Ana içeriğe geç
« Tüm hikâyelere geri dön
iPhone 4 5-Point Pentalobe Screwdriver modification needed
dbuckel -
iPhone 4 Verizon
Hikâye görseli
iPhone 4 Verizon Rear Panel Replacement
5 dakika
Easy
Sorunum
Purchased the screwdriver to repair a broken back cover on an iPhone 4.
Tamirim
Fixing the iPhone was very easy and quick. Unfortunately, the screwdriver had to be modified prior to use. The tip of the screwdriver was too long and came to too fine of a point to grip the screw.
Önerim
Very, and I mean VERY, gently grind or file off a small amount of the excess tip. I'd suggest grinding a little and testing the fit and then grinding some more if needed. Be sure to keep the tip square to the grinder.
P2 Pentalobe Screwdriver iPhone Görseli
$5.99
iPhone 4 (CDMA/Verizon) Blank Rear Glass Panel Görseli
$9.99
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 204
