Neye ihtiyacın var
Disconnect the power connector from the circuit board.
Push the black tabs on the ZIF connector towards the cable, then remove the cable.
After disconnecting the ribbon cable, we can inspect the LED array.
It has both warm and cold colored LEDs.
There is a weight glued in below the LED.
The panel feels heavy and weighted. There is also a weight glued in under the LED array, seemingly in an attempt to make the device feel more premium.
Disconnect the audio cable
Here we can see the motherboard. It has an ESP32 processor.
There is a blank area that could possibly hold a second ESP32
There is also a 32GB MicroSD card
To remove the MicroSD card, stick your nail into the slot on the metal latch, and slide it towards the ESP32.
