Ana içeriğe geç
Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
iRobot Roomba 870 Bumper Sensor Replacement
Neye ihtiyacın var
  1. iRobot Roomba 870  Bumper Sensor Replacement, Bumper Sensor: adım 1, 2 resimden 1. iRobot Roomba 870  Bumper Sensor Replacement, Bumper Sensor: adım 1, 2 resimden 2.
    • Flip the iRoomba over so that the underside is facing up.
    • Using the Phillips #0 screwdriver, remove the 4.0mm screw in the center of the yellow side brush.
    • Remove the yellow side brush.
  2. iRobot Roomba 870  Bumper Sensor Replacement: adım 2, 3 resimden 1. iRobot Roomba 870  Bumper Sensor Replacement: adım 2, 3 resimden 2. iRobot Roomba 870  Bumper Sensor Replacement: adım 2, 3 resimden 3.
    • Remove the two 3.5mm Phillips screws that hold the battery cover onto the Roomba with a Phillips #0 screwdriver.
    • Remove the battery cover.
  3. iRobot Roomba 870  Bumper Sensor Replacement: adım 3, 3 resimden 1. iRobot Roomba 870  Bumper Sensor Replacement: adım 3, 3 resimden 2. iRobot Roomba 870  Bumper Sensor Replacement: adım 3, 3 resimden 3.
    • Remove the two remaining 3.5mm Phillips #0 screws that attach the base-plate to the bottom of the Roomba.
    • Remove the entire base-plate from the bottom of the Roomba.
  4. iRobot Roomba 870  Bumper Sensor Replacement: adım 4, 3 resimden 1. iRobot Roomba 870  Bumper Sensor Replacement: adım 4, 3 resimden 2. iRobot Roomba 870  Bumper Sensor Replacement: adım 4, 3 resimden 3.
    • Remove the ten 3mm screws that attach the bumper guard to the bumper with a Phillips #1 screwdriver.
    • Remove the bumper guard.
  5. iRobot Roomba 870  Bumper Sensor Replacement: adım 5, 2 resimden 1. iRobot Roomba 870  Bumper Sensor Replacement: adım 5, 2 resimden 2.
    • Be careful when removing the bumper from the Roomba to prevent damage to the sensor wires. Remove slowly!
    • Lift up the Roomba so that its bumper is not resting on anything, and slowly separate the bumper from the device.
  6. iRobot Roomba 870  Bumper Sensor Replacement: adım 6, 3 resimden 1. iRobot Roomba 870  Bumper Sensor Replacement: adım 6, 3 resimden 2. iRobot Roomba 870  Bumper Sensor Replacement: adım 6, 3 resimden 3.
    • Remove the two 3mm screws that attach the sensor connector to the bumper/sensor with a #1 Phillips Screwdriver.
    • Carefully detach the sensor connector from the bumper and the sensor.
  7. iRobot Roomba 870  Bumper Sensor Replacement: adım 7, 2 resimden 1. iRobot Roomba 870  Bumper Sensor Replacement: adım 7, 2 resimden 2.
    • The sensor is now loose on the bumper. Be careful not to rapidly move the bumper for fear of dislodging the sensor and breaking it.
    • Flip the bumper over, ensuring the sensor remains inside the sensor compartment.
    • Gently remove the bumper from the black infrared sensor.
Sonuç
13 farklı kişi bu kılavuzu tamamladı.
Jacob Lindberg
449 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S14-G3, Banghart Spring 2017 Cal Poly, Team S14-G3, Banghart Spring 2017 üyesi
CPSU-BANGHART-S17S14G3
4 Üyeler
10 adet Kılavuz yazıldı
3 Yorum
Can not get to the plug-in area on the board to replace sensor this way. DOES NOT work this way.
jkeysgate - Yanıt
man kommt nicht an den Stecker. Die Anleitung bringt überhaupt nichts.
Reinhard Totzauer - Yanıt
Incomplete. This NEEDs to explain how to access the plug on the board.
Ed T. - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 32
Son 30 gün: 139
Her zaman: 7,712
