Ana içeriğe geç
plantronics Voyager pro Battery Replacement
Neye ihtiyacın var
Videoya Genel Bakış
  1. plantronics Voyager pro Battery Replacement, Battery: adım 1, 1 resimden 1.
    • order your battery
  2. plantronics Voyager pro Battery Replacement: adım 2, 1 resimden 1.
    • separate rubber case from back of earpiece. you don't need to remove it completely like I did.
  3. plantronics Voyager pro Battery Replacement: adım 3, 1 resimden 1.
    • rotate the back away from the case. its basically glued in place with no other fasteners
  4. plantronics Voyager pro Battery Replacement: adım 4, 1 resimden 1.
    • you will need to slowly cut through the foam to separate the wires from the battery. then use a soldering iron to desolder the old battery from the board these connections go through the entire board.
  5. plantronics Voyager pro Battery Replacement: adım 5, 1 resimden 1.
    • solder the new battery in and test the charging before reassembly.
    • the new battery I ordered was slightly larger but it fit with no problems. I found the wires inside this device to be fairly robust and did not have any issues with wires breaking or dislodging.
    • When I re-assembled I used small amounts of gorilla glue for both the case and the rubber cover. it worked very well and has worked well since. for more details I put together a short video you can check out.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Dan Dunham
3.477 İtibar
30 adet Kılavuz yazıldı
2Kılavuz Yorumları
I accomplished this battery replacement. I was successful. However in my opinion, this device was not meant to have this repair done. It is a “fiddley” affair, but possible. I think it took me two hours, at my leisure. Probably better off replacing the device. Unless…. your just that type who enjoys fiddling around.
Leslie Womelsdorff - Yanıt
I have 2 of these type headsets that I bought as refurbs. They both lasted less than a year...cheap batteries I'm thinking. The process from Dan looks to be a moderate repair. I am going to give it a go because I like to fix things and will write back if I complete the process!
Richard - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 14
Son 30 gün: 112
Her zaman: 5,455
