Giriş
Under the weight of a myriad of tariffs and embargoes, Huawei released their Mate 30 Pro under their own power. While the rest of the world wonders whether this thing will survive without the search engine overlord, we’re more concerned about what’s on the inside—only a teardown will tell what sweet hardware everyone outside of China is missing out on, for now.
Stay up to date on the latest teardowns and repair news by following us on Instagram, Twitter, and Facebook. We've got a newsletter too if you're more into emails.
Neye ihtiyacın var
It may look like a front-load washing machine, but cleaning your laundry is about the only thing this phone can't do. Check out the specs on our teardown unit (Chinese model LIO-AL00):
6.53" OLED display with a resolution of 2400 × 1176 (~409.29 ppi)
Huawei Kirin 990 processor with 8-core CPU, 16-Core Mali-G76 GPU, and Neural Processing Unit
Quadruple rear cameras—40 MP ƒ/1.8, 40 MP ƒ/1.6, 8 MP ƒ/2.4 with 3x optical zoom, and a 3D depth-sensing camera
32 MP ƒ/2.0 selfie cam, plus a 3D depth-sensing camera
IP68 dust/water ingress rating, USB-C port (but no headphone jack)
Facial recognition hardware, gesture recognition, and an under-display fingerprint sensor
In a size comparison, the gigantic Mate 20 X 5G still dwarfs the rest of the Mate lineup, including our Mate 30 Pro.
But at 1.1 mm tall, the 30 Pro's camera bump is more than double that of the 0.4 mm bump on last year's vanilla 20 Pro.
Meanwhile, the 88° "ultra curved" display makes for a sleek-looking device, and will make you fumble for a good hold on the slick back.
We’re curious about how those display curves look from the inside. Historically, we've found that curved displays are a big pain to remove.
At the upper edge of the screen, the Mate 30 Pro's additional 3D depth-sensing camera also takes a lot more space than the camera in the tiny teardrop notch of its predecessor.
Bu adımda kullanılan alet:iOpener$17.99
As interesting as the display is, we're pretty sure it has to come off last. Instead, we attack the back cover with our classic move: heat–lift–slice.
We make it through unscathed! The back cover lifts off cleanly (with some gentle convincing). Everything peeking through the back cover while this thing is sealed up is either mounted in the plastic camera frame, or safely housed in the camera module—no booby trap cables here.
Bu adımda kullanılan alet:iFixit Precision Bit Driver, Aluminum$9.99
With just a few flicks and swishes with our precision bit driver, we remove the classic plastic combo frame: flash, NFC coil, and a wireless charging coil.
With the frame out of the way, we extract a sprawling Y-shaped interconnect cable that ... interconnects the USB-C port, motherboard, and accessory board together. It has a handy arrow in case the electrons get lost and need directions.
The only other thing between us and the battery is this anaconda of a cable ("snakes on a phone," anyone?)
This battery comes out with familiar rip-and-pull tabs—or is it pull-and-rip? Whatever it is, it's orange, and it has instructions on it—better than nothing, though.
The 4500 mAh cell is rated at 3.85 V, and a whopping 17.32 Wh of total power. That's a bit more than the 16.04 Wh from the Mate 20 X Pro or the P30 Pro. The iPhone 11 Pro Max trails behind at 15.04 Wh.
These four lenses are the horses for Huawei’s marketing carriage—and with good reason. It's quite a lineup:
40 MP ƒ/1.8 Cine Camera with a classical RGGB pattern on a 1/1.54" IMX608 sensor, outputting a 3:2 format
40 MP ƒ/1.6 SuperSensing Camera with Huawei’s special RYYB pattern and OIS on a 1/1.7" IMX600 sensor, shooting in 4:3
8 MP ƒ/2.4 telephoto lens with OIS over an OV08A10 sensor to offer 3x optical zoom, 5x hybrid zoom and up to 30x digital zoom
3D depth-sensing camera for real-time in-depth video effects with an IMX316 sensor
What remains on the motherboard seems to be the dot projector module that gives the 3D camera something to look at.
A tenacious tandem teardown team effort spudges up the front-facing camera connectors to free three front-facing peepers.
