Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Fujifilm Camera cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Fujifilm Camera Teardown, Fujifilm Camera Teardown: adım 1, 3 resimden 1. Fujifilm Camera Teardown, Fujifilm Camera Teardown: adım 1, 3 resimden 2. Fujifilm Camera Teardown, Fujifilm Camera Teardown: adım 1, 3 resimden 3.
    Bu adımda kullanılan alet:
    • tools needed
    • Phillips 00 screwdriver
    • "Y" screwdriver
    • tweezers
    • small needle nose pliers
    • small plastic pry tool
    • plastic spudger
    • the iFixit Pro Tech tool kit contains all necessary tools for this job
  2. Fujifilm Camera Teardown, open it up: adım 2, 1 resimden 1.
    • remove the 2 Phillips 00 screws from the bottom
    • remove the 1 Phillips 00 screws from the side
    • remove the 2 "Y" screws from the other side
  3. Fujifilm Camera Teardown, remove back: adım 3, 1 resimden 1.
    • use your plastic pry tool to remove the back of the camera
    • make sure the battery door is open as it will hold the back in place
    • remove back carefully camera has a ribbon cable running to the digitizer screen
    • disconnect digitizer cable
  4. Fujifilm Camera Teardown, remove view finder: adım 4, 3 resimden 1. Fujifilm Camera Teardown, remove view finder: adım 4, 3 resimden 2. Fujifilm Camera Teardown, remove view finder: adım 4, 3 resimden 3.
    • you should have already disconnected the copper ribbon cable and the molex connector with the pink and white wires.
    • wiggle the view finder gently until it comes lose
  5. Fujifilm Camera Teardown, remove battery compartment: adım 5, 1 resimden 1.
    • there is a small white ribbon cable attached to the battery compartment and the cameras logic board verify that it's disconnected
    • there is a molex connector with a black wire and a red wire coming from the battery compartment going to the cameras logic board. disconnect this wire from the logic board.
    • using your plastic pry tool carefully free battery compartment from the camera housing
  6. Fujifilm Camera Teardown, LCD removal: adım 6, 3 resimden 1. Fujifilm Camera Teardown, LCD removal: adım 6, 3 resimden 2. Fujifilm Camera Teardown, LCD removal: adım 6, 3 resimden 3.
    • remove the 2 Phillips screws securing the LCD one is in the upper left corner and the other is on the lower right corner
    • gently lift the top of the LCD panel towards you
    • use caution not to damage the copper ribbon cable behind the display
    • use a plastic pry tool to release the latch that secure the cable to the logic board
    • gently pull the ribbon cable from the logic board
  7. Fujifilm Camera Teardown, Removal of logic board 1: adım 7, 3 resimden 1. Fujifilm Camera Teardown, Removal of logic board 1: adım 7, 3 resimden 2. Fujifilm Camera Teardown, Removal of logic board 1: adım 7, 3 resimden 3.
    • STILL WORKING ON THIS GUIDE PLEASE CHECK BACK
Timothy Fogg
21 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 29
Her zaman: 1,616
