Ana içeriğe geç
iRobot Roomba 551 Battery Replacement
Neye ihtiyacın var
  1. iRobot Roomba 551  Battery Replacement, Side Brush: adım 1, 1 resimden 1.
    • Place your Roomba upside-down on a hard surface.
    If all you need off is the faceplate, skip all of the screwdriver-based steps, and just remove the dirt bin(step 7) and start from step 11 at the rear.
    David Forrest - Yanıt
  2. iRobot Roomba 551  Battery Replacement: adım 2, 1 resimden 1.
    • While holding the side brush in place, use a Phillips #1 screwdriver to remove the 4.5mm screw from the center of the brush.
  3. iRobot Roomba 551  Battery Replacement: adım 3, 1 resimden 1.
    • Gently pull upwards on the brush to remove it.
  4. iRobot Roomba 551  Battery Replacement, Bottom Plate: adım 4, 1 resimden 1.
    • Rotate the Roomba upside-down so the bottom is facing towards you.
  5. iRobot Roomba 551  Battery Replacement: adım 5, 2 resimden 1. iRobot Roomba 551  Battery Replacement: adım 5, 2 resimden 2.
    • Using a Phillips #2 screwdriver, remove the captive screws that hold the bottom plate in place.
  6. iRobot Roomba 551  Battery Replacement: adım 6, 1 resimden 1.
    • Carefully lift the bottom plate.
    • The battery is only secured in place by the bottom plate, and may fall out once the bottom plate is removed.
  7. iRobot Roomba 551  Battery Replacement, Battery: adım 7, 2 resimden 1. iRobot Roomba 551  Battery Replacement, Battery: adım 7, 2 resimden 2.
    • Lift and remove the old battery by pulling the tabs on both sides.
    • Gently replace with a new battery.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Deborah Newberry
623 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 13-14, Regan Winter 2014 Cal Poly, Team 13-14, Regan Winter 2014 üyesi
CPSU-REGAN-W14S13G14
4 Üyeler
19 adet Kılavuz yazıldı
1Rehber Yorum
Thank you Deborah!
James - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 59
Her zaman: 10,889
