Ana içeriğe geç
Neye ihtiyacın var
Videoya Genel Bakış
Bu teardown bir tamir kılavuzu değildir. Lenovo Yoga 730-13IKB cihazınızı onarmak için, servis kılavuzumuzu kullanın.
    • Insert wisdom here.
  1. Lenovo YOGA 730 13" Teardown: adım 2, 3 resimden 1. Lenovo YOGA 730 13" Teardown: adım 2, 3 resimden 2. Lenovo YOGA 730 13" Teardown: adım 2, 3 resimden 3.
IT FIX
6.361 İtibar
67 adet Kılavuz yazıldı
9Kılavuz Yorumları
Guten Tag. könnten Sie mir bitte sagen. wo man ein Ersatzscharnier rechts für das Modell Lenovo Yoga 730-13IKB , Core i5-8250U, 8GB RAM, 256GB SSD (81CT0023GE) finden kann? Danke im Voraus für Ihre Antwort.
Iurie Ciobanu - Yanıt
Why didn’t you completly pull the board out and show the cpu? Is it removable and upgradable?
Braheem Hazeem (Grumpy Wolf) - Yanıt
Most laptop cpu’s are soldered to their contacts. There’s very few models of laptop’s that will have removable cpu’s in the consumer market.
Matthew Dixon -
I’ve the yoga 30 13 inch FHD touchscreen. Anyone know if the 40 pin connector on the board would support a UHD touchscreen upgrade?
JT Cen - Yanıt
Teardown to me mean you strip it completely down to loose parts. This did not help me at all with removing the screen to replace hinges. This “teardown” is something a rookie should have made. I expect better ifixit.
bw_b_dub - Yanıt
Which one's the keyboard cable? Certain keys are only intermittently working. I think my keyboard connector might be loose.
S I - Yanıt
TP = Touch Pad
KB = Keyboard
PW = Power
IT FIX -
Photos are in really low quality. It would be awesome to be able to read the text in the ram chips :(
Anibal Montano - Yanıt
The “unboxing” portion was completely irrelevant… and a waste of time. Why do so many people think the unboxing is such a monumental event to document and publish…? Aside from that, I totally cringe each time I see purported professionals touching computer components with their bare fingers; this is especially so with the chips. Fingerprints contain corrosive elements that will “eat into” a component.
calbear70 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 26
Her zaman: 14,405
