breaking the ribbon cables connected to the LCD, Place your thumb and index finger over the lower corners of the display to stop the display from opening too far.
      • Start to Lift the suction cup, and start to firmly pull constantly until the adhesive breaks, and the display comes up from the rear case.
      • When lifting the screen apart if adhesive is still sticking to the display you may get a razor blade to cut the adhesive.
      • Be careful not to lift more than about an inch—a fragile plastic frame still connects the display assembly to the rear case.
      FixBot'a Sor
      Yorum Ekle
    5. iPod Touch 6th Generation Display Assembly Replacement: adım 5, 2 resimden 1. iPod Touch 6th Generation Display Assembly Replacement: adım 5, 2 resimden 2.
      • In this part we will be losing and freeing the Bezel (The plastic Frame) that surround the screen.
      • Start at the top of the Bezel, Using a plastic opening tool, insert it into the gap between the plastic frame and the rear case.
      • Slid to tool down the Bezel to loosen it from the case.
      FixBot'a Sor
      Yorum Ekle
    6. iPod Touch 6th Generation Display Assembly Replacement: adım 6, 2 resimden 1. iPod Touch 6th Generation Display Assembly Replacement: adım 6, 2 resimden 2.
      • Insert the plastic opening tool between the frame and the rear case behind the first clip.
      • Rock the tool sideways, to spread the gap behind the clip and separate it from the rear case.
      • Initially this may not free the clip , but by repeating the procedure for each clip, it will begin to loosen the piece.
      • Repeat the procedure with the next two clips on that side
      • You may have to go back and forth between the clips to free all of them. Be patient, as the plastic frame is quite fragile.
      FixBot'a Sor
      Yorum Ekle
    7. iPod Touch 6th Generation Display Assembly Replacement: adım 7, 3 resimden 1. iPod Touch 6th Generation Display Assembly Replacement: adım 7, 3 resimden 2. iPod Touch 6th Generation Display Assembly Replacement: adım 7, 3 resimden 3.
      • Moving onto the left side of the bezel, insert the plastic opening tool into the gap between the frame and the rear case near the top.
      • Now slide the tool down, loosening the frame from the case.
      FixBot'a Sor
      Yorum Ekle
    8. iPod Touch 6th Generation Display Assembly Replacement: adım 8, 2 resimden 1. iPod Touch 6th Generation Display Assembly Replacement: adım 8, 2 resimden 2.
      FixBot'a Sor
      Yorum Ekle
    9. iPod Touch 6th Generation Display Assembly Replacement: adım 9, 3 resimden 1. iPod Touch 6th Generation Display Assembly Replacement: adım 9, 3 resimden 2. iPod Touch 6th Generation Display Assembly Replacement: adım 9, 3 resimden 3.
      • Insert the plastic opening tool between the display assembly and the rear case near the top of the iPod.
      • Barley twist the opening tool to lift the front panel up from the rear case.
      • Separate the display assembly from the iPod.
      • Don't try to remove the Front panel, because there are still many cables connected to it.
      FixBot'a Sor
      Yorum Ekle
    10. iPod Touch 6th Generation Display Assembly Replacement, LCD Shield Plate: adım 10, 2 resimden 1. iPod Touch 6th Generation Display Assembly Replacement, LCD Shield Plate: adım 10, 2 resimden 2.
      • Carefully fold the display over away from the rest of the iPod, watching out not to disconnect or break any of the ribbon cables. Set the two halves flat on a flat surface
      • Use a plastic opening tool to pry the home button switch up from the LCD Plate
      • You may need to use a heat gun or hair dryer to soften the adhesive on the back of the home button. (Use a low heat setting)
      • Do not try to remove the home button switch, because it is connected to components below the LCD plate.
      FixBot'a Sor
      Yorum Ekle
    11. iPod Touch 6th Generation Display Assembly Replacement: adım 11, 1 resimden 1.
      • Remove the following screws securing the LCD plate to the rear case:
      • Two 1.2 mm #00 Phillips screws
      • Nine 1.6 mm #00 Phillips screws
      • One 2.3 mm #00 Phillips screw
      FixBot'a Sor
      Yorum Ekle
    12. iPod Touch 6th Generation Display Assembly Replacement: adım 12, 2 resimden 1. iPod Touch 6th Generation Display Assembly Replacement: adım 12, 2 resimden 2.
      • Lift up the LCD plate to remove it
      FixBot'a Sor
      Yorum Ekle
    13. iPod Touch 6th Generation Display Assembly Replacement, Battery: adım 13, 1 resimden 1.
      • Remove three 1.6 mm #00 Phillips screws that are securing the logic board onto the rear case.
      FixBot'a Sor
      Yorum Ekle
    14. iPod Touch 6th Generation Display Assembly Replacement, Heat the back of the iPod: adım 14, 1 resimden 1.
      • There are two strips of adhesive holding the battery onto the rear case.
      • Do not heat the battery!!
      • Turn the iPod to the back were you can see the Apple logo and apply heat there to soften adhesive
      • The rear case does not have to be hot, you should be able to touch it without felling discomfort
      FixBot'a Sor
      Yorum Ekle
    15. iPod Touch 6th Generation Display Assembly Replacement: adım 15, 2 resimden 1. iPod Touch 6th Generation Display Assembly Replacement: adım 15, 2 resimden 2.
      • There are three notches on either side of the battery. In the next steps, you will be using these notches to gradually pry the battery up from the rear case.
