Giriş
If your Roomba is having trouble sensing it's surrounding, or is displaying a bumper sensor error, you will need to replace the sensors. While working through this, make sure to keep track of the screws, as you accumulate quite a few.
Neye ihtiyacın var
Flip your Roomba over so the wheels are facing up.
Using a Phillips #2 screwdriver, remove the side brush and place off to the side. There will be a 10mm screw that remains in the brush.
8 farklı kişi bu kılavuzu tamamladı.
3Kılavuz Yorumları
Great tutorial! I was lucky to only need to follow directions to the point of removing the bumper, just enough to reposition the metal tension springy thing in front. Obviously, I’m a neophyte and need easy to understand, illustrated content to accomplish anything mechanical. You provided everything necessary to get my Roomba back to work. Thank you!
Im a 14 year old and i had a roomba 530 with a error 9 and i fixed it i love these things there so cool it just takes a long time to fix but it was worth it!
just followed this guide and it was easy and replaced all the censors and it still says error 6. any ideas?
