Ana içeriğe geç
ring Indoor Cam Body Replacement
John Bray
John Bray ve 5 diğer katkıda bulunanlar
En son December 20, 2023 tarihinde güncellendi
5 - 10 dakika
Kolay
This guide provides a replacement walkthrough for the body of the ring Indoor Cam. This walkthrough is useful for opening the device for internal repairs or replacement of the camera base or body.
While prying the device, insert multiple iFixit opening picks into the creases to loosen the interlocking of the cam covers and prevent damaging your device.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. ring Indoor Cam Body Replacement, Body: adım 1, 3 resimden 1. ring Indoor Cam Body Replacement, Body: adım 1, 3 resimden 2. ring Indoor Cam Body Replacement, Body: adım 1, 3 resimden 3.
    • Place the cam with the base facing towards you.
    • Loosen the 21.6 mm silver screw using a Phillips #1 screwdriver.
    • Remove the base from the rest of the camera.
  2. ring Indoor Cam Body Replacement: adım 2, 2 resimden 1. ring Indoor Cam Body Replacement: adım 2, 2 resimden 2.
    • Place the cam with the top facing toward you.
    • Insert the iFixit opening pick into the crease at the top of the camera.
    • Slide the pick along the crease until you can separate the top cover of the camera from the backing.
    • Leave the pick in the crease.
  3. ring Indoor Cam Body Replacement: adım 3, 2 resimden 1. ring Indoor Cam Body Replacement: adım 3, 2 resimden 2.
    • Place the camera on its side where the horizontal crease is facing you.
    • Insert another iFixit opening pick into the crease between the front and back portions of the camera.
  4. ring Indoor Cam Body Replacement: adım 4, 3 resimden 1. ring Indoor Cam Body Replacement: adım 4, 3 resimden 2. ring Indoor Cam Body Replacement: adım 4, 3 resimden 3.
    • Slide the pick along the vertical crease until you can remove the back cover of the cam, using the opening tool to pry the portions apart.
    • You may hear a popping noise when you pry it open.
Sonuç
John Bray
411 İtibar
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 25
Son 30 gün: 70
Her zaman: 722