We momentarily scratch our heads as we wonder why Huawei only listed two front cameras in the spec sheet, until we realize that one of these must be the gesture sensor mentioned elsewhere on the page.
The double-wide camera couple houses the larger 32 MP ƒ/2.0 selfie cam on the right, (1/2.8" IMX616 sensor) and the aforementioned 2.4 MP gesture camera on the left (1/6.95" IMX332 sensor).
The single unit is the 3D depth sensing camera with an IMX516 sensor—likely used for face unlock and depth effects for your selfies.
With the cameras out of the way, we remember that this phone is more than just its seven cameras! There's a lot of other stuff in here:
The USB-C port and its Y-shaped interconnect cable
A daughterboard with the SIM card slot on the back
The loudspeaker in its plastic frame
The optical fingerprint scanner (SYNAPTICS S3909).
At the north end of the phone, we're left with a bunch of writhing
snakescoax cables.
With all those things crammed into the phone, the motherboard is shaped to fill the remaining space. Let's see what goodies we can find on this
chocolatesilicon bar: -
HiSilicon Hi6421 power management IC
HiSilicon Hi6422 power management IC
STMicroelectronics BWL68 wireless charging receiver IC
Halo Micro HL1506F1 battery management IC
Dot projector
Microphone
The other side reveals:
SKhynix H9HKNNNFBMAU-DRNEH 8 GB LPDDR4X SDRAM with the SoC Kirin 990 layered underneath
Kioxia (Toshiba) M-CT041930U544311JPN 256 GB UFS
HiSilicon Hi1103 Wi-Fi module (as seen in the Mate 20 X 5G)
An empty pad, which apparently hosts an additional front-end module in the 5G version of this phone
HiSilicon Hi6363 RF transceiver (as in the Mate 20 Pro)
HiSilicon Hi6526 power management IC
NXP 80T37 (likely NFC controller)
Next we dig out the structure-borne speaker driver, previously seen in the P30 Pro teardown.
Aaand what do we have here? It looks like the tiny circular LRA vibration motor from Mates past has been upgraded to a rectangular taptic engine-style buzzer.
Peeling the mysterious wobble box open like a can of sardines, we indeed find an x-axis linear actuator.
What Apple started all the way back in 2014 seems to finally be catching on with other manufacturers. From Meizu to Google to Samsung, and now Huawei—everyone seems to agree that precision haptics (and bigger motors) positively affect the way we interact with these pocket computers.
Bu adımda kullanılan alet:iMac Opening Wheel$7.99
Next up, the ultra-curved screen! We are faced with zero margin between the display and the frame.
Patient heating and prying gets our foot in the seam, and we go slicing around corners and curves with our handy
pizza cutteriMac Opening Wheel that seems to be tailored for this job. -
Finally our opening picks can start gnawing on the glue behind the edge …
… and eventually grant us the success we deserve—an open display.
- Almost every component is modular and can be replaced independently.
- Only standard Phillips screws are used.
- Pull tabs make fairly quick work of battery replacement, once you've carved through the rear cover, plastic frame, and some cables.
- A few components require extended disassembly for service.
- The display can be removed without removing the battery, although it's still tough to pry off and impeded by some cables.
- Glued-down front and back glass means greater risk of breakage, while making all repairs more difficult and lengthy.
Son Düşünceler
Onarılabilirlik Puanı
(10 en kolay onarılabileni)
7Kılavuz Yorumları
About the fingerprint sensor: It should say SYNAPTICS S3909 and not Synopsis (EDA tools) and so the statement from other websites that it is free from US components is just wrong. Apart from the fact that the 5G version of the Mate 30 Pro contains even more US parts (TI, Qualcomm, Cirrus Logic)…
I have what seems to be the Hawaii mate 30 Pro but the components on the inside or not as you show the battery is soldered onto the top board which is a board all in itself and the speaker is soldered onto a smaller bottom board which is separate from the top board and is green said of blue and the SIM tray is like twice as long as what shows and on the backing of the phone like the actual backing it has no writing on it whatsoever
As far as I know the phone does not work with direct power source and the battery removed.
