Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Fitbit Charge HR cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Fitbit Charge HR Teardown, Remove Screws: adım 1, 1 resimden 1.
    • Take the 4 Screws out of the Sides you will need a T3 star Screw Driver
  2. Fitbit Charge HR Teardown: adım 2, 2 resimden 1. Fitbit Charge HR Teardown: adım 2, 2 resimden 2.
    • You Pry out the Main board you can see the Metal Hooks
  3. Fitbit Charge HR Teardown: adım 3, 1 resimden 1.
    • You can Then pull out the Screws from around the Screen
Bradley Nelson
56 İtibar
1 Kılavuz yazıldı
8Kılavuz Yorumları
Can the battery be replaced?
Rick - Yanıt
Mine was just over a year old (barely out of warranty) when it died. The Fitbit folks were kind enough to replace it anyway once I expressed my displeasure. I'd haggle with them a bit before going the DIY route but I'm definitely keeping my old one for spare parts. Hopefully someone will point out an aftermarket battery source before I need to do that.
fragmasterflash - Yanıt
The screws in mine were Torx T-2, not T-3.
Jake McIvor - Yanıt
The button is stuck in my ChargeHR. I bought the T3 screwdriver and it is too big. Either the screws are T2 or my screwdriver is too much imprecise.
Anyone fixed a stuck button?
Anderson Maciel - Yanıt
it definitely not T3 must be T2
Marc Frederick - Yanıt
No, a charge hr is a t3
eric hicks - Yanıt
Definitely not T3 screws, bought a T3 just for this - its too big!
martin - Yanıt
Does anyone know where to get a spare band?
RoadKill - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 21
Her zaman: 24,075
