Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
« Tüm hikâyelere geri dön
Metal pry tools and bulging batteries!
Liam -
iPhone 6
Hikâye görseli
How to Replace Your iPhone 6 Battery
20 dakika
Easy
Sorunum
Customer brought an iPhone 6 into the store with a massive bulging battery that was pushing the screen out of the frame... not good.
Tamirim
As it was my first time removing a battery from a device unsupervised, I thought I would use a metal pry tool to get under that bulging battery and pry it the !&&* outta there. Little did i know that metal and batteries absolutely do not mix.
Got the little piece of sheet metal under the battery for all about 2 minutes before I heard a small popping sound. Only a little worried, but seeing no reason to stop as the battery appeared fine, I continued... to use the metal pry tool. Another quick slice with that tiny piece of metal and I could smell it before I could see it.
I didn't have to wonder long what the smell was as moments later plumes of smoke started coming out of the device in my hand. If you've never held an exploding battery before, it is terrifying. I discard the device onto my desk and stepped back as it kept blowing smoke for the next minute.
After the smoke started to subside, I investigated the slightly charred piece of metal that had made contact with the innards of the battery, and realised just what I had done.
The battery was still only partially adhered to the device, so I was able to pull the rest out by hand without using a METAL pry tool. Luckily for me none of the rest of the phone had any damage and it even still worked after I got the replacement battery in there. Customer was informed of a slight mishap but the device was functioning fine so I didn't feel the need to tell her I had blown it up an hour earlier.
Önerim
Never, ever, never, EVER, use a metal tool when trying to remove a battery. Don't use anything metal at all near the battery if the tool is sharp or the battery is compromised. Just take things slow and steady and use alcohol or heat to remove adhesive with plastic tools, never metal.
Alcohol Dispensing Bottle Görseli
$19.99
Bir Yorum
Darn. That’s rough buddy.
Melvyn - Yanıt
Yorum Ekle
