Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Seagate Expansion cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Expansion Teardown, Open the cover: adım 1, 1 resimden 1.
    • Using a flat head screwdriver or plastic tool
  2. Expansion Teardown: adım 2, 1 resimden 1.
    • Remove the cover
  3. Expansion Teardown: adım 3, 1 resimden 1.
    • Remove the drive from the case
  4. Expansion Teardown: adım 4, 1 resimden 1.
    • Peel back the shielding
  5. Expansion Teardown: adım 5, 1 resimden 1.
    • Remove the Screw with the #02 screw driver
  6. Expansion Teardown: adım 6, 2 resimden 1. Expansion Teardown: adım 6, 2 resimden 2.
    • Separate the adapter form the sata port
Dan
4.261 İtibar
9 adet Kılavuz yazıldı
2 Yorum
Hello,
I’d like to know if it’s possible to swap in another bigger NAS drive, as I keep my hard drive connected and it might be more durable.
Thank you !
Léana Jiang - Yanıt
This does appear to be a semi-destructive method. In the picture under step 2, you can see the series of plastic brackets on the cover are snapped. See my pictures here
I had difficulty finding a spot to pry up from. There are 4 lips around the cover that should make it easier. See pics.
Derick Roy - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 12
Son 30 gün: 76
Her zaman: 3,925
