Ana içeriğe geç
iRobot Roomba 692 Motherboard Replacement
Neye ihtiyacın var
  1. iRobot Roomba 692 Motherboard Replacement, Battery: adım 1, 3 resimden 1. iRobot Roomba 692 Motherboard Replacement, Battery: adım 1, 3 resimden 2. iRobot Roomba 692 Motherboard Replacement, Battery: adım 1, 3 resimden 3.
    • To access the iRobot Roomba 692 battery compartment, flip your iRobot Roomba 692 upside down.
    • Using the Phillips #0 screwdriver, remove the 4.0mm screw in the center of the yellow side brush and lift the part out.
  2. iRobot Roomba 692 Motherboard Replacement: adım 2, 3 resimden 1. iRobot Roomba 692 Motherboard Replacement: adım 2, 3 resimden 2. iRobot Roomba 692 Motherboard Replacement: adım 2, 3 resimden 3.
    • Use a Phillips #0 screwdriver to remove the four black 3.5 mm screws on the bottom panel.
    • Remove the bottom panel.
    • Can't find the screws? Refer to the red circles in the Step 1 image.
  3. iRobot Roomba 692 Motherboard Replacement: adım 3, 3 resimden 1. iRobot Roomba 692 Motherboard Replacement: adım 3, 3 resimden 2. iRobot Roomba 692 Motherboard Replacement: adım 3, 3 resimden 3.
    • Using the black tabs on both short ends of the battery pack, gently pull the battery up and out of its slot.
  4. iRobot Roomba 692 Motherboard Replacement, Motherboard: adım 4, 3 resimden 1. iRobot Roomba 692 Motherboard Replacement, Motherboard: adım 4, 3 resimden 2. iRobot Roomba 692 Motherboard Replacement, Motherboard: adım 4, 3 resimden 3.
    • Remove the ten 13.3 mm screws with a Phillips #00 screwdriver.
    • Pull off the outer and inner holders.
  5. iRobot Roomba 692 Motherboard Replacement: adım 5, 3 resimden 1. iRobot Roomba 692 Motherboard Replacement: adım 5, 3 resimden 2. iRobot Roomba 692 Motherboard Replacement: adım 5, 3 resimden 3.
    • Use a Phillips #00 screwdriver to remove the two 7.4 mm screws that secure the sensor.
    • Once screws are removed slide out the sensor to free it from the slide bumper.
  6. iRobot Roomba 692 Motherboard Replacement: adım 6, 3 resimden 1. iRobot Roomba 692 Motherboard Replacement: adım 6, 3 resimden 2. iRobot Roomba 692 Motherboard Replacement: adım 6, 3 resimden 3.
    • Wedge open the top with an opening tool.
    • Wedge the side tabs and middle tabs upward to remove the top lid.
  7. iRobot Roomba 692 Motherboard Replacement: adım 7, 3 resimden 1. iRobot Roomba 692 Motherboard Replacement: adım 7, 3 resimden 2. iRobot Roomba 692 Motherboard Replacement: adım 7, 3 resimden 3.
    • Use a Phillips #00 screwdriver to unscrew and remove the following screws:
    • Ten 9.6 mm screws.
    • Four 9.4 mm screws.
    • One 9.5 mm screw.
  8. iRobot Roomba 692 Motherboard Replacement: adım 8, 3 resimden 1. iRobot Roomba 692 Motherboard Replacement: adım 8, 3 resimden 2. iRobot Roomba 692 Motherboard Replacement: adım 8, 3 resimden 3.
    • Lift up the top cover to access the motherboard.
    • Use the Phillips #00 screwdriver to remove all five 7.6 mm screws that are holding it down.
  9. iRobot Roomba 692 Motherboard Replacement: adım 9, 2 resimden 1. iRobot Roomba 692 Motherboard Replacement: adım 9, 2 resimden 2.
    • Unplug the wiring by pulling it outward.
    • Once all plugs are off the motherboard it can be removed, repaired, or replaced.
Sonuç
Ruth Oliva
217 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team 1-1, Harley Fall 2023 IUPUI, Team 1-1, Harley Fall 2023 üyesi
IUPUI-HARLEY-F23S1G1
4 Üyeler
3 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 4
Son 30 gün: 15
Her zaman: 287
