Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. Flashlight cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Knog PWR Rider 450 Lumen - Teardown, Remove the lens: adım 1, 3 resimden 1. Knog PWR Rider 450 Lumen - Teardown, Remove the lens: adım 1, 3 resimden 2. Knog PWR Rider 450 Lumen - Teardown, Remove the lens: adım 1, 3 resimden 3.
    • I was not able to remove it without breaking it. It has two latches on it's sides. On the picture, the O-ring is also broken while testing another way of opening it.
    • I managed to force open it (and break the latching parts) by using flat head screwdriver and opening picks.
  2. Knog PWR Rider 450 Lumen - Teardown, Remove the 2 screws: adım 2, 1 resimden 1.
    • Remove the 2 screws (the ones that are NOT near the led)
  3. Knog PWR Rider 450 Lumen - Teardown, Pull the assembly out: adım 3, 3 resimden 1. Knog PWR Rider 450 Lumen - Teardown, Pull the assembly out: adım 3, 3 resimden 2. Knog PWR Rider 450 Lumen - Teardown, Pull the assembly out: adım 3, 3 resimden 3.
    • You can now pull from the red side, the whole assembly will come out.
  4. Knog PWR Rider 450 Lumen - Teardown, Search for what you want to fix: adım 4, 3 resimden 1. Knog PWR Rider 450 Lumen - Teardown, Search for what you want to fix: adım 4, 3 resimden 2. Knog PWR Rider 450 Lumen - Teardown, Search for what you want to fix: adım 4, 3 resimden 3.
    • The soldering tabs for the battery are very easily broken. In my case it was the part that caused the lamp to not turn on (although charging and programming was fine)
  5. Knog PWR Rider 450 Lumen - Teardown, Remount the lamp: adım 5, 2 resimden 1. Knog PWR Rider 450 Lumen - Teardown, Remount the lamp: adım 5, 2 resimden 2.
    • Do the steps in reverse order to mount the lamp.
    • If required, use hot-glue to hold the lens
    • Do not put hot-glue in-between the lens and the LED
Nicolas Esseiva
131 İtibar
1 Kılavuz yazıldı
2 Yorum
спасиб тебе, чувак, нигде нет инфы как этот фонарь разобрать, получается там стоит обычный 18650, что-то спустя 4 года начал быстро разряжаться
Nik -B - Yanıt
Like yours, my pwr too stopped working after it fell. Charging was working fine, but the light wouldn't come on. The battery in mine is shorter and wider than the one in your photo. I reinserted the battery, it didn't work. i guess it's time for the garbage. I never thought I would find guidance on disassembling this light on the internet, but I just want to say thank you for providing such valuable instructions. Your detailed steps and excellent pictures were incredibly helpful.
granola - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 38
Her zaman: 854