      • The battery is secured with a lot of adhesive, so you'll need to go slowly and carefully to avoid puncturing or creasing the battery.
      • Insert a plastic opening tool into the top right notch and gently pry up on the battery.
      • Don't try to attempt to pry up the entire battery at this point, just slowly start to loosen the adhesive at each point.
      • Continue with the lower right notch. Insert a plastic opening tool into the notch, and gently lift up on the side of the battery.
      FixBot'a Sor
      Yorum Ekle
    16. iPod Touch 6th Generation Display Assembly Replacement: adım 16, 1 resimden 1.
      • Continue prying up the battery from the bottom.
      • When prying along the bottom, be careful not to press down too hard against the speaker or headphone jack.
      FixBot'a Sor
      Yorum Ekle
    17. iPod Touch 6th Generation Display Assembly Replacement: adım 17, 2 resimden 1. iPod Touch 6th Generation Display Assembly Replacement: adım 17, 2 resimden 2.
      • Pry along the left side as well.
      FixBot'a Sor
      Yorum Ekle
    18. iPod Touch 6th Generation Display Assembly Replacement: adım 18, 3 resimden 1. iPod Touch 6th Generation Display Assembly Replacement: adım 18, 3 resimden 2. iPod Touch 6th Generation Display Assembly Replacement: adım 18, 3 resimden 3.
      • Once all of the adhesive is loose, lift the battery up from the bottom and sway it out over the left side of the rear case.
      • Make sure not to pull it out because it is soldered onto the logic board.
      • Once battery is out of case turn the battery over to straighten its cable and set it down.
      FixBot'a Sor
      Yorum Ekle
    19. iPod Touch 6th Generation Display Assembly Replacement, Front facing camera: adım 19, 2 resimden 1. iPod Touch 6th Generation Display Assembly Replacement, Front facing camera: adım 19, 2 resimden 2.
      • Get a spudger and use the flat end of it to take out facing camera out of its socket in the display assembly.
      FixBot'a Sor
      Yorum Ekle
    20. iPod Touch 6th Generation Display Assembly Replacement, Lighting connector assembly: adım 20, 1 resimden 1.
      • Use the tip of a spudger to peel back a piece of tape covering a screw on the side of the headphone jack.
      FixBot'a Sor
      Yorum Ekle
    21. iPod Touch 6th Generation Display Assembly Replacement: adım 21, 1 resimden 1.
      • Remove the following screws securing the headphone jack, Lightning connector, and speaker.
      • Three 2.6 mm #00 Phillips screws
      • Two 2.0 mm #00 Phillips screws
      FixBot'a Sor
      Yorum Ekle
    22. iPod Touch 6th Generation Display Assembly Replacement: adım 22, 1 resimden 1.
      • Use the flat end of a spudger to lift the speaker up from the rear case.
      • Do not try to remove the speaker, because it is soldered to the Lightning connector assembly.
      FixBot'a Sor
      Yorum Ekle
    23. iPod Touch 6th Generation Display Assembly Replacement: adım 23, 1 resimden 1.
      • Gripping the large ribbon cable, gently pull the Lightning connector assembly out of the bottom of the case.
      FixBot'a Sor
      Yorum Ekle
    24. iPod Touch 6th Generation Display Assembly Replacement, Display Assembly: adım 24, 2 resimden 1. iPod Touch 6th Generation Display Assembly Replacement, Display Assembly: adım 24, 2 resimden 2.
      • Flip the entire assembly over, showing the back of the logic board.
      • Use a plastic opening tool to disconnect the digitizer cable from the logic board.
      FixBot'a Sor
      Yorum Ekle
    25. iPod Touch 6th Generation Display Assembly Replacement: adım 25, 2 resimden 1. iPod Touch 6th Generation Display Assembly Replacement: adım 25, 2 resimden 2.
      • Use a plastic opening tool to disconnect the display cable from its socket.
      FixBot'a Sor
      Yorum Ekle
    26. iPod Touch 6th Generation Display Assembly Replacement: adım 26, 3 resimden 1. iPod Touch 6th Generation Display Assembly Replacement: adım 26, 3 resimden 2. iPod Touch 6th Generation Display Assembly Replacement: adım 26, 3 resimden 3.
      • Flip the Lightning connector/logic board assembly back over to expose the top of the logic board.
      • The display cable is lightly adhered to the top of the logic board.
      • Use the flat end of a spudger to peel the display cable up from the logic board.
      FixBot'a Sor
      Yorum Ekle
    27. iPod Touch 6th Generation Display Assembly Replacement: adım 27, 2 resimden 1. iPod Touch 6th Generation Display Assembly Replacement: adım 27, 2 resimden 2.
      • Finally remove the display assembly from the iPod
      • You can use an iPod touch 5 LCD on the iPod touch 6 the're exactly the same.
      FixBot'a Sor
      Yorum Ekle
Sonuç
17 farklı kişi bu kılavuzu tamamladı.
Aiden
1.650 İtibar
2 adet Kılavuz yazıldı
Ekip
Aiden's Tech Repairs Aiden's Tech Repairs üyesi
Business
1 Üye
8 adet Kılavuz yazıldı
2Kılavuz Yorumları
This is a very comprehensive guide, but it is way beyond me.
I’d rather live with erratic behaviour in my current iPod, or ditch it and rely on my Android cell-phone for the same functions.
Paul Terni - Yanıt Paylaş
Does this also apply to battery removal?
bliss - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 10
Son 7 gün: 46
Son 30 gün: 231
Her zaman: 17,726
