Ana içeriğe geç
iView-776TPCII Battery Replacement
Neye ihtiyacın var
    1. iView-776TPCII Battery Replacement, Rear Panel: adım 1, 3 resimden 1. iView-776TPCII Battery Replacement, Rear Panel: adım 1, 3 resimden 2. iView-776TPCII Battery Replacement, Rear Panel: adım 1, 3 resimden 3.
      • Before disassembling your device, make sure that the power is completely turned off.
      • Use the plastic opening tool to release the clips holding the rear panel of the device onto the front section.
      • The clips may take some pressure before releasing.
      • Continue around the entire device until all of the clips have been released.
      FixBot'a Sor
      Yorum Ekle
    2. iView-776TPCII Battery Replacement: adım 2, 2 resimden 1. iView-776TPCII Battery Replacement: adım 2, 2 resimden 2.
      • Use a spudger to carefully free the speaker from it's housing on the back panel.
      • Place the spudger between the speaker and the rear panel. Use a prying motion to remove the component.
      • Be careful not to apply an over amount of force. If care is not taken, the speaker could break under the pressure.
      FixBot'a Sor
      Yorum Ekle
    1. iView-776TPCII Battery Replacement, Battery: adım 3, 1 resimden 1.
      • Insert the flat side of the standard spudger underneath the battery and use a prying action to loosen the glue holding it to the digitizer.
      • Do this all around the battery until it comes off.
      • The glue is strong, so some force may be required. However, be careful not to apply so much pressure that the battery bends or breaks.
      • At this point, do not attempt to fully remove the battery, since it is still connected to the motherboard.
      FixBot'a Sor
      Yorum Ekle
    2. iView-776TPCII Battery Replacement: adım 4, 1 resimden 1.
      Bu adımda kullanılan alet:
      • Use the Portable Soldering Iron tool to heat the leads coming from the battery to the motherboard, thereby breaking the connection.
      • For help on soldering, refer to the iFixit "How To Solder and Desolder Connections" technique guide as necessary.
      • Once heated, use tweezers to pull the wires free from their connections.
      • To ease reassembly, take note of which wire went to the positive and negative terminals.
      FixBot'a Sor
      Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Cory Gratzer
586 İtibar
5 adet Kılavuz yazıldı
Ekip
IUPUI, Team 2-2, Baechle Fall 2015 IUPUI, Team 2-2, Baechle Fall 2015 üyesi
IUPUI-BAECHLE-F15S2G2
3 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 22
Her zaman: 1,200
