Sorunum
The left fan was making noise.
Tamirim
Repair went smooth, easy to remove and install the new fan.
Önerim
Be careful, screws are really small, pay attention to what length screw goes in each location.
İptal Et
Bu ürün ülkenizde mevcut değil.
Ürün Kodu: IF161-017-1
$59,99
iFixit Pro indirimi uygulandı. Kayıt no:
$59,99
A-Stok kullanılmış parçalar mükemmel durumda
B-Stok parçalarının dış yüzeylerinde ufak tefek hasarlar var
C-Stok parçalarının dış yüzeyleri ciddi şekilde hasar görmüş ancak tamamen kullanılabilir durumdalar
$59,99
$59,99
Stokta Yok
Nakliyata Hazır
Stokta Yok
Nakliyata Hazır
Bizde bu kadar stok mevcut değil
Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
Mağazamıza Göz AtınÜrün Detayı
Açıklama
Açıklama
Replace the left fan for your Late 2008 through Mid 2012 Unibody 15" MacBook Pro (excluding Mid 2009 2.53 GHz) with this part. This part includes the fan and its surrounding metal bracket.
Açıklama
Açıklama
Uyumluluk
Uyumluluk
Teknik Özellikler
Teknik Özellikler
Uyumluluk
3 cihaz daha göster
3 cihaz gizle
Onarım hikayeleri
Fan was making horrible noise at times.
Repair was really simple. Basically remove the bottom plate to get inside the computer then removed 3 screws holding the fan in place. Used a plastic pry tool to gently disconnect the fan from connector and put the new one in, in a flash.
Just make sure you have a plastic pry tool. I've got one in a "mobile phone tool kit" from defunct RadioShack. They were also including in some iphone glass repair kits I've purchased in the past. I'm sure an electronics store would sell them in a "mobile phone took kit" as well.
Just make sure you hav . . .
Left fan on a MacBook Pro - was very noisy
Perfect /easy - iFixit instructions were fantastic.
Check the iFixit list before you just click on the tools they recommend - they should also recommend an anti-static wrist loop. Also use an egg box or daily/weekly pill dispenser to keep all the little screws as you go.
Check the iFixit list before you just click on the tools they recommend - they should also recommend an anti-static wrist loop. Also use an egg box or daily/weekly pill dispenser to keep all the little scre . . .
Left fan runs / stops randomly, and makes big noise!
Easy to replace within 10 min.
To browse infixit instruction before fixing it. It is hopeful!
Had to change the battery in my 5 year old MacBook Pro 15"
The service and delivery speed was top notch!
Installed the new battery I got from Ifixit.
What bothers me is that the new battery is not as good as I expected.
It drains fairly quickly, almost the same speed as the old one.
The situation is somewhat getting better.
Is this normal? Did I do something wrong when charging for the first time, etc. etc... Or are those batteries just some second grade product?
The situation i . . .
The fans on my MacbookPro had been running constantly due to some software that seemed to need 1 CPU to run constantly to check web pages. After finally figuring out which software to trash and reducing use of the fan, the wear and tear of this bad software took its toll and eventually the fans started to periodically make a grinding noise.
The directions from iFixit were great, the parts arrived quickly and it took about 30 minutes to complete the repair. No problems were encountered.
Follow the directions and be careful not to strip the screws when reinstalling them
The fans on my MacbookPro had been running constantly due to some software that seemed to need 1 CPU to run constantly to check web pages. After finally figuring out which software to trash and reducing use of the fan, the wear and tear of this bad software took its toll and eventually the fans sta . . .
My brother's Macbook Pro was making some interesting sounds on top of overheating. We did some research and came across ifixit.com how-to articles. From there, I ordered the fans (used), and the problem was fixed!
Removing and replacing the right and left fans (Macbook Pro 15 mid-2009 2.8 GHz model) was simple. I ordered the required tools (Philips #00 screwdriver, spudger, & anti-static wristband) along with the fans, unscrewed the bottom plate, popped out the connectors with spudger, unscrewed fans, and then did the reverse. Simple!
2 pieces of advice: use an anti-static wristband and be careful while handling the spudger to disconnect fans.
Removing and replacing the right and left fans (Macbook Pro 15 mid-2009 2.8 GHz model) . . .
fans started making grinding noise so had to replace
No problems. Easy and didn't take long
Make sure to clean out the intake grills before you switch up your fans, and it's probably a good idea to start cleaning out that dust every 6 months or so
Mis ventiladores hacían muchísimo ruido, ni se iba con lubricante especial para ventiladores.
Ventiladores como nuevo. Silencio absoluto. Paquete bien protegido. Atención, servicio y rapidez de entrega inmejorable.
Valoración 12 sobre 10.
Lamento que en su página en Europa, no tengan existencias, pero si las tengan en USA; lo que conlleva un sobre coste de aduanas.
Lamento que en su página en Europa, no tengan existencias, . . .
leftFAN noises and damaged
rightFAN was ok but i want to change it
All perfect, except for the rightFAN. I can't unscrew the old one, the screw is locked!
nn
Daha fazla göster
Daha az göster
Bu ürünü satın alan müşteriler aynı zamanda aşağıdaki ürünleri de satın aldı
