Ana içeriğe geç
Neye ihtiyacın var
Videoya Genel Bakış
Bu teardown bir tamir kılavuzu değildir. Lenovo ThinkPad 410 cihazınızı onarmak için, servis kılavuzumuzu kullanın.
    • Unlatch and remove battery
    • Open Acess panel
    • Remove Hard drive
    • Remove wirless WAN
    • Remove DIMM from back
    • Remove Keyboard retaing Screw from bottom of system
    • Turn the system over and open the cover. Push the keyboard toward the back and lift it up. Slide it forward to rest it on the palm rest. Disconnect the ribbon cable.
    • Remove BIOS battery
    • Disconnect the two antenna leads from the Wireless WAN card. Remove the two retaining screws. Rotate the card up and pull it out of the slot.
    • Remeber which lead goes where Prior to removing it . Grey is usually MAIN , black AUX
    • Remove 14 retaining screws from back
    • The first 9 are required for bezel and touchpad removal .
    • M2 × 14 mm, wafer-head, nylon-coated (6)
    • M2 × 3 mm, wafer-head, nylon-coated (3)
    • The remaining need to be removed for base cover removal
    • M2 × 5 mm, wafer-head, nylon-coated (4)
    • M2 × 10 mm, wafer-head, nylon-coated (1)
    • Note: The FPC cable is attached on the underside of the keyboard bezel assembly. In some models, the Bluetooth daughter card is also attached on the underside of the keyboard bezel assembly.
    • Turn system over , open , remove 4 retaining screws and the work form one side , using spudger to remove chasis bezel
    • M2 × 3 mm, wafer-head, nylon-coated (4)
    • Remove 4 retaining screws
    • Remove the two retaining screws on the bottom of the system.
    • M2.5 × 6 mm, wafer-head, nylon-coated (2)
    • Unroute all the wires.
    • Remove the retaining screws.
    • Carefully lift the LCD panel up and out of the chass
kevinleroy
350 İtibar
1 Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
326 Üyeler
1.672 adet Kılavuz yazıldı
5Kılavuz Yorumları
Uhm, sorry, what about the photos? I don't see any...
JoeMuc2014 - Yanıt
Still not seeing any photos accompanying the steps listed in the teardown.
Jason Landers - Yanıt
well. if get short out inside of USB or network line>> that has been stopping the software lunched.
mohammed - Yanıt
we need teardown of T410
mohammed - Yanıt
The video shows a teardown of the T410s. It is a lot different from the T410.
Robert Oschmann - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 19
Son 30 gün: 119
Her zaman: 11,151
