Ana içeriğe geç
iRobot Roomba 692 Side Brush Motor Replacement
Neye ihtiyacın var
  1. iRobot Roomba 692 Side Brush Motor Replacement, Battery: adım 1, 3 resimden 1. iRobot Roomba 692 Side Brush Motor Replacement, Battery: adım 1, 3 resimden 2. iRobot Roomba 692 Side Brush Motor Replacement, Battery: adım 1, 3 resimden 3.
    • To access the iRobot Roomba 692 battery compartment, flip your iRobot Roomba 692 upside down.
    • Using the Phillips #0 screwdriver, remove the 4.0mm screw in the center of the yellow side brush and lift the part out.
  2. iRobot Roomba 692 Side Brush Motor Replacement: adım 2, 3 resimden 1. iRobot Roomba 692 Side Brush Motor Replacement: adım 2, 3 resimden 2. iRobot Roomba 692 Side Brush Motor Replacement: adım 2, 3 resimden 3.
    • Use a Phillips #0 screwdriver to remove the four black 3.5 mm screws on the bottom panel.
    • Remove the bottom panel.
    • Can't find the screws? Refer to the red circles in the Step 1 image.
  3. iRobot Roomba 692 Side Brush Motor Replacement: adım 3, 3 resimden 1. iRobot Roomba 692 Side Brush Motor Replacement: adım 3, 3 resimden 2. iRobot Roomba 692 Side Brush Motor Replacement: adım 3, 3 resimden 3.
    • Using the black tabs on both short ends of the battery pack, gently pull the battery up and out of its slot.
  4. iRobot Roomba 692 Side Brush Motor Replacement, Side Brush Motor: adım 4, 2 resimden 1. iRobot Roomba 692 Side Brush Motor Replacement, Side Brush Motor: adım 4, 2 resimden 2.
    • Remove two gold 12 mm screws from the motor, and lift the motor out.
Sonuç
John Teeguarden
73 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team 1-1, Harley Fall 2023 IUPUI, Team 1-1, Harley Fall 2023 üyesi
IUPUI-HARLEY-F23S1G1
4 Üyeler
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 11
Her zaman: 179
