Ana içeriğe geç
ring Indoor Cam Camera Replacement
John Bray
John Bray ve 5 diğer katkıda bulunanlar
En son December 20, 2023 tarihinde güncellendi
10 - 15 dakika
Orta
Is your ring Indoor Cam's camera malfunctioning, the image not showing clearly, or not showing at all? Then, you can use this guide as a walkthrough to replace the camera.
While replacing the camera you will need to detach small white leads from sockets on the motherboard, so make sure to handle them with care.
While doing so you'll need to make sure your Indoor Cam isn't connected to any electrical circuits and that you're using ESD-safe tools in order to avoid electrical injuries
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. ring Indoor Cam Camera Replacement, Body: adım 1, 3 resimden 1. ring Indoor Cam Camera Replacement, Body: adım 1, 3 resimden 2. ring Indoor Cam Camera Replacement, Body: adım 1, 3 resimden 3.
    • Place the cam with the base facing towards you.
    • Loosen the 21.6 mm silver screw using a Phillips #1 screwdriver.
    • Remove the base from the rest of the camera.
  2. ring Indoor Cam Camera Replacement: adım 2, 2 resimden 1. ring Indoor Cam Camera Replacement: adım 2, 2 resimden 2.
    • Place the cam with the top facing toward you.
    • Insert the iFixit opening pick into the crease at the top of the camera.
    • Slide the pick along the crease until you can separate the top cover of the camera from the backing.
    • Leave the pick in the crease.
  3. ring Indoor Cam Camera Replacement: adım 3, 2 resimden 1. ring Indoor Cam Camera Replacement: adım 3, 2 resimden 2.
    • Place the camera on its side where the horizontal crease is facing you.
    • Insert another iFixit opening pick into the crease between the front and back portions of the camera.
  4. ring Indoor Cam Camera Replacement: adım 4, 3 resimden 1. ring Indoor Cam Camera Replacement: adım 4, 3 resimden 2. ring Indoor Cam Camera Replacement: adım 4, 3 resimden 3.
    • Slide the pick along the vertical crease until you can remove the back cover of the cam, using the opening tool to pry the portions apart.
    • You may hear a popping noise when you pry it open.
  5. ring Indoor Cam Camera Replacement, Motherboard: adım 5, 3 resimden 1. ring Indoor Cam Camera Replacement, Motherboard: adım 5, 3 resimden 2. ring Indoor Cam Camera Replacement, Motherboard: adım 5, 3 resimden 3.
    • Gently remove the three white leads from their sockets on the top of the motherboard.
  6. ring Indoor Cam Camera Replacement: adım 6, 2 resimden 1. ring Indoor Cam Camera Replacement: adım 6, 2 resimden 2.
    • Using a Phillips #00 screwdriver, remove the two 4.7 mm black screws located in the corners of the motherboard.
    • Using a Phillips #00 screwdriver, remove the two silver 5 mm screws in the center of the motherboard.
  7. ring Indoor Cam Camera Replacement: adım 7, 3 resimden 1. ring Indoor Cam Camera Replacement: adım 7, 3 resimden 2. ring Indoor Cam Camera Replacement: adım 7, 3 resimden 3.
    • Use the iFixit opening pick to pry the motherboard from the body of the camera.
  8. ring Indoor Cam Camera Replacement: adım 8, 2 resimden 1. ring Indoor Cam Camera Replacement: adım 8, 2 resimden 2.
    • Detach the black wire connecting the motherboard to the body of the camera.
  9. ring Indoor Cam Camera Replacement, Camera: adım 9, 3 resimden 1. ring Indoor Cam Camera Replacement, Camera: adım 9, 3 resimden 2. ring Indoor Cam Camera Replacement, Camera: adım 9, 3 resimden 3.
    • Gently turn to the motherboard's backside and remove the white leads connecting the camera to the socket in the motherboard.
    • Cautiously remove the camera.
Sonuç
John Bray
411 İtibar
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 22
Her zaman: 433
