Ana içeriğe geç
« Tüm hikâyelere geri dön
iPhone 6 GPS working like new!!
Wes Adeyinka-Skold -
iPhone 6
Hikâye görseli
  • Görsel #1
  • Görsel #2
  • Görsel #3
iPhone 6 Antenna Flex Cable Replacement
2 saat
Moderate
Sorunum
The GPS functionality was very inaccurate, making it seem like I was driving in bodies of water or random neighborhoods. Simply put, the phone could no longer assess my location correctly.
Tamirim
Almost everything was EXTREMELY smooth. I had removed the logic board on an iphone 4 in the past, so I felt more comfortable this time around. The one hitch was that I accidentally tried to plug the antenna connector wire into a screw hole as opposed to back onto the logic board. I used too much force, causing the padding to come off the back of it. That said, I was able to get it onto the logic board once I figured out the issue.
Önerim
Setup is key. Make sure you make a chart (magnetic, or using double-sided tape) to keep track of each exact length of screw. There are about 12 different lengths of screws!! Breathe, take your time, and use steady, confident motions. Lastly, there are two different phillips screw heads in the pack--one is wider, and one is deeper. The deeper one is better for getting the screws back in to the screw holes. The wider one is necessary for getting them all-the-way tight.
iPhone 6 Logic Board Antenna Flex Cable Resmi
$14.99
Bir Yorum
Dragon Mania Mod APK – Guys, we’ve come with Lee- Dragon Mania legends mod apk for you. This game is very exciting. It will be quite fun to play This game is the most exciting game action game. In this game, we can also create houses and buildings for all living creatures. After that, we help provide In this game, you are given an island, where you feed the food. And when they take your food, they will grow, so the game keeps moving ahead. To learn more about this game, keep reading our post until
the end. food to those people.
Download Dragon Mania Mod APK
akhilesh871 - Yanıt
Yorum Ekle
